mon graveur ne grave plus depuis que je formaté mon disc dur le message d’erreur est le suivant : impossibre d’executé endtrack, Fonction writestate invalide" voila le fichier log pour tous ceux qui peuvent m’aider, merci d’avance
MECHANT
ELHADE
1A20-020N-0132-2525-1258-0359*
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File ‹ C:\Program Files\Ahead\nero\Wnaspi32.dll ›: Ver=2.0.1.74, size=164112 bytes, created 27/10/2004 10:35:32
Nero Version: 6.6.0.15
Internal Version: 6, 6, 0, 15e
(Nero Express)
Recorder: <MATSHITA DVD-RAM UJ-831S>Version: 1.90 - HA 1 TA 0 - 6.6.0.15
Adapter driver: <atapi> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
CD-ROM: <MATSHITA DVD-RAM UJ-831S >Version: 1.90 - HA 1 TA 0 - 6.6.0.15
=== Scsi-Device-Map ===
DiskPeripheral : TOSHIBA MK8025GAS atapi Port 0 ID 0 DMA: On
CdRomPeripheral : MATSHITA DVD-RAM UJ-831S atapi Port 1 ID 0 DMA: On
CdRomPeripheral : Generic DVD-ROM 1.0 d344prt Port 2 ID 0 DMA: Off
=== CDRom-Device-Map ===
MATSHITA DVD-RAM UJ-831S D: CDRom0
Generic DVD-ROM G: CDRom1
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 74448896 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 510MB (522672kB)
Free physical memory: 146MB (149552kB)
Memory in use : 71
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
17.4.2007
CD vidéo
21:31:35 #1 Text 0 File VCDDoc.cpp, Line 1387
VideoCD document burn settings
Compilation type : VCD
Menu : Enable
Picture in separate folder : TRUE
Folder name :PICTURES
Use CD-I : TRUE
CD-I configuration : CONTROLS=ALL
CURCOL=YELLOW
PSDCURCOL=RED
PSDCURSHAPE=ARROW
CENTRTRACK=2
AUTOPLAY=AUTO_ON
DUALCHAN=DUAL_ON
TIMECODE_X=64
TIMECODE_Y=100
LOTID_X=64
LOTID_Y=64
ALBUM=STANDARD
Encoding bitrate mode : User defined (kb/s)
21:31:35 #2 Phase 82 File dlgbrnst.cpp, Line 1832
Encoding video
21:31:35 #3 Text 0 File VCDCompilationImpl.cpp, Line 514
Using Nero Video Converter version 0.00
21:31:36 #4 Text 0 File AVIVCDFileItem.cpp, Line 912
Encoding E:\Mes vidéos\Nouveau films\King Kong.avi to C:\DOCUME~1\MECHANT\LOCALS~1\Temp\NER22.tmp
ScalingType: 0 Video: yes Audio: yes
File size: 734124032 bytes
Resolution: 608x256 25 Hz
Frames: 277733
21:31:36 #5 Text 0 File AVIVCDFileItem.cpp, Line 925
Playing time: 11109,320000 s
Requested rate: 225 KB/s
iVideoRate=0
iAudioRate=32
Estimated size: 833199 blocks
21:34:58 #6 Phase 40 File dlgbrnst.cpp, Line 1519
Aborted by user
21:34:58 #7 Text 0 File AVIVCDFileItem.cpp, Line 990
Encoding done
21:34:58 #8 Text 0 File AVIVCDFileItem.cpp, Line 1054
Temporary file C:\DOCUME~1\MECHANT\LOCALS~1\Temp\NER22.tmp deleted
21:34:58 #9 Text 0 File VCDDoc.cpp, Line 2865
VCD options:
Create standard compliant CD: YES
Encoding resolution: PAL
Existing drivers:
File ‹ Drivers\atapi.sys ›: Ver=5.1.2600.1106 (xpsp1.020828-1920), size=86912 bytes, created 29/08/2002 11:17:04 (Adapter driver for rec)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
====== *** Nero-Burning Rom, History File *** ======
MECHANT
ELHADE
Windows XP 5.1
IA32
WinAspi: -
(Nero Express)
AutoRun : 1
Excluded drive IDs:
ShowDrvBufStat : 0
BUFE : 0
Free physical memory: 180MB (184620kB)
Memory in use : 64
Use Inquiry : 1
17.4.2007
CD vidéo
