comment transferer mes contacts de mon palm centro vers un ipod touch ou un iphone
a mon avis le plus simple c’est de passer par la synchro avec un logiciel tiers.
Genre synchro ton palm avec outlook, puis ensuite synchro ton iphone avec outlook.
le probleme c’est que j’utilise thunderbird et je n’ai pas outlook ni outlook express sur mon pc.
merci
Pas évident.
Si tu peux sync ton Palm avec Google Calendar, l’iPhone le fait aussi.
Sinon y'a cette méthode la, via Contacts Windows C'est en Anglais, dis moi si tu t'en sors pas.
- Bring up Palm Desktop. Make sure your Palm phone is sync’ed up. Show the Address page, select all contacts (Ctrl-A), and export them with File, Export vCard… This puts all contact information into a single file as a sequence of vCards.
- Bring up Windows Address Book. You can find this in Start, All Program, Accessories, Address Book.
- Using Windows Explorer, drag the vCard file you created in step 1 to the Windows Address Book window. I had never used Windows Address Book, so it was empty. If yours isn’t empty, you’ll have to decide whether you want to merge your contacts.
- When you drop the file, you’ll get a window asking you to confirm the first contact. Press OK. Another window will come up for the second contact. Press OK until all windows are gone. It’s easiest to hold down the Enter key.
- Bring up iTunes with your iPhone plugged in. Go to your iPhone page, to the Info tab, and configure it to sync from Windows Address Book. Click Apply in the lower-right corner of the window.
- Sync your iPhone. Verify that your contacts transferred over.
- Tell iTunes to stop sync’ing with Windows Address Book, since you probably only wanted a one-way sync. Your contacts will be backed up anyway by iTunes, so the Address Book sync feature doesn’t buy you much.
Edité le 12/05/2009 à 13:51
ca y est ,j’ai réussi ,non sans mal ,avec une traduction aproximative la migration de tous mes contacts vers le carnet d’adresse windows ,qui en fait lié à outlook express (puisqu’il était sur mon PC ,mais je ne l’utilisé pas ),reste plus qu’à synchroniser avec l’iphone.
donc suite au prochain épisode .
et merci pour l’aide;)
Je t’en prie,
dis moi si tu rencontres d’autres difficultés pour la suite.
