Probleme plugins serveur minecraft
bonjour
mon plugin iconomychestshop ne marche pas cela marque
[GRAVE]could not load plugins/iconomychestshop.jar
comment faire:
voici le dossier yml dans permission
groups:
Citoyens:
default: true
info:
prefix: ‹  ›
suffix: ‹  ›
build: true
inheritance:
permissions:
- ‹ bar.foo ›
- ‹ essentials.clearinventory ›
- ‹ essentials.getpos ›
- ‹ essentials.realname ›
- ‹ essentials.compass ›
- ‹ essentials.depth ›
- ‹ essentials.mail ›
- ‹ essentials.mail.send ›
- ‹ essentials.me ›
- ‹ essentials.home ›
- ‹ essentials.sethome ›
- ‹ essentials.ping ›
- ‹ essentials.whois ›
- ‹ essentials.afk ›
- ‹ essentials.rules ›
- ‹ essentials.sell ›
- ‹ lwc.protect ›
- ‹ iConomy.payment ›
- ‹ iConomyChestShop.shop.sell ›
- ‹ iConomyChestShop.shop.buy ›
- 'iConomyChestShop.shop.create ’
- ‹ iConomyChestShop.command.iteminfo ›
Maires:
default: false
info:
prefix: ‹  ›
suffix: ‹  ›
build: true
inheritance:
- Default
permissions:
- ‹ bar.foo ›
- ‹ essentials.me ›
- ‹ lwc.protect ›
- ‹ iConomyChestShop.shop.create ›
Président:
default: false
info:
prefix: ‹  ›
suffix: ‹  ›
build: false
inheritance:
permissions:
Users denote which users are included in which group.
TheNo1Yeti is in the Admin group
Herpina is a member of the Moderator group but also has access
to the herp.derp permissions
Derpina is a member of the admin group but does not have access
to the derp.derp permission node
Users can also have a prefix and suffix as seen with Herpina
users:
cyberieur_ATLM:
group: Président
permissions:
Coldshade:
group: Maires
permissions:
Vedior:
group: Maires
permissions:
battlejoe:
group: Maires
permissions:
voici l’erreur:
[Lnet.minecraft.server.Statistic;@15b0afd
146 recipes
16 achievements
19:30:34 [INFO] Starting minecraft server version Beta 1.5_02
19:30:34 [INFO] Loading properties
19:30:34 [INFO] Starting Minecraft server on *:25565
19:30:34 [ATTENTION] **** SERVER IS RUNNING IN OFFLINE/INSECURE MODE!
19:30:34 [ATTENTION] The server will make no attempt to authenticate usernames.
Beware.
19:30:34 [ATTENTION] While this makes the game possible to play without internet
access, it also opens up the ability for hackers to connect with any username t
hey choose.
19:30:34 [ATTENTION] To change this, set « online-mode » to « true » in the server.s
ettings file.
19:30:34 [INFO] This server is running Craftbukkit version git-Bukkit-0.0.0-706-
gf53e007-b740jnks (MC: 1.5_02)
19:30:34 [INFO] Preparing level « J3DL »
19:30:34 [INFO] Preparing start region
19:30:35 [GRAVE] Could not load ‹ plugins\iConomyChestShop.jar › in folder ‹ plugin
s ›:
java.lang.ExceptionInInitializerError
at org.bukkit.plugin.java.JavaPlugin.initialize(JavaPlugin.java:175)
at org.bukkit.plugin.java.JavaPluginLoader.loadPlugin(JavaPluginLoader.j
ava:140)
at org.bukkit.plugin.SimplePluginManager.loadPlugin(SimplePluginManager.
java:160)
at org.bukkit.plugin.SimplePluginManager.loadPlugins(SimplePluginManager
.java:108)
at org.bukkit.craftbukkit.CraftServer.loadPlugins(CraftServer.java:85)
at net.minecraft.server.MinecraftServer.e(MinecraftServer.java:217)
at net.minecraft.server.MinecraftServer.a(MinecraftServer.java:204)
at net.minecraft.server.MinecraftServer.init(MinecraftServer.java:144)
at net.minecraft.server.MinecraftServer.run(MinecraftServer.java:259)
at net.minecraft.server.ThreadServerApplication.run(SourceFile:394)
Caused by: java.lang.RuntimeException: java.lang.IllegalArgumentException: Error
constructing com.avaje.ebeaninternal.server.core.DefaultServerFactory
at com.avaje.ebean.EbeanServerFactory.createServerFactory(EbeanServerFac
tory.java:114)
at com.avaje.ebean.EbeanServerFactory.(EbeanServerFactory.java:5
7)
… 10 more
Caused by: java.lang.IllegalArgumentException: Error constructing com.avaje.ebea
at com.avaje.ebeaninternal.api.ClassUtil.newInstance(ClassUtil.java:107)
    at com.avaje.ebeaninternal.api.ClassUtil.newInstance(ClassUtil.java:94)
tory.java:112)
… 11 more
Caused by: java.lang.RuntimeException: java.io.FileNotFoundException: H:\T?®l?®c
hargement\minecraft\1.5\serveur bukkit\craftbukkit-0.0.1-SNAPSHOT.jar (Le chemin
dÆaccÞs spÚcifiÚ est introuvable)
at com.avaje.ebeaninternal.server.core.XmlConfigLoader.search(XmlConfigL
oader.java:121)
at com.avaje.ebeaninternal.server.core.XmlConfigLoader.load(XmlConfigLoa
der.java:78)
