Je viens de faire le test avec HWMonitor et je pense que les températures sont stables, a vous de me dire si vous voyez quelque chose d’anormal,
CPUID HWMonitor Report
Binaries
HWMonitor version 1.3.0.0
Monitoring
Mainboard Model Z97-E (0x0000013C - 0x0002D4D0)
LPCIO
LPCIO Vendor Nuvoton
LPCIO Model NCT6791
LPCIO Vendor ID 0x5CA3
LPCIO Chip ID 0xC8
LPCIO Revision ID 0x3
Config Mode I/O address 0x2E
Config Mode LDN 0xB
Config Mode registers
00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
00 FF FF 00 FF FF FF FF 0B FF FF FF FF FF FF FF FF
10 FF FF FF FF FF FF FF FF FF FF 00 70 10 00 FF FF
20 C8 03 FF 00 00 00 00 00 10 FF 00 00 00 00 00 01
30 01 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
40 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
50 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
60 02 90 00 00 0A 00 FF FF FF FF FF FF FF FF FF FF
70 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Register space LPC, base address = 0x0290
Register space PMIO, base address = 0x0A00
Hardware Monitors
Hardware monitor Nuvoton NCT6791D
Voltage 0 5.08 Volts [0x7F] (+5V)
Voltage 1 3.30 Volts [0xCE] (+3.3V)
Voltage 2 12.29 Volts [0x80] (+12V)
Voltage 3 0.14 Volts [0x12] (VIN3)
Voltage 4 0.29 Volts [0x12] (VIN4)
Voltage 5 1.79 Volts [0x70] (VCORE)
Temperature 0 113 degC (235 degF) [0x71] (Mainboard)
Temperature 1 30 degC (86 degF) [0x1E] (CPU)
Fan 1 1077 RPM [0x435] (CPU)
Fan 2 4530 RPM [0x11B2] (Chassis #2)
Fan 3 15340 RPM [0x3BEC] (Chassis #4)
00 70 7F CE CE 80 15 81 CF CD 7F 15 12 11 11 12 00
10 71 1C 18 6A 69 69 00 35 C0 1C 1C 1C 1E 18 18 3F
20 71 02 99 47 FF 99 00 00 00 00 00 00 00 00 FF 1F
30 27 1F 09 1F 02 1F FF 1F FF 1F 00 00 04 35 11 B2
40 3B EC 00 00 00 00 00 00 00 00 00 00 99 49 FF 99
50 FF FF 1E 80 00 00 00 00 00 00 00 00 00 00 00 00
60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
70 00 1C 00 FE 00 FF FF FF FF FF FF FF FF FF FF FF
80 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
90 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Hardware monitor ACPI
Temperature 0 28 degC (82 degF) [0xBC2] (TZ00)
Temperature 1 30 degC (85 degF) [0xBD6] (TZ01)
Hardware monitor NVIDIA NVAPI
Voltage 0 0.86 Volts [0x35E] (VIN0)
Power 0 11.84 pc (GPU)
Temperature 0 43 degC (109 degF) [0x2B] (TMPIN0)
Fan 0 0 RPM [0x0] (FANIN0)
Fan PWM 0 0 pc [0x0] (FANPWMIN0)
Clock Speed 0 135.00 MHz [0x87] (Graphics)
Clock Speed 1 324.00 MHz [0x87] (Memory)
Processors
Number of processors 1
Number of threads 8
APICs
Processor 0
– Core 0
– Thread 0 0
– Thread 1 1
– Core 1
– Thread 0 2
– Thread 1 3
– Core 2
– Thread 0 4
– Thread 1 5
– Core 3
– Thread 0 6
– Thread 1 7
Timers
Perf timer 3.906 MHz
Sys timer 1.000 KHz
Processors Information
Processor 1 ID = 0
Number of cores 4 (max 4)
Number of threads 8 (max 8)
Name Intel Core i7 4790K
Codename Haswell
Specification Intel(R) Core™ i7-4790K CPU @ 4.00GHz
Package (platform ID) Socket 1150 LGA (0x1)
CPUID 6.C.3
Extended CPUID 6.3C
Core Stepping C0
Technology 22 nm
TDP Limit 88.0 Watts
Tjmax 100.0 °C
Core Speed 4399.9 MHz
Multiplier x Bus Speed 44.0 x 100.0 MHz
Stock frequency 4000 MHz
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX, AVX2, FMA3, TSX
