Probleme Gravure DVD Nec ND- 2500A?
Salut tout le monde , voila je viens juste de prendre un graveur DVD nec ND-2500A jusque la pas de probleme pour graver un cd par contre pour graver un DVD impossible avec alcohol 120% , Nero Burning ou CDRWIN des que je clique graver ou simuler ça commence et puis quelque instant plus tard direct , gravure echouée etc…;j’aimerais bien savoir pourquoi , j’arrive pas a graver
voici mes txt:
j’ai un message apres la gravure échouée sur alcohol 120%:
une erreur est survenue durant la procedure de gravure!
veuillez consultez le registre et rapporter les erreurs au support technique
################## Detailed Information of Device(s) ##################
(E:) JLMS DVD-ROM LTD-166S(3:0) detail information.
Vendor Identification: JLMS
Product Identification: DVD-ROM LTD-166S
Production Revision Level: DS0B
-* Note: This information below is provided by the unit, it might be inaccurate. -
This software does not use this information! *-
Removable media: Yes
Version: ATAPI (INF-8090i/INF-8020i/INF-8028i)
Response Data Format: 01h
CD-R Read/Write: Yes/No
CD-RW Read/Write: Yes/No
Read CD-R Fixed Packet: Yes
Test Write: No
DVD-ROM Read: Yes
DVD-R Read/Write: Yes/No
DVD-RAM Read/Write: Yes/No
Audio Play: Yes
Composite Audio and Video Data Stream: Yes
Digital output (IEC958) on port 1 Supported: Yes
Digital output (IEC958) on port 2 Supported: No
Mode 1 Form 2: Yes
Mode 2 Form 2: Yes
Multi-Session: Yes
BUF: No
CD-DA Commands supported: Yes
CD-DA Stream is Accurate: Yes
R-W Supported: Yes
R-W De-interleaved and Corrected: No
C2 Pointers Support: Yes
ISRC Supported: Yes
UPC Supported: Yes
Read Bar Code: No
Lock media into the drive: Yes
Currently drive Lock state: Unlocked
Prevent Jumper: No
Eject Command: Yes
Separate volume levels: Yes
Separate channel mute: Yes
Changer Supports Disc Present: No
Software slot selection: No
Side change capable: No
P through W in Lead-In: Yes
Maximum Read Speed Supported (with current disc): 48X (7200 Ko/Sec)
Current Read Speed Supported (with current Disc): 48X (7200 Ko/Sec)
(F:) _NEC DVD_RW ND-2500A(3:1) detail information.
Vendor Identification: _NEC
Product Identification: DVD_RW ND-2500A
Production Revision Level: 1.06
Support recording method: DAO, RAW SAO, RAW SAO+SUB, RAW DAO(96), DVD DAO
BURN-Free Technology: Not Supported
Auto-Select best write speed: Not Supported
Response Data Format: 02h
CD-R Read/Write: Yes/Yes
CD-RW Read/Write: Yes/Yes
Test Write: Yes
DVD-ROM Read: Yes
DVD-R Read/Write: Yes/Yes
DVD-RAM Read/Write: No/No
Audio Play: Yes
Composite Audio and Video Data Stream: No
Digital output (IEC958) on port 1 Supported: No
Mode 1 Form 2: Yes
Mode 2 Form 2: Yes
Multi-Session: Yes
BUF: Yes
R-W Supported: Yes
ISRC Supported: Yes
UPC Supported: Yes
Read Bar Code: No
Prevent Jumper: No
Eject Command: Yes
Maximum Read Speed Supported (with current disc): 40X (6000 Ko/Sec)
Maximum Write Speed Supported (with current Disc): 32X (4800 Ko/Sec)
Current Read Speed Supported (with current Disc): 40X (6000 Ko/Sec)
Current Write Speed Supported (with current Disc): 32X (4800 Ko/Sec)
###################### Source Disc/Image Information ######################
Type: Fichier image Nero
Chemin: G:\Incoming
Nom: Final Fantasy X 2.nrg
Taille: 3887.20 MB
Session : 1
Piste : 1
Session 01:
Piste 01: DVD, Nombre de secteurs: 1990096(3.79 GB), Adresse: 000000
####################### Dumping/Recording Progress Log #######################
01:53:42 Infos processeur : Intel(R) Pentium(R) 4 CPU 2.66GHz (2665MHz)
01:53:42 Mémoire disponible pour Windows :1 047 280 KB
01:53:42 Taille de la mémoire tampon : 128 MB
01:53:42 Lecture du fichier image: G:\Incoming\Final Fantasy X 2.nrg
01:53:42 DVD Source Info : Session: 1, Piste: 1, Nombre de secteurs: 3.79 GB / 442:14:46
01:53:42 (F:) _NEC DVD_RW ND-2500A(3:1): Méthode d’écriture / Vitesse
01:53:42 Simulation d’écriture - DVD DAO - 4.0X (5520 Ko/Sec)
01:54:20 (F:) _NEC DVD_RW ND-2500A(3:1) - [Write ERROR] LBA: 0, Length: 16
S:KEY - 03/73/04 - « Program Memory Area/RMA Update Failure »
01:54:20 (F:) _NEC DVD_RW ND-2500A(3:1): Gravure échouée !