at com.avaje.ebeaninternal.server.core.DefaultServerFactory.(Defau
ltServerFactory.java:91)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
    at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
    at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Sou
rce)
at java.lang.reflect.Constructor.newInstance(Unknown Source)
at java.lang.Class.newInstance0(Unknown Source)
at java.lang.Class.newInstance(Unknown Source)
at com.avaje.ebeaninternal.api.ClassUtil.newInstance(ClassUtil.java:104)
    ... 13 more
Caused by: java.io.FileNotFoundException: H:\T?®l?®chargement\minecraft\1.5\serv
eur bukkit\craftbukkit-0.0.1-SNAPSHOT.jar (Le chemin dÆaccÞs spÚcifiÚ est introu
vable)
at java.util.zip.ZipFile.open(Native Method)
at java.util.zip.ZipFile.(Unknown Source)
at java.util.jar.JarFile.(Unknown Source)
at com.avaje.ebeaninternal.server.core.XmlConfigLoader.checkJar(XmlConfi
gLoader.java:176)
oader.java:110)
… 22 more
19:30:35 [INFO] LWC Loading shared objects
19:30:35 [INFO] LWC Native library: plugins/LWC/lib/native/Windows/x86/sqlit
ejdbc.dll
19:30:35 [GRAVE] Could not load ‹ plugins\Permissions.jar › in folder ‹ plugins ›:
java.lang.reflect.InvocationTargetException
rce)
ava:138)
java:160)
.java:108)
Caused by: unacceptable character #FFFD special characters are not allowed
in «  », position 4164
at org.yaml.snakeyaml.reader.StreamReader.checkPrintable(StreamReader.ja
va:68)
at org.yaml.snakeyaml.reader.StreamReader.update(StreamReader.java:159)
at org.yaml.snakeyaml.reader.StreamReader.peek(StreamReader.java:117)
at org.yaml.snakeyaml.scanner.ScannerImpl.scanFlowScalarNonSpaces(Scanne
rImpl.java:1449)
at org.yaml.snakeyaml.scanner.ScannerImpl.scanFlowScalar(ScannerImpl.jav
a:1434)
at org.yaml.snakeyaml.scanner.ScannerImpl.fetchFlowScalar(ScannerImpl.ja
va:846)
at org.yaml.snakeyaml.scanner.ScannerImpl.fetchSingle(ScannerImpl.java:8
31)
at org.yaml.snakeyaml.scanner.ScannerImpl.fetchMoreTokens(ScannerImpl.ja
va:339)
at org.yaml.snakeyaml.scanner.ScannerImpl.checkToken(ScannerImpl.java:18
3)
at org.yaml.snakeyaml.parser.ParserImpl$ParseBlockSequenceEntry.produce(
ParserImpl.java:510)
at org.yaml.snakeyaml.parser.ParserImpl.peekEvent(ParserImpl.java:163)
at org.yaml.snakeyaml.parser.ParserImpl.checkEvent(ParserImpl.java:148)
at org.yaml.snakeyaml.composer.Composer.composeSequenceNode(Composer.jav
a:203)
at org.yaml.snakeyaml.composer.Composer.composeNode(Composer.java:158)
at org.yaml.snakeyaml.composer.Composer.composeMappingNode(Composer.java
:230)
at org.yaml.snakeyaml.composer.Composer.composeNode(Composer.java:160)
:230)
:230)
at org.yaml.snakeyaml.composer.Composer.composeDocument(Composer.java:12
2)
at org.yaml.snakeyaml.composer.Composer.getSingleNode(Composer.java:105)
    at org.yaml.snakeyaml.constructor.BaseConstructor.getSingleData(BaseCons
tructor.java:124)
at org.yaml.snakeyaml.Yaml.load(Yaml.java:264)
at com.nijiko.configuration.NotNullConfiguration.load(NotNullConfigurati
on.java:58)
at com.nijikokun.bukkit.Permissions.Permissions.(Permissions.java:
132)
… 13 more
19:30:35 [INFO] Loaded Essentials build 2.1.38 maintained by Zenexer, ementalo,
Aelux, Brettflan, KimKandor, snowleo and ceulemans.
19:30:35 [INFO] Loaded EssentialsChat build 2.1.38 by Zenexer, ementalo, Aelux,
19:30:35 [INFO] Loaded EssentialsProtect build 2.1.38 maintained by Zenexer, eme
ntalo, Aelux, Brettflan, KimKandor, snowleo and ceulemans.
19:30:35 [INFO] Loaded EssentialsSpawn build 2.1.38 maintained by Zenexer, ement
19:30:37 [INFO] [iConomy] Logging is currently disabled.
19:30:37 [INFO] [iConomy] v5.01 (Eruanna) loaded.
19:30:37 [INFO] [iConomy] Developed by: [Nijikokun]
19:30:37 [INFO] LWC Loaded 116 locale strings (0 overrides)
19:30:38 [INFO] LWC Loading SQLite
19:30:38 [INFO] SQLite Using: Native
19:30:38 [INFO] LWC At version: v2.30
19:30:38 [INFO] PlgEssentials version 4.2 is enabled!
19:30:38 [INFO] Whitelist: Trying to load whitelist and settings…
19:30:38 [INFO] done.
19:30:38 [INFO] Whitelist version 2.7 is enabled!
19:30:38 [INFO] Done (0.375s)! For help, type « help » or « ? »
merci d’avance
Edité le 17/05/2011 à 19:31
Hum
Je vois pas trop clair lol, il te faut soit le plugin permissions, soit le plugin EssentialsGroupManager (qui est une copie du plugin permissions en faite)
AS-tu un des deux ?
oui j’ai le plugins permissions