21:39:38 #1 Text 0 File VCDDoc.cpp, Line 1387
Menu : Enable
Use CD-I : TRUE
CURCOL=YELLOW
PSDCURCOL=RED
PSDCURSHAPE=ARROW
CENTRTRACK=2
AUTOPLAY=AUTO_ON
DUALCHAN=DUAL_ON
TIMECODE_X=64
TIMECODE_Y=100
LOTID_X=64
LOTID_Y=64
ALBUM=STANDARD
21:39:38 #2 Phase 82 File dlgbrnst.cpp, Line 1832
Encoding video
21:39:38 #3 Text 0 File VCDCompilationImpl.cpp, Line 514
21:39:39 #4 Text 0 File AVIVCDFileItem.cpp, Line 912
Encoding E:\Mes vidéos\the-marine.avi to C:\DOCUME~1\MECHANT\LOCALS~1\Temp\NER25.tmp
File size: 732686336 bytes
Resolution: 608x336 25 Hz
Frames: 137021
21:39:39 #5 Text 0 File AVIVCDFileItem.cpp, Line 925
Playing time: 5480,840000 s
iVideoRate=0
iAudioRate=32
Estimated size: 411063 blocks
22:05:59 #6 Text 0 File AVIVCDFileItem.cpp, Line 990
Encoding done
22:07:01 #7 Text 0 File VCDFileItem.cpp, Line 437
Actual size: 411085 blocks
22:07:01 #8 Text 0 File VCDFileItem.cpp, Line 441
The generated Video file is 0,999981 of the evaluated size
22:07:01 #9 Text 0 File Isodoc.cpp, Line 6314
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 2 / XA
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
22:07:01 #10 Text 0 File VCDDoc.cpp, Line 2865
VCD options:
22:07:01 #11 Text 0 File Burncd.cpp, Line 2946
Protection contre les ruptures activés
22:07:01 #12 Text 0 File Reader.cpp, Line 127
Reader running
22:07:01 #13 ISO9660GEN -11 File geniso.cpp, Line 3309
First writeable address = 0 (0x00000000)
22:07:01 #14 ISO9660GEN -11 File geniso.cpp, Line 3309
22:07:01 #15 Text 0 File Burncd.cpp, Line 3231
Turn on Disc-At-Once, using CD-R/RW media
22:07:29 #16 Phase 40 File dlgbrnst.cpp, Line 1832
Aborted by user
22:07:29 #17 Text 0 File DlgWaitCD.cpp, Line 267
Last possible write address on media: 359848 ( 79:59.73)
Last address to be written: 412639 ( 91:43.64)
22:07:29 #18 Text 0 File DlgWaitCD.cpp, Line 279
Write in overburning mode: NO (enabled: CD)
22:07:29 #19 Text 0 File DlgWaitCD.cpp, Line 2457
Recorder: MATSHITA DVD-RAM UJ-831S
Medium not present
22:07:29 #20 Text 0 File DlgWaitCD.cpp, Line 445
>>> Protocol of DlgWaitCD activities: <<<
Not enough free discspace.
(Medium in drive: CD-R. Medium required by compilation: CD-R/RW.)
22:07:29 #21 Text 0 File AVIVCDFileItem.cpp, Line 1054
Temporary file C:\DOCUME~1\MECHANT\LOCALS~1\Temp\NER25.tmp deleted
Existing drivers:
Registry Keys:
MECHANT
ELHADE
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File ‹ C:\Program Files\Ahead\Nero\Wnaspi32.dll ›: Ver=2.0.1.74, size=164112 bytes, created 27/10/2004 10:35:32
(Nero Express)
AutoRun : 1
Excluded drive IDs:
ShowDrvBufStat : 0
BUFE : 0
Free physical memory: 225MB (231304kB)
Memory in use : 55
Use Inquiry : 1
2.5.2007
CD vidéo
23:58:24 #1 Text 0 File VCDDoc.cpp, Line 1387
Menu : Enable
Use CD-I : TRUE
CURCOL=YELLOW
PSDCURCOL=RED
PSDCURSHAPE=ARROW
CENTRTRACK=2
AUTOPLAY=AUTO_ON
DUALCHAN=DUAL_ON
TIMECODE_X=64
TIMECODE_Y=100
LOTID_X=64
LOTID_Y=64
ALBUM=STANDARD
23:58:24 #2 Phase 82 File dlgbrnst.cpp, Line 1832
Encoding video
23:58:24 #3 Text 0 File VCDCompilationImpl.cpp, Line 514
23:58:25 #4 Text 0 File AVIVCDFileItem.cpp, Line 912
Encoding C:\Documents and Settings\MECHANT\Mes documents\Mes vidéos\Sans titre_20070501_1.MPG to C:\DOCUME~1\MECHANT\LOCALS~1\Temp\NERD2.tmp