01:54:20 Message d’erreur [03/73/04] - Program Memory Area/RMA Update Failure
01:54:20 (F:) _NEC DVD_RW ND-2500A(3:1): Simulation d’écriture échouée !
01:54:20 Lecture du fichier image annulée !
01:54:22 Une erreur est survenue durant la procédure de gravure!
Veuillez consulter le registre et rapporter les erreurs au support technique.
apres quand je clique rapport ou je sais plus trop quoi , c’est marqué ceci:
Calling Mapisendmail() function failed one or more unspecified errors occurred no message was sent
Sur Ahead Nero Burning , voici mon txt:
Greg
Microse Corporation
1A23-3123-4037-4047-5520-3523
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File ‹ C:\Program Files\Ahead\Nero\Wnaspi32.dll ›: Ver=2.0.1.59, size=160016 bytes, created 16/12/2003 19:18:06
Version de Nero : 6.3.0.3
Graveur : <_NEC DVD_RW ND-2500A> Version: 1.06 - HA 3 TA 1 - 6.3.0.3
Pilote d’adaptateur : HA 3
Drive buffer : 2048kB
Bus Type : default (0) → ATAPI, detected: ATAPI
CD-ROM : Version: DS0B - HA 3 TA 0 - 6.3.0.3
=== Scsi-Device-Map ===
DiskPeripheral : ExcelStor Technology J240 atapi Port 0 ID 0 DMA: On
DiskPeripheral : Maxtor 6Y060L0 atapi Port 0 ID 1 DMA: On
DiskPeripheral : Maxtor 6Y080M0 atapi Port 2 ID 0 DMA: On
CdRomPeripheral : JLMS DVD-ROM LTD-166S atapi Port 3 ID 0 DMA: On
CdRomPeripheral : _NEC DVD_RW ND-2500A atapi Port 3 ID 1 DMA: On
CdRomPeripheral : AXV CD/DVD-ROM 2.2a xmasscsi Port 4 ID 0 DMA: Off
=== CDRom-Device-Map ===
JLMS DVD-ROM LTD-166S E: CDRom0
_NEC DVD_RW ND-2500A F: CDRom1
AXV CD/DVD-ROM K: CDRom2
AutoRun : 1
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 83886080 (0) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 1022MB (1047280kB)
Free physical memory: 688MB (705272kB)
Memory in use : 32 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
18.3.2004
Graver une image DVD
01:59:42 #1 Text 0 File Reader.cpp, Line 118
Reader running
01:59:42 #2 Text 0 File Writer.cpp, Line 124
Writer _NEC DVD_RW ND-2500A running
01:59:42 #3 IMAGEGEN -10 File ImageGen.cpp, Line 366
Image was written as DAO.
