Pour les pings, ils sont confirmés par le second PC.
Je fais le nslookup sur le pc portable et je fais le ping sur le pc donc les navigateurs sont bloqués.
Plus j’essaye, plus je me dis que le firewall se met en route ou qu’un truc fait office de firewall sur le PC. Pour essayer, j’ai ajouté une redirection sur mon routeur Linksys pour les 1024 premier ports.
Résultat:
[color=#3333FF]0
<nil>
Closed Your computer has responded that this port exists but is currently closed to connections.
21
FTP
22
SSH
23
Telnet
25
SMTP
79
Finger
80
HTTP
110
POP3
113
IDENT
119
NNTP
135
RPC
OPEN! (Remote Procedure Call) This impossible-to-close port appears in most Windows systems. Since many insecure Microsoft services use this port, it should never be left "open" to the outside world. This port has been exploited to send "Messenger Spam" pop-ups to Microsoft windows users. Since it is impossible to close, you will need a personal firewall or NAT router to block it from external access. Do it soon!
139
Net
BIOS
OPEN! As you probably know by now, the NetBIOS File Sharing port is one of the largest security holes for networked Windows machines. The payoff to Malicious hackers from finding open Windows shares is so big that many scanners have been written just to find open ports like this one. Closing this port is not difficult and it should be a priority for you!
143
IMAP
389
LDAP
443
HTTPS
445
MSFT
DS
OPEN! This impossible-to-close port first appeared on Windows 2000 and was carried over to Windows XP. Since several insecure Microsoft services use this port, it should never be left "open" to the outside world. Since it is impossible to close you’ll need a personal firewall or residential NAT router to block this port from external access. Do it soon!
1002
ms-ils
1024
DCOM
1025
Host
Stealth There is NO EVIDENCE WHATSOEVER that a port (or even any computer) exists at this IP address!
1026
Host
1027
Host
1028
Host
1029
Host
1030
Host
1720
H.323
5000
UPnP
[/color]
Il n’y a pas de firewall pour bloquer le traffic entrant à priori d’après ce que je remarque. Mais, je ne peux pas sortir
