non le manuel ya keudalle, dans le fichier read me il y a :
Copyright (c) 1998-2003 VIA Technologies Inc.
VIA VT6421 RAID Software Package ReadMe.txt
This readme file provides information on VIA VT6421 software pacakge.
VIA Technologies assumes no responsibility for any errors in this
document and no part of this document may be reproduced,transmitted,
or translated into any language, or in any form without the prior
written permission of VIA Technologies Incorporated.
Package Version 1.00A / ReadMe Version 1.00A
VIA VT6421 RAID controller supports two SATA HDDs + Two IDE HDDs.
It supports RAID 0, 1, 0+1 and JBOD, these functions. This
« VIA VT6421 Software Package » is used to install the drivers and utility
which are needed for using the VIA VT6421 RAID controller.
CONTENTS
System Requirements
Package Version Identification
Software Package Contents
Install Drivers and Utility
Insatll Operating System into HDD of VT6421
Silent install
Notes
System Requirements
Hardware Requirement
This package should be installed on the VIA VT6421.
Supports up to four hard disk drives, which all support LBA address.
Software Requirement
Supports the following Operating Systems:
Operation System
Microsoft Windows NT4.0
Microsoft Windows 98SE
Microsoft Windows Me
Microsoft Windows 2000
Microsoft Windows XP
Microsoft Windows Server 2003 IA32
IE 4.0 or later version must be installed.
The VT6421 RAID driver versions included in this package are:
Operation System Version
Windows 98SE, ME 2.0.950.100
Windows NT 4.0 4.0.1381.100
Windows 2000 5.0.2195.100
Windows XP 5.1.2600.100
Windows Server 2003 IA32 5.1.2600.100
2. The RAID Windows Utility versions included in this package are:
Windows 98SE, ME 2.21
Windows NT 4.0 2.21
Windows 2000 2.21
Windows XP 2.21
Windows Server 2003 IA32 2.21
4. The production tool versions included in this package are:
DOS 1.00
The decompressed software package includes the following files:
\BIOS
6421Vxxx.rom VIA VT6421 BIOS
\Mass_Tool
Dig6421.exe Diagnostic tool for VIA VT6420 controller
Readme.txt Read me file for Dig6421.exe
\6421Raid VIA VT6421 RAID Controller setup folder
Component.cif VIA setup component interface file
RaidDrv.dll VIA setup dynamical link library for Win2000, XP
RaidDrv9x.dll VIA setup dynamical link library for Win98SE
Via_stor.dll VIA setup dynamical link library for WinNT 4.0
\Driver
\2003IA32
VIAsprid.inf VIA VT6421 RAID Controller driver install information file
VIAsprid.sys VIA VT6421 RAID Controller driver for Win Server 2003 IA32
VIAsprid.cat Microsoft WHQL file
\Win2000
VIAsprid.sys VIA VT6421 RAID Controller driver for Win2000
\Win98-Me
VIAsprid.mpd VIA VT6421 RAID Controller driver for Win98 and Me
Vspvsd.vxd VIA VT6421 RAID Controller driver for Win98 and Me ACPI
\Winnt40
VIAsprid.sys VIA VT6421 RAID Controller driver for Win NT4.0
\WinXP
VIAsprid.sys VIA VT6421 RAID Controller driver for WinXP
\RaidTool VIA Windows RAID Tool setup folder
RaidUtl.dll VIA setup dynamical link library
RaidUtlNT.dll VIA setup dynamical link library for Win NT4.0
\Utility
\Win2000-XP
DrvInterface.dll Dynamical link library for utility under Windows NT base OS
\Win98-Me
DrvInterface.dll Dynamical link library for utility under Windows 9x base OS
Raid_tool.chm Help file for utility
Raid_tool.exe Windows RAID utility
\DriverDisk Driver Disk folder for installing Windows NT base OS
Txtsetup.oem Driver install file for installing Windows NT base OS
VT6421 Tag file for installing Windows NT base OS
\2003IA32
\Win2000
\Win98-Me
\Winnt40
\WinXP
0x0409.ini Installshield file
Instmsia.exe Installshield file
Instmsiw.exe Installshield file
Isscript.msi Installshield file
License.rtf VIA software license file
Pcienum.sys VIA setup driver
Readme.txt This file
Setup.exe Install driver and utility
Setup.ini Installshield file
Setup.iss Installshield file
Setup.scf VIA setup configuration file
Viasetup.dll Installshield file
VIA RAID Driver Setup Wizard.msi Installshield file
Install drivers and utility
== Driver Installation ==
Click on the SETUP.EXE program and it will automatically install the
« VIA VT6421 RAID Controller Driver » and utility onto the operating system.
== Driver Uninstallation ==
Click on the SETUP.EXE program and choose « Remove » to remove
« VIA VT6421 RAID Controller Driver » and utility from the operating system.
Install Windows 98SE or Me
Make sure VT6421 BIOS is executed by the system BIOS when POST.
Make sure the HDD wanted for installing the OS is in the first hard disk drive (C:).
Install OS.
Install driver and RAID utility after OS is installed.
2. Install Windows NT 4.0, 2000, XP, or Server 2003
* Copy all files and directories from the DriverDisk folder to a floppy disk.
Make sure the following directories and files are copied into the floppy disk.
A:\
\2003IA32
VIAsprid.inf
VIAsprid.sys
VIAsprid.cat
\Win2000
VIAsprid.inf
VIAsprid.sys
VIAsprid.cat
\Winnt40
VIAsprid.inf
VIAsprid.sys
\WinXP
VIAsprid.inf
VIAsprid.sys
VIAsprid.cat
Txtsetup.oem
VT6421
* Boot system from OS installing CD-ROM.
* Make sure VT6421 BIOS is executed by the system BIOS when POST.
* Press "F6" when OS installer starts running.
* Insert floppy disk.
* Choose the OS device driver wanted for loading.
* Install OS.
* Install RAID utility after OS is installed.
Silent install
Under windows DOS command window, and type « setup -s », the setup program will install the All drivers.
If user want reboot, you can type « setup -s /z"Reboot »", After install the drivers, OS will reboot.
If you want uninstall drivers, you can type « setup -s » again, setup program will remove all drivers.
or type « setup -s /z"reboot »", setup program will remove all drivers and reboot.
Notes
