Impossible de graver avec mon graveur, voilà ce qui m’affiche le rapport de gravure, c’est la même chose pour les DVD et les CD.
1A22-0206-0530-1610-5715-1441*
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File ‹ C:\Program Files\Ahead\nero\Wnaspi32.dll ›: Ver=2.0.1.74, size=164112 bytes, created 26/10/2004 17:35:32
Nero Version: 6.6.0.12
Internal Version: 6, 6, 0, 12d
(Nero Express)
Recorder: <SONY DVD RW DRU-810A> Version: 1.0a - HA 4 TA 0 - 6.6.0.12
Adapter driver: <atapi> HA 4
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
CD-ROM: <IDE-DVD DROM6216 >Version: HD07 - HA 4 TA 1 - 6.6.0.12
=== Scsi-Device-Map ===
DiskPeripheral : ST3200822AS atapi Port 2 ID 0 DMA: On
CdRomPeripheral : SONY DVD RW DRU-810A atapi Port 4 ID 0 DMA: On
CdRomPeripheral : IDE-DVD DROM6216 atapi Port 4 ID 1 DMA: On
=== CDRom-Device-Map ===
SONY DVD RW DRU-810A E: CDRom0
IDE-DVD DROM6216 F: CDRom1
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 1022MB (1047024kB)
Free physical memory: 547MB (560696kB)
Memory in use : 46 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
19.11.2005
CD-ROM (ISO)
11:00:36 #1 Text 0 File Isodoc.cpp, Line 6194
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : FALSE
Multisession : TRUE
Multisession type: : Start multisession
Burning mode : TAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
11:00:36 #2 Text 0 File Burncd.cpp, Line 2868
Power-Burn activés
11:00:36 #3 Text 0 File Reader.cpp, Line 127
Reader running
11:00:36 #4 Text 0 File Writer.cpp, Line 122
Writer SONY DVD RW DRU-810A running
11:00:36 #5 ISO9660GEN -11 File geniso.cpp, Line 3293
First writeable address = 0 (0x00000000)
11:00:36 #6 Text 0 File Burncd.cpp, Line 3153
Turn on Track-At-Once, using CD-R/RW media
11:00:36 #7 Text 0 File DlgWaitCD.cpp, Line 260
Last possible write address on media: 359845 ( 79:59.70)
Last address to be written: 125898 ( 28:00.48)
11:00:36 #8 Text 0 File DlgWaitCD.cpp, Line 272
Write in overburning mode: NO (enabled: CD)
11:00:36 #9 Text 0 File DlgWaitCD.cpp, Line 2339
Recorder: SONY DVD RW DRU-810A;
CDR code: 00 97 26 66; OSJ entry from: CMC Magnetics Corporation
ATIP Data:
Special Info [hex] 1: D0 00 98, 2: 61 1A 42 (LI 97:26.66), 3: 4F 3B 47 (LO 79:59.71)
Additional Info [hex] 1: 00 00 00 (invalid), 2: 00 00 00 (invalid), 3: 00 00 00 (invalid)
11:00:36 #10 Text 0 File DlgWaitCD.cpp, Line 438
>>> Protocol of DlgWaitCD activities: <<<
11:00:36 #11 Text 0 File ThreadedTransferInterface.cpp, Line 830
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 125899 (125899) = #125899/27:58.49
relocatable, disc pos for caching/writing not required/ required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 125897 blocks [SONY DVD RW DRU-810A]
11:00:36 #12 Text 0 File ThreadedTransferInterface.cpp, Line 1043
Prepare recorder [SONY DVD RW DRU-810A] for write in TAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc not fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 307200 258148352, ISRC ""
DAO layout:
Start|Track|Idx|CtrlAdr|RecDep_____
-150 | lead-in | 0 | 0x41 | 0x00
-150 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
125899 | lead-out | 1 | 0x41 | 0x00
11:00:36 #13 Text 0 File ThreadedTransferInterface.cpp, Line 1111
Removed 2 run-out blocks from end of track 1. Length: 125899 -> 125897.
11:00:36 #14 Phase 24 File dlgbrnst.cpp, Line 1832
Caching of files started
11:00:36 #15 Text 0 File Burncd.cpp, Line 4037
Cache writing successful.
11:00:36 #16 Phase 25 File dlgbrnst.cpp, Line 1832
Caching of files completed
11:00:36 #17 Phase 36 File dlgbrnst.cpp, Line 1832
Burn process started at 40x (6 000 Ko/s)
11:00:36 #18 Text 0 File ThreadedTransferInterface.cpp, Line 2609
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
11:00:36 #19 Text 0 File Mmc.cpp, Line 21359
Set BUFE: Power-Burn -> ON
11:00:45 #20 SCSI -1015 File Cdrdrv.cpp, Line 1436
SCSI Exec, HA 4, TA 0, LUN 0, buffer 0x0C4D0000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x73
Sense Qual: 0x02
CDB Data: 0x2A 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x03 0x00 0x00 0x00 0x00 0x12
0x00 0x00 0x00 0x00 0x73 0x02
11:00:45 #21 CDR -1015 File Writer.cpp, Line 311
Calibration area full
11:00:45 #22 Text 0 File ThreadedTransfer.cpp, Line 228
all writers idle, stopping conversion
11:00:45 #23 Text 0 File ThreadedTransfer.cpp, Line 222
conversion idle, stopping reader
11:00:45 #24 CDR -201 File WriterStatus.cpp, Line 200
Invalid write state
SONY DVD RW DRU-810A\H4 T0
11:00:45 #25 TRANSFER -18 File WriterStatus.cpp, Line 200
Could not perform EndTrack
11:00:45 #26 Text 0 File Mmc.cpp, Line 16009
<SONY DVD RW DRU-810A > start Close Session
11:00:45 #27 Phase 38 File dlgbrnst.cpp, Line 1832
Burn process failed at 40x (6 000 Ko/s)
Existing drivers:
File ‹ Drivers\PXHELP20.SYS ›: Ver=2.03.28a, size=20640 bytes, created 31/05/2005 23:36:01 (Prassi/Veritas driver for win 2K)
File ‹ Drivers\atapi.sys ›: Ver=5.1.2600.2180 (xpsp_sp2_rtm.040803-2158), size=95360 bytes, created 04/08/2004 05:59:44 (Adapter driver for rec)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
