salut j y connait pas grand chose, un peu d aide me ferait plaisir
voici 1 rapport
System Information
Time of this report: 10/22/2006, 09:40:04
Machine name: STEVE-FLU8QY9VB
Operating System: Windows XP Home Edition (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_gdr.050301-1519)
Language: French (Regional Setting: French)
System Manufacturer: MEDIONPC
System Model: AWRDACPI
BIOS: Phoenix - AwardBIOS v6.00PG
Processor: Intel® Pentium® 4 CPU 2.53GHz
Memory: 512MB RAM
Page File: 163MB used, 1086MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.2180 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: No problems found. DirectDraw test results: All tests were successful. Direct3D 7 test results: All tests were successful. Direct3D 8 test results: All tests were successful. Direct3D 9 test results: All tests were successful.
Sound Tab 1: No problems found.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: RADEON 9000 Family (Microsoft Corporation)
Manufacturer: ATI Technologies Inc.
Chip type: RADEON 9000 AGP (0x4966)
DAC type: Internal DAC(400MHz)
Device Key: Enum\PCI\VEN_1002&DEV_4966&SUBSYS_11021787&REV_01
Display Memory: 64.0 MB
Current Mode: 1280 x 1024 (32 bit) (75Hz)
Monitor: Écran Plug-and-Play
Monitor Max Res: 1600,1200
Driver Name: ati2dvag.dll
Driver Version: 6.14.0010.6462 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 8/20/2004 01:09:20, 201728 bytes
WHQL Logo’d: Yes
WHQL Date Stamp: n/a
VDD: n/a
Mini VDD: ati2mtag.sys
Mini VDD Date: 8/20/2004 00:53:40, 701440 bytes
Device Identifier: {D7B71EE2-0A26-11CF-096D-0831A0C2CB35}
Vendor ID: 0x1002
Device ID: 0x4966
SubSys ID: 0x11021787
Revision ID: 0x0001
Revision ID: 0x0001
Video Accel: ModeMPEG2_C ModeMPEG2_D
tout est normal ou bien c est normal que ca va pas???
quand j arrive dans le jeu apres le chargement c est tout vert bleu rouge???
merci de votre aide