DAOI:
MediaCatalogNumber = ‹  ›
TocType = 0x00
Finalized = 1
First/Last Track = 1 / 1
1: ISRC = ‹  ›
Blocksize = 2048
TrackMode = ‹ TRM_DATA_MODE1 ›
TrackConfig = 0x00
First/Last Index = 0 / 1
Index0FilePos = 0, Index1FilePos = 307200, NextTrackFilePos = -218943488
CUES:
0: Ctrl=0x41 Trk= 0 (0x00) Index=00 RecDep=0x00 Start=954437:08.46 ( -150)
1: Ctrl=0x41 Trk= 1 (0x01) Index=00 RecDep=0x00 Start=954437:08.46 ( -150)
2: Ctrl=0x41 Trk= 1 (0x01) Index=01 RecDep=0x00 Start=00:00.00 ( 0)
3: Ctrl=0x41 Trk=110 (0xAA) Index=01 RecDep=0x00 Start=442:14.46 ( 1990096)
MTYP: Mediumtype = DVD (old format) (0x1C)
Image file name: <G:\Incoming\Final Fantasy X 2.nrg>
01:59:42 #4 Text 0 File Burncd.cpp, Line 3101
Turn on Disque entier, using DVD media
01:59:42 #5 Text 0 File DlgWaitCD.cpp, Line 240
Last possible write address on media: 2298495 (510:46.45, 4489MB)
Last address to be written: 1990095 (442:14.45, 3886MB)
01:59:42 #6 Text 0 File DlgWaitCD.cpp, Line 245
Write in overburning mode: FALSE
01:59:42 #7 Text 0 File DlgWaitCD.cpp, Line 2085
Recorder: _NEC DVD_RW ND-2500A, Media type: DVD-R
Disc Manufacturer: AN31 -
Disc Application Code: 64, Disc Physical Code: 193
01:59:42 #8 Text 0 File DlgWaitCD.cpp, Line 406
>>> Protocol of DlgWaitCD activities: <<<
01:59:42 #9 Text 0 File ThreadedTransferInterface.cpp, Line 779
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 (1 - DVD-ROM)
2 indices, index0 (150) provided
original disc pos #0 + 1990096 (1990096) = #1990096/442:14.46
not relocatable, disc pos for caching/writing not required/not required, no patch infos
→ TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 1990096 blocks [_NEC DVD_RW ND-2500A ]
01:59:42 #10 Text 0 File ThreadedTransferInterface.cpp, Line 948
Prepare recorder [_NEC DVD_RW ND-2500A ] for write in CUE-sheet-DAO
DAO infos:
MCN: «  »
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4075716608, ISRC «  »
DAO layout:
_Start|___Track|Idx|RecDep|CtrlAdr
0 | lead-in | 0 | 0x00 | 0x41
0 | 1 | 0 | 0x00 | 0x41
0 | 1 | 1 | 0x00 | 0x41
1990096 | lead-out | 1 | 0x00 | 0x41
01:59:42 #11 Phase 24 File dlgbrnst.cpp, Line 1800
Début de mise en cache des fichiers
01:59:42 #12 Text 0 File Burncd.cpp, Line 4073
Cache writing successful.
01:59:42 #13 Phase 25 File dlgbrnst.cpp, Line 1800
Cache des fichiers terminé
01:59:42 #14 Phase 32 File dlgbrnst.cpp, Line 1800
Début de simulation à 4x (5 520 Ko/s)
01:59:42 #15 Text 0 File ThreadedTransferInterface.cpp, Line 2264
Verifying disc position of item 0 (not relocatable, no disc pos, no patch infos, orig at #0): write at #0
01:59:42 #16 Text 0 File dlgbrnst.cpp, Line 1658
Set remaining time: 12:23,408 (743408ms) → OK
01:59:42 #17 Text 0 File DVDR.cpp, Line 1512
Recording mode: Sequential Recording Mode
01:59:42 #18 Text 0 File Mmc.cpp, Line 19487
Set BUFE: JustLink → ON
01:59:42 #19 Text 0 File DVDR.cpp, Line 1643
Start write address at LBA 0
DVD high compatibility mode: Yes
01:59:42 #20 Text 0 File Cdrdrv.cpp, Line 7941
---- DVD Structure: Physical Format Information (00h) ----
Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-R (2), Part Version: 5
Disc Size: 120 mm, Maximum Rate: (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 26127F h
End Sector Number in Layer 0: 0 h
Data in Burst Cutting Area (BCA) does not exist
Media Specific:
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 …
02 FE 10 00 02 FF A0 00 - 00 00 00 00 00 00 00 00 …
01:59:42 #21 Text 0 File Cdrdrv.cpp, Line 1277
01:59:42.812 - _NEC DVD_RW ND-2500A\H3 T1 : Queue again later
02:00:19 #22 SCSI -1194 File Cdrdrv.cpp, Line 1431
SCSI Exec, HA 3, TA 1, LUN 0, buffer 0x05D10000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x73
