Alors voila je suis un petit noob sur Linux je viens d’installer SuSe Linux 10.1 version Gnome sur mon ordi et je ne parviens pas a avoir le net sur ma carte réseau intégrer Marvell Yukon Gigabit alors que sur la carte réseau Nvidia ca marche nickel, j’ai télécharger les driver Yukon et quand j’ai lancé l’installation il me met ce message d’erreur:
Create tmp dir (/tmp/Sk98IFjLYOMjhNpopbmSjaCQW) [ OK ]
Check user id (0) [ OK ]
Check kernel version (2.6.16.13-4-smp) [ OK ]
Check kernel symbol file (/proc/kallsyms) [ OK ]
Check kernel type (SMP) [ OK ]
Check number of CPUs (2) [ OK ]
Check architecture (found) [ OK ]
Set architecture (x86_64) [ OK ]
Check compiler (/usr/bin/gcc) [ OK ]
Check mcmodel flags (kernel) [ OK ]
Check module support (/sbin/insmod) [ OK ]
Check make (/usr/bin/make) [ OK ]
Check archive file (sk98lin) [ OK ]
Check kernel gcc version (4.1.0) (Kernel:4.1.0 == gcc:4.1.0) [ OK ]
Check sk98lin driver availability (loaded) [ OK ]
Disconnect devices: ls: /proc/net/sk98lin: Aucun fichier ou répertoire de ce type
(done) [ OK ]
Remove driver (done) [ OK ]
Check kernel header files (/usr/src/linux) [ OK ]
Unpack the sources (done) [ OK ]
Check sources for .config file (/usr/src/linux/.config) [ OK ]
Copying file from proc directory (done) [ OK ]
Copy and check .config file (done) [ OK ]
Check the mem address space (lowmem) [ OK ]
Change IOMMU (enabled) [ OK ]
Create new .config file (done) [ OK ]
Execute: make oldconfig (done) [ OK ]
Check kernel header version (Kernel:2.6.16.13-4-smp == Header:2.6.16.[ OK ]
Check kernel functions (Changed: nothing) [ OK ]
Compile the kernel (error) [ failed ]
An error has occurred during the compile proces which prevented
the installation from completing.
Take a look at the log file install.log for more informations.
Installation of sk98lin driver module failed.
Voila apparement il y a une erreur au niveau de la compilation du kernel!!!!
Alors ma config c’est:
DFI Sli-dr expert
Athlon 64 4800+
2go de ram
Geforce 7950 GX2
Ah petite précision c’est la version suse 64 bit
Sur xp je tiens a préciser que ca marche nickel.
PS: Ah oui au passage la 7950 GX2 n’a pas l’air d’etre supporter par défaut par suse au démarrage j’ai eu un bel ecran rose ou je voyait presque rien mais apres un dur labeur pour installer les driver nvidia ca marche nickel.
Si vous avez besoin de renseignement sur ma config Linux ou autre hésitez pas merci ![]()