File size: 129677316 bytes
Resolution: 352x288 25 Hz
Frames: 23552
23:58:25 #5 Text 0 File AVIVCDFileItem.cpp, Line 925
Playing time: 942,080000 s
iVideoRate=0
iAudioRate=32
Estimated size: 70656 blocks
00:01:35 #6 Text 0 File AVIVCDFileItem.cpp, Line 990
Encoding done
00:01:37 #7 Text 0 File VCDFileItem.cpp, Line 437
Actual size: 70684 blocks
00:01:37 #8 Text 0 File VCDFileItem.cpp, Line 441
The generated Video file is 0,999972 of the evaluated size
00:01:37 #9 Text 0 File Isodoc.cpp, Line 6314
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Burning mode : DAO
Mode : 2 / XA
Joliet : TRUE
00:01:37 #10 Text 0 File VCDDoc.cpp, Line 2865
VCD options:
00:01:37 #11 Text 0 File Burncd.cpp, Line 2946
00:01:37 #12 Text 0 File Reader.cpp, Line 127
Reader running
00:01:37 #13 Text 0 File Writer.cpp, Line 122
Writer MATSHITA DVD-RAM UJ-831S running
00:01:37 #14 ISO9660GEN -11 File geniso.cpp, Line 3309
00:01:37 #15 ISO9660GEN -11 File geniso.cpp, Line 3309
00:01:37 #16 Text 0 File Burncd.cpp, Line 3231
00:01:37 #17 Text 0 File DlgWaitCD.cpp, Line 267
Last possible write address on media: 359845 ( 79:59.70)
Last address to be written: 72227 ( 16:05.02)
00:01:37 #18 Text 0 File DlgWaitCD.cpp, Line 279
00:01:37 #19 Text 0 File DlgWaitCD.cpp, Line 2457
Recorder: MATSHITA DVD-RAM UJ-831S;
CDR code: 00 97 26 66; OSJ entry from: CMC Magnetics Corporation
ATIP Data:
Special Info [hex] 1: D0 00 98, 2: 61 1A 42 (LI 97:26.66), 3: 4F 3B 47 (LO 79:59.71)
Additional Info [hex] 1: 00 00 00 (invalid), 2: 00 00 00 (invalid), 3: 00 00 00 (invalid)
00:01:37 #20 Text 0 File DlgWaitCD.cpp, Line 445
00:01:37 #21 Text 0 File ThreadedTransferInterface.cpp, Line 830
Setup items (after recorder preparation)
0: TRM_DATA_MODE2_2336 ()
2 indices, index0 (150) not provided
original disc pos #0 + 1304 (1304) = #1304/0:17.29
relocatable, disc pos for caching/writing not required/ required, no patch infos
-> TRM_DATA_MODE2_2336, 2336, config 0, wanted index0 0 blocks, length 1304 blocks [MATSHITA DVD-RAM UJ-831S]
1: TRM_DATA_MODE2_2336 (Sans titre_20070501_1)
original disc pos #0 + 70774 (70774) = #70774/15:43.49
relocatable, disc pos for caching/writing not required/not required, no patch infos
-> TRM_DATA_MODE2_2336, 2336, config 0, wanted index0 0 blocks, length 70774 blocks [MATSHITA DVD-RAM UJ-831S]
00:01:37 #22 Text 0 File ThreadedTransferInterface.cpp, Line 1043
Prepare recorder [MATSHITA DVD-RAM UJ-831S] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x20; Session Closed, disc fixated
Tracks 1 to 2:
1: TRM_DATA_MODE2_2336, 2336/0x00, FilePos 0 350400 3396544, ISRC ""
2: TRM_DATA_MODE2_2336, 2336/0x00, FilePos 3396544 3746944 169075008, ISRC ""
DAO layout:
Start|Track|Idx|CtrlAdr|RecDep_____
-150 | lead-in | 0 | 0x41 | 0x00
-150 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
1304 | 2 | 0 | 0x41 | 0x00
1454 | 2 | 1 | 0x41 | 0x00
72228 | lead-out | 1 | 0x41 | 0x00
00:01:37 #23 Phase 73 File dlgbrnst.cpp, Line 1832
Preparing items
00:01:37 #24 Phase 24 File dlgbrnst.cpp, Line 1832
Caching of files started
00:01:38 #25 Text 0 File Burncd.cpp, Line 4116
Cache writing successful.
