Bonjour, j’ai un souci avec ie7. j’ai réinstallé xp sur mon pc portable et a chaque fois que j’éssaie d’installer ie7 ca me dit que ie7 n’a pas été installé.
0.328: ================================================================================
0.328: 2008/12/21 16:26:25.515 (local)
0.328: c:\462777c7e3337101fe6cee7ee6327c\update\update.exe (version 6.2.29.0)
0.359: Failed To Enable SE_SHUTDOWN_PRIVILEGE
0.359: Hotfix started with following command line: /quiet /norestart /er /log:C:\WINDOWS
0.359: IECUSTOM: Scanning for proper registry permissions...
0.843: IECUSTOM: Unwriteable key HKCR\Interface\{34A715A0-6587-11D0-924A-0020AFC7AC4D}
0.843: IECUSTOM: Unwriteable key HKCR\Interface\{34A715A0-6587-11D0-924A-0020AFC7AC4D}\ProxyStubClsid
0.859: IECUSTOM: Unwriteable key HKCR\Interface\{34A715A0-6587-11D0-924A-0020AFC7AC4D}\ProxyStubClsid32
0.859: IECUSTOM: Unwriteable key HKCR\Interface\{34A715A0-6587-11D0-924A-0020AFC7AC4D}\TypeLib
1.140: IECUSTOM: Scanning for proper registry permissions...
1.406: IECUSTOM: Scanning for proper registry permissions...
1.734: IECUSTOM: Unwriteable key HKCR\Interface\{34A715A0-6587-11D0-924A-0020AFC7AC4D}
1.796: IECUSTOM: Backing up registry permissions...
1.812: IECUSTOM: Finished backing up registry permissions...
1.812: IECUSTOM: Setting new registry permissions...
1.812: IECUSTOM: Unable to clear DACLs HKCR\Interface\{34A715A0-6587-11D0-924A-0020AFC7AC4D}
1.812: IECUSTOM: Finished setting new registry permissions...
1.812: IECUSTOM: An error occured verifying registry permissions. ERROR: 0x80070534
1.812: DoInstallation: CustomizeCall Failed: 0x3f5
1.812: IECUSTOM: Restoring registry permissions...
1.812: IECUSTOM: Finished restoring registry permissions...
1.828: Impossible d'écrire la clé du Registre de configuration.
1.843: L'installation du Internet Explorer 7 ne s'est pas terminée.
1.843: Update.exe extended error code = 0x3f5
0.359: 2008/12/21 16:44:12.984 (local)
0.359: c:\61b10ed25727acdbb500\update\update.exe (version 6.2.29.0)
0.375: Failed To Enable SE_SHUTDOWN_PRIVILEGE
0.375: Hotfix started with following command line: /quiet /norestart /er /log:C:\WINDOWS
0.375: IECUSTOM: Scanning for proper registry permissions...
0.797: IECUSTOM: Unwriteable key HKCR\Interface\{34A715A0-6587-11D0-924A-0020AFC7AC4D}
0.797: IECUSTOM: Unwriteable key HKCR\Interface\{34A715A0-6587-11D0-924A-0020AFC7AC4D}\ProxyStubClsid
0.797: IECUSTOM: Unwriteable key HKCR\Interface\{34A715A0-6587-11D0-924A-0020AFC7AC4D}\ProxyStubClsid32
0.797: IECUSTOM: Unwriteable key HKCR\Interface\{34A715A0-6587-11D0-924A-0020AFC7AC4D}\TypeLib
1.047: IECUSTOM: Scanning for proper registry permissions...
1.297: IECUSTOM: Scanning for proper registry permissions...
1.578: IECUSTOM: Unwriteable key HKCR\Interface\{34A715A0-6587-11D0-924A-0020AFC7AC4D}
1.625: IECUSTOM: Backing up registry permissions...
1.641: IECUSTOM: Finished backing up registry permissions...
1.641: IECUSTOM: Setting new registry permissions...
1.641: IECUSTOM: Unable to clear DACLs HKCR\Interface\{34A715A0-6587-11D0-924A-0020AFC7AC4D}
1.641: IECUSTOM: Finished setting new registry permissions...
1.641: IECUSTOM: An error occured verifying registry permissions. ERROR: 0x80070534
1.641: DoInstallation: CustomizeCall Failed: 0x3f5
1.641: IECUSTOM: Restoring registry permissions...
1.641: IECUSTOM: Finished restoring registry permissions...
1.656: Impossible d'écrire la clé du Registre de configuration.
1.672: L'installation du Internet Explorer 7 ne s'est pas terminée.
1.672: Update.exe extended error code = 0x3f5
il y a pas mal de clé de registre qui sont unwrittable , est ce que vous sauriez d’ou ca peut venir?
merci d’avancd
bonne journée
Edité le 21/12/2008 à 16:51
