Problème WSUS depuis Maj 3.0
Bonjour tout le monde
Comme mon titre l’explique lors du passage de la 2.0 à la 3.0 les mises à jour ne descendent plus sur mes clients.
voici un aperçu du log :
** START ** Agent: Finding updates [CallerId = AutomaticUpdates]
2007-10-18 11:34:54:707 1068 2dc Agent *********
2007-10-18 11:34:54:707 1068 2dc Agent * Online = Yes; Ignore download priority = No
2007-10-18 11:34:54:707 1068 2dc Agent * Criteria = « IsHidden=0 and IsInstalled=0 and DeploymentAction=‹ Installation › and IsAssigned=1 or IsHidden=0 and IsPresent=1 and DeploymentAction=‹ Uninstallation › and IsAssigned=1 or IsHidden=0 and IsInstalled=1 and DeploymentAction=‹ Installation › and IsAssigned=1 and RebootRequired=1 or IsHidden=0 and IsInstalled=0 and DeploymentAction=‹ Uninstallation › and IsAssigned=1 and RebootRequired=1 »
2007-10-18 11:34:54:707 1068 2dc Agent * ServiceID = {3DA21691-E39D-4DA6-8A4B-B43877BCB1B7}
2007-10-18 11:34:54:707 1068 2dc Misc Validating signature for C:\WINDOWS\SoftwareDistribution\SelfUpdate\Default\wuident.cab:
2007-10-18 11:34:54:707 1068 2dc Misc Microsoft signed: Yes
2007-10-18 11:35:15:755 1068 2dc Misc WARNING: Send failed with hr = 80072ee7.
2007-10-18 11:35:15:755 1068 2dc Misc WARNING: SendRequest failed with hr = 80072ee7. Proxy List used: <(null)> Bypass List used : <(null)> Auth Schemes used : <>
2007-10-18 11:35:15:755 1068 2dc Misc WARNING: WinHttp: SendRequestUsingProxy failed for http://wsus:80/selfupdate/wuident.cab. error 0x8024402c
2007-10-18 11:35:15:755 1068 2dc Misc WARNING: WinHttp: SendRequestToServerForFileInformation MakeRequest failed. error 0x8024402c
2007-10-18 11:35:15:755 1068 2dc Misc WARNING: WinHttp: SendRequestToServerForFileInformation failed with 0x8024402c
2007-10-18 11:35:15:755 1068 2dc Misc WARNING: WinHttp: ShouldFileBeDownloaded failed with 0x8024402c
2007-10-18 11:35:25:052 1068 2dc Misc WARNING: Send failed with hr = 80072ee7.
2007-10-18 11:35:25:052 1068 2dc Misc WARNING: SendRequest failed with hr = 80072ee7. Proxy List used: <(null)> Bypass List used : <(null)> Auth Schemes used : <>
2007-10-18 11:35:25:052 1068 2dc Misc WARNING: WinHttp: SendRequestUsingProxy failed for http://wsus:80/selfupdate/wuident.cab. error 0x8024402c
2007-10-18 11:35:25:052 1068 2dc Misc WARNING: WinHttp: SendRequestToServerForFileInformation MakeRequest failed. error 0x8024402c
2007-10-18 11:35:25:052 1068 2dc Misc WARNING: WinHttp: SendRequestToServerForFileInformation failed with 0x8024402c
2007-10-18 11:35:25:052 1068 2dc Misc WARNING: WinHttp: ShouldFileBeDownloaded failed with 0x8024402c
2007-10-18 11:35:34:083 1068 2dc Misc WARNING: Send failed with hr = 80072ee7.
2007-10-18 11:35:34:083 1068 2dc Misc WARNING: SendRequest failed with hr = 80072ee7. Proxy List used: <(null)> Bypass List used : <(null)> Auth Schemes used : <>
2007-10-18 11:35:34:083 1068 2dc Misc WARNING: WinHttp: SendRequestUsingProxy failed for http://wsus:80/selfupdate/wuident.cab. error 0x8024402c
2007-10-18 11:35:34:083 1068 2dc Misc WARNING: WinHttp: SendRequestToServerForFileInformation MakeRequest failed. error 0x8024402c
2007-10-18 11:35:34:083 1068 2dc Misc WARNING: WinHttp: SendRequestToServerForFileInformation failed with 0x8024402c
2007-10-18 11:35:34:083 1068 2dc Misc WARNING: WinHttp: ShouldFileBeDownloaded failed with 0x8024402c
2007-10-18 11:35:43:115 1068 2dc Misc WARNING: Send failed with hr = 80072ee7.
2007-10-18 11:35:43:115 1068 2dc Misc WARNING: SendRequest failed with hr = 80072ee7. Proxy List used: <(null)> Bypass List used : <(null)> Auth Schemes used : <>
2007-10-18 11:35:43:115 1068 2dc Misc WARNING: WinHttp: SendRequestUsingProxy failed for http://wsus:80/selfupdate/wuident.cab. error 0x8024402c
2007-10-18 11:35:43:115 1068 2dc Misc WARNING: WinHttp: SendRequestToServerForFileInformation MakeRequest failed. error 0x8024402c
2007-10-18 11:35:43:115 1068 2dc Misc WARNING: WinHttp: SendRequestToServerForFileInformation failed with 0x8024402c
2007-10-18 11:35:43:115 1068 2dc Misc WARNING: WinHttp: ShouldFileBeDownloaded failed with 0x8024402c
2007-10-18 11:35:43:115 1068 2dc Misc WARNING: DownloadFileInternal failed for wsus:80… error 0x8024402c
2007-10-18 11:35:43:115 1068 2dc Setup FATAL: IsUpdateRequired failed with error 0x8024402c
2007-10-18 11:35:43:115 1068 2dc Setup WARNING: SelfUpdate: Default Service: IsUpdateRequired failed: 0x8024402c
2007-10-18 11:35:43:115 1068 2dc Setup WARNING: SelfUpdate: Default Service: IsUpdateRequired failed, error = 0x8024402C
2007-10-18 11:35:43:115 1068 2dc Agent * WARNING: Skipping scan, self-update check returned 0x8024402C
2007-10-18 11:35:43:146 1068 2dc Agent * WARNING: Exit code = 0x8024402C
2007-10-18 11:35:43:146 1068 2dc Agent *********
2007-10-18 11:35:43:146 1068 2dc Agent ** END ** Agent: Finding updates [CallerId = AutomaticUpdates]
J’ai déjà cherché un peu partout sur le net et n’ai pas trouvé grand chose qui fonctionne.
merci de votre attention :slight_smile:
Edité le 18/10/2007 à 12:00
j’ai moi aussi fait la mise à jour de WSUS sans aucun problème, je te conseille de désinstaller et de réinstaller le WSUS.
Tu risque de perdre ton temps à essayer de débuger le truc…
a+
Serge
merci serge
c’est ce que j’ai fait
cela refonctionne :wink:
merci a+