L1 Data cache 4 x 32 KBytes, 8-way set associative, 64-byte line size
L1 Instruction cache 4 x 32 KBytes, 8-way set associative, 64-byte line size
L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size
L3 cache 8 MBytes, 16-way set associative, 64-byte line size
FID/VID Control yes
Turbo Mode supported, enabled
Max non-turbo ratio 40x
Max turbo ratio 44x
Max efficiency ratio 8x
O/C bins unlimited
Ratio 1 core 44x
Ratio 2 cores 44x
Ratio 3 cores 43x
Ratio 4 cores 42x
TSC 3999.0 MHz
APERF 944482624.0 MHz
MPERF 3936.0 MHz
IA Voltage Mode PCU adaptive
IA Voltage Offset 0 mV
GT Voltage Mode PCU adaptive
GT Voltage Offset 0 mV
LLC/Ring Voltage Mode PCU adaptive
LLC/Ring Voltage Offset 0 mV
Agent Voltage Mode PCU adaptive
Agent Voltage Offset 0 mV
Temperature 0 26 degC (78 degF) (Core #0)
Temperature 1 30 degC (86 degF) (Core #1)
Temperature 2 28 degC (82 degF) (Core #2)
Temperature 3 30 degC (86 degF) (Core #3)
Temperature 4 30 degC (86 degF) (Package)
Voltage 0 1.29 Volts (VID)
Voltage 1 +0.00 Volts (IA Offset)
Voltage 2 +0.00 Volts (GT Offset)
Voltage 3 +0.00 Volts (LLC/Ring Offset)
Voltage 4 +0.00 Volts (System Agent Offset)
Power 0 21.54 W (Package)
Power 1 11.48 W (IA Cores)
Power 2 n.a. (GT)
Power 3 10.05 W (Uncore)
Power 4 3.89 W (DRAM)
Clock Speed 0 4399.95 MHz (Core #0)
Clock Speed 1 4199.95 MHz (Core #1)
Clock Speed 2 4299.95 MHz (Core #2)
Clock Speed 3 4399.95 MHz (Core #3)
Thread dumps
CPU Thread 0
APIC ID 0
Topology Processor ID 0, Core ID 0, Thread ID 0
Type 01020201h
Max CPUID level 0000000Dh
Max CPUID ext. level 80000008h
Cache descriptor Level 1, D, 32 KB, 2 thread(s)
Cache descriptor Level 1, I, 32 KB, 2 thread(s)
Cache descriptor Level 2, U, 256 KB, 2 thread(s)
Cache descriptor Level 3, U, 8 MB, 16 thread(s)
CPUID
0x00000000 0x0000000D 0x756E6547 0x6C65746E 0x49656E69
0x00000001 0x000306C3 0x06100800 0x7FFAFBBF 0xBFEBFBFF
0x00000002 0x76036301 0x00F0B5FF 0x00000000 0x00C10000
0x00000003 0x00000000 0x00000000 0x00000000 0x00000000
0x00000004 0x1C004121 0x01C0003F 0x0000003F 0x00000000
0x00000004 0x1C004122 0x01C0003F 0x0000003F 0x00000000
0x00000004 0x1C004143 0x01C0003F 0x000001FF 0x00000000
0x00000004 0x1C03C163 0x03C0003F 0x00001FFF 0x00000006
0x00000005 0x00000040 0x00000040 0x00000003 0x00042120
0x00000006 0x00000077 0x00000002 0x00000009 0x00000000
0x00000007 0x00000000 0x00002FBB 0x00000000 0x00000000
0x00000008 0x00000000 0x00000000 0x00000000 0x00000000
0x00000009 0x00000000 0x00000000 0x00000000 0x00000000
0x0000000A 0x07300403 0x00000000 0x00000000 0x00000603
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000006
0x0000000B 0x00000004 0x00000008 0x00000201 0x00000006
0x0000000C 0x00000000 0x00000000 0x00000000 0x00000000
0x0000000D 0x00000007 0x00000340 0x00000340 0x00000000
0x80000000 0x80000008 0x00000000 0x00000000 0x00000000
0x80000001 0x00000000 0x00000000 0x00000021 0x2C100800
0x80000002 0x65746E49 0x2952286C 0x726F4320 0x4D542865
0x80000003 0x37692029 0x3937342D 0x43204B30 0x40205550
0x80000004 0x302E3420 0x7A484730 0x00000000 0x00000000
0x80000005 0x00000000 0x00000000 0x00000000 0x00000000
0x80000006 0x00000000 0x00000000 0x01006040 0x00000000
0x80000007 0x00000000 0x00000000 0x00000000 0x00000100
0x80000008 0x00003027 0x00000000 0x00000000 0x00000000
MSR 0x0000001B 0x00000000 0xFEE00900
MSR 0x0000003A 0x00000000 0x00000005
MSR 0x000001A0 0x00000000 0x00850089
MSR 0x000000CE 0x00080838 0xF3012800
MSR 0x00000017 0x00040000 0x00000000
MSR 0x00000035 0x00000000 0x00040008
MSR 0x000000C1 0x00000000 0x00000000
MSR 0x000000C2 0x00000000 0x00000000
MSR 0x000000C3 0x00000000 0x00000000
MSR 0x000000C4 0x00000000 0x00000000
MSR 0x00000186 0x00000000 0x00000000
MSR 0x00000187 0x00000000 0x00000000
MSR 0x000001AD 0x00000000 0x2A2B2C2C
MSR 0x00000194 0x00000000 0x000F0000
MSR 0x0000019A 0x00000000 0x00000000
MSR 0x000001A4 0x00000000 0x00000000
MSR 0x000001B1 0x00000000 0x88460800
MSR 0x000001FC 0x00000000 0x0004005F
MSR 0x00000606 0x00000000 0x000A0E03
MSR 0x00000601 0x00101414 0x00001FFF
MSR 0x00000610 0x0042FFF8 0x001AFFF8
MSR 0x00000611 0x00000000 0xF67F14B3
MSR 0x00000639 0x00000000 0x5F806B9F
MSR 0x00000641 0x00000000 0x00000000
MSR 0x00000619 0x00000000 0x30785660
MSR 0x00000614 0x00000000 0x000002C0
MSR 0x0000019C 0x00000000 0x884A0000
MSR 0x000001A2 0x00000000 0x00641400
MSR 0x00000198 0x000025E7 0x00002A00
MSR 0x00000199 0x00000000 0x0000FF00
Storage
Drive 0
Device Path ?scsi#disk&ven_ct250bx1&prod_00ssd1#4&268c595a&0&000000#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}
Type Fixed
Name CT250BX1 00SSD1
Capacity 232.9 GB
SMART Support Yes
Volume c:, 232.7 GBytes (77.7 percent available)
Drive 1
Device Path ?scsi#disk&ven_st2000dm&prod_001-1er164#4&268c595a&0&010000#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}
Type Fixed
Name ST2000DM 001-1ER164
Capacity 1863.0 GB
SMART Support Yes
Volume d:, 1863.0 GBytes (97.6 percent available)
USB Devices
USB Device Generic USB Hub, class=0x09, subclass=0x00, vendor=0x8087, product=0x8009
USB Device Generic USB Hub, class=0x09, subclass=0x00, vendor=0x8087, product=0x8001
USB Device Périphérique USB composite, class=0x00, subclass=0x00, vendor=0x1B1C, product=0x1B33
USB Device Périphérique USB composite, class=0x00, subclass=0x00, vendor=0x1395, product=0x1000
USB Device Périphérique d?entrée USB, class=0x00, subclass=0x00, vendor=0x1AF3, product=0x0001
Graphic APIs
API NVIDIA I/O
API NVIDIA NVAPI
Display Adapters
Display adapter 0
Name NVIDIA GeForce GTX 970
Board Manufacturer ASUSTeK Computer Inc.
Revision A1
Codename GM204
Technology 28 nm
Memory size 4 GB
Memory type GDDR5
PCI device bus 1 (0x1), device 0 (0x0), function 0 (0x0)
Vendor ID 0x10DE (0x1043)
Model ID 0x13C2 (0x8508)
Performance Level 0
Core clock 135.0 MHz
Memory clock 324.0 MHz
Monitor 0
Model BenQ XL2420T ()
ID BNQ7F04
Serial 63C00501SL0
Manufacturing Date Week 11, Year 2012
Size 24.0 inches
Max Resolution 1920 x 1080 @ 60 Hz
Horizontal Freq. Range 30-140 kHz
Vertical Freq. Range 56-120 Hz
Max Pixel Clock 330 MHz
Gamma Factor 2.2
Monitor 1
Model BenQ GL2250H ()
ID BNQ78A1
Serial 23E02350019
Manufacturing Date Week 9, Year 2014
Size 21.7 inches
Horizontal Freq. Range 30-83 kHz
Vertical Freq. Range 50-76 Hz
Max Pixel Clock 210 MHz
Gamma Factor 2.2