Sense Qual: 0x04
CDB Data: 0x2A 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x03 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x73 0x04
02:00:19 #23 CDR -1194 File Writer.cpp, Line 301
Echec de la mise à jour PMA
02:00:19 #24 Text 0 File ThreadedTransfer.cpp, Line 229
all writers idle, stopping conversion
02:00:20 #25 Text 0 File ThreadedTransfer.cpp, Line 223
conversion idle, stopping reader
02:00:20 #26 Text 0 File DVDR.cpp, Line 1847
EndDAO: Last written address was -1
02:00:20 #27 Text 0 File dlgbrnst.cpp, Line 1658
Set remaining time: 0:00,000 (0ms) → OK
02:00:20 #28 Text 0 File dlgbrnst.cpp, Line 1658
02:00:20 #29 Phase 34 File dlgbrnst.cpp, Line 1800
La simulation a échoué à 4x (5 520 Ko/s)
Existing drivers:
File ‹ Drivers\atapi.sys ›: Ver=5.1.2600.1106 (xpsp1.020828-1920), size=86912 bytes, created 29/08/2002 01:27:50 (Adapter driver for rec)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
et pour finir sur CDRWIN 5:
Erreur lors de l’utilisation du tampon de sortie
NED DVD_RW ND 2500A (F: BUS 0,ID 1): (CDB: 2a000000000000001000, Status: 040002, Sense 037304)
Erreur de mise a jour de l’opc ou du pma
j’espere que vous allez pouvoir m’aider , je suis sous Windows XP PRO SP1
Bienvenue au club !
[:acid-xp]
Je débute en gravure de DVD avec un NEC 1300A, et comme beaucoup de personnes je rencontre des tas de problèmes.
Je me suis informé sur les forums et j’ai retenu ceci :
  1. Mettre à jour le firmware de son graveur sur le site du constructeur ;
  2. Ne pas utiliser de DVD vierges à bas prix du type Princo et compagnie ;
  3. Préférer les marques Verbatim (MCC) et Ritek (G04) ;
  4. La marque NEC n’est pas le meilleur choix pour un graveur ; [:altharion]
  5. Lire les avis des forumeurs sur les différentes marques de DVD vierges du commerce.
    J’espère que ça pourra t’aider à résoudre ton problème, car dans ce domaine on se retrouve vite un peu seul …
moi j’ai un nec 2500 et j’ai deja graver des princo sans pb avec firmware d origine et nero !!!
mais apparement c’est vrai que les princo c’est de la daube a long terme !!!
voila quelques liens qui peuvent vous etre utile:
http://forum.hardware.fr/hardwarefr/Hardware/sujet-592637-1.htm
http://forum.hardware.fr/hardwarefr/Hardware/sujet-602347-1.htm
http://forum.hardware.fr/hardwarefr/Hardware/sujet-579886-1.htm
j’ai remarquer quelque chose de bizarre quand je vais dans poste de travail et qu’il ya rien dedans ça marque Lecteru DVD-RW par contre je met un dvd vierge ça marque Lecteur CD , j’y comprend rien
en reponse a galaxia
moi aussi j ai le meme souci…HELP
Moi j’ai jamais eu de problème avec mon Nec-2500 avec n’importe quelle marque de dvd (princo, emtec, et même nonames).
J’utilise Nero 6 et Windows 2000.
Tu es sur que ton fichier image n’est pas corrompu ? Tu arrive a le lire avec Daemon Tools, tu as esssayer de graver un autre fichier image ??
Je n arrive pas a mettre le firmware a jour, il me dis flashing errror ou un truc du style HELP HELP
ca commence a devenir urgent
salut,
essai quand même avec la dernière version de Néro si tu peux te la procurer, j’ai un pote qui a eu ce genre de problème et pour qui l’instal de cette version lui a été salutaire.
Des fois faut pas chercher à comprendre.
c koi la derniere version de nero??? et ou pusi je l avoir?
merci
mème galére pour moi,et avec des dvd verbatine aussi.Je me douté un peu que j’aurais eu des soucis vue les nombre de post concidérable sur les forums donc,pour ce genre de motos pas de commande sur le net,en se moment il est en sav chez le revendeur à coté de chez moi :wink:
