Voilà j’essaie d’installer le driver nforce officiel et j’ai une erreure que je n’arrive pas à résoudre à propos de kernel précompilé que je n’aurai pas.
Vous n’auriez pas une solution par hasard, merci ![]()
voici mon fichier de log
nforce-installer log file ‹ /var/log/nvidia-nforce-installer.log ›
creation time: Fri Jun 16 03:34:44 2006
option status:
license pre-accepted : false
expert : false
uninstall : false
driver info : false
no precompiled interface : false
no ncurses color : false
no questions : false
silent : false
Installer install prefix : /usr
kernel source path : (not specified)
net kernel install path : (not specified)
audio kernel install path : (not specified)
proc mount point : /proc
ui : (not specified)
tmpdir : /tmp
Using: nvidia-installer ncurses user interface
-> Found package NVIDIA audio driver for Linux-x86_64
-> Found package NVIDIA network driver for Linux-x86_64
-> Please select packages for installation:
Selections:
NVIDIA audio driver for Linux-x86_64 (1.0-7)
NVIDIA network driver for Linux-x86_64 (1.0-13)
-> Starting install of NVIDIA audio driver for Linux-x86_64
-> Checking for loaded module nvsound
-> Checking for loaded module nvaudio
-> License accepted.
-> Skipping check for conflicting rpms.
-> /proc/version is Linux version 2.6.15-23-amd64-generic (buildd@yellow) (gcc
version 4.0.3 (Ubuntu 4.0.3-1ubuntu5)) #1 SMP PREEMPT Tue May 23 13:45:47
UTC 2006
-> No precompiled kernel interface was found to match your kernel; this means
that the installer will need to compile a new kernel interface.
ERROR: Unable to find the kernel source tree for the currently running kernel.
Please make sure you have installed the kernel source files for your
kernel; on Red Hat Linux systems, for example, be sure you have the
‹ kernel-source › rpm installed. If you know the correct kernel source
files are installed, you may specify the kernel source path with the
‹ –kernel-source-path › commandline option.
ERROR: Installation of the audio driver has failed. Please see the file
‹ /var/log/nvidia-nforce-installer.log › for details. You may find
suggestions on fixing installation problems in the README available on
the Linux driver download page at www.nvidia.com.
-> Starting install of NVIDIA network driver for Linux-x86_64
-> Checking for loaded module nvnet
-> Checking for loaded module forcedeth
-> Trying to remove loaded module forcedeth
UTC 2006
ERROR: Installation of the network driver has failed. Please see the file