00:01:38 #26 Phase 25 File dlgbrnst.cpp, Line 1832
Caching of files completed
00:01:38 #27 Phase 36 File dlgbrnst.cpp, Line 1832
Burn process started at 24x (3 600 Ko/s)
00:01:38 #28 Text 0 File ThreadedTransferInterface.cpp, Line 2643
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
00:01:38 #29 Text 0 File ThreadedTransferInterface.cpp, Line 2643
Verifying disc position of item 1 (relocatable, no disc pos, no patch infos, orig at #0): write at #1454
00:01:38 #30 Text 0 File Mmc.cpp, Line 16847
StartDAO : CD-Text - Off
00:01:38 #31 Text 0 File Mmc.cpp, Line 21627
Set BUFE: Buffer underrun protection -> ON
00:01:38 #32 Text 0 File Mmc.cpp, Line 17134
CueData, Len=48
41 00 00 24 00 00 00 00
41 01 00 20 00 00 00 00
41 01 01 20 00 00 02 00
41 02 00 20 00 00 13 1d
41 02 01 20 00 00 15 1d
41 aa 01 24 00 10 05 03
00:01:38 #33 Text 0 File Cdrdrv.cpp, Line 1288
00:01:38.562 - MATSHITA DVD-RAM UJ-831S\H1 T0 : Queue again later
00:02:37 #34 SCSI -1135 File Cdrdrv.cpp, Line 1436
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x085C0000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x2A 0x00 0x00 0x00 0x42 0x46 0x00 0x00 0x1C 0x00 0x00 0x00
Sense Data: 0xF1 0x00 0x03 0x00 0x00 0x3F 0xDE 0x0A
0x00 0x2B 0x00 0x00 0x0C 0x00
00:02:37 #35 CDR -1135 File Writer.cpp, Line 311
Write error
00:02:38 #36 Text 0 File ThreadedTransfer.cpp, Line 228
all writers idle, stopping conversion
00:02:38 #37 Phase 38 File dlgbrnst.cpp, Line 1832
Burn process failed at 24x (3 600 Ko/s)
00:02:38 #38 Text 0 File AVIVCDFileItem.cpp, Line 1054
Temporary file C:\DOCUME~1\MECHANT\LOCALS~1\Temp\NERD2.tmp deleted
Existing drivers:
File ‹ Drivers\CDRALW2K.SYS ›: Ver=8.0.0.212 , size=2560 bytes, created 28/08/2006 21:48:26
File ‹ Drivers\PXHELP20.SYS ›: Ver=3.00.43J, size=36624 bytes, created 02/11/2006 16:57:04 (Prassi/Veritas driver for win 2K)
Registry Keys:
MECHANT
ELHADE
Windows XP 5.1
IA32
WinAspi: File ‹ Wnaspi32.dll ›: Ver=4.71 (0002), size=45056 bytes, created 21/11/2005 07:48:20
(Nero Express)
Recorder: < Image Recorder> Version: Pas disponible - HA -1 TA 0 - 6.6.0.15
Adapter driver: <Virtual Device> HA -1
Drive buffer :
AutoRun : 1
Excluded drive IDs:
ShowDrvBufStat : 0
BUFE : 0
Free physical memory: 199MB (204084kB)
Memory in use : 60
Use Inquiry : 1
13.5.2007
Compilation ISO
18:02:06 #1 Text 0 File Isodoc.cpp, Line 6314
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Burning mode : DAO
Mode : 1
Joliet : TRUE
18:02:06 #2 Text 0 File Reader.cpp, Line 127
Reader running
18:02:06 #3 Text 0 File Writer.cpp, Line 122
Writer Image Recorder running
18:02:06 #4 ISO9660GEN -11 File geniso.cpp, Line 3309
18:02:06 #5 Text 0 File Burncd.cpp, Line 3231
Turn on Disc-At-Once, using DVD media
18:02:07 #6 Text 0 File DlgWaitCD.cpp, Line 267
Last possible write address on media: 4718591 (1048:34.41, 9215MB)
Last address to be written: 1474975 (327:46.25, 2880MB)
18:02:07 #7 Text 0 File DlgWaitCD.cpp, Line 279
18:02:07 #8 Text 0 File DlgWaitCD.cpp, Line 2457
Recorder: Image Recorder;
CD type reading failed
ATIP Data: ?
18:02:07 #9 Text 0 File DlgWaitCD.cpp, Line 445
18:02:07 #10 Text 0 File ThreadedTransferInterface.cpp, Line 830
0: TRM_DATA_MODE1 ()
original disc pos #0 + 1474976 (1474976) = #1474976/327:46.26
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 1474976 blocks [Image Recorder]
18:02:15 #11 Text 0 File ThreadedTransferInterface.cpp, Line 1043
Prepare recorder [Image Recorder] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 3020750848, ISRC ""
DAO layout:
1474976 | lead-out | 1 | 0x41 | 0x00
18:02:15 #12 Phase 65 File dlgbrnst.cpp, Line 1832
18:02:15 #13 Text 0 File ThreadedTransferInterface.cpp, Line 2643
18:02:21 #14 TRANSFER -25 File Reader.cpp, Line 382
Error reading data
18:02:21 #15 Text 0 File Reader.cpp, Line 385
Exception value: -1
18:02:21 #16 Text 0 File ThreadedTransfer.cpp, Line 228
18:02:21 #17 Phase 67 File dlgbrnst.cpp, Line 1832
Burn process failed
Existing drivers:
File ‹ Drivers\ASPI32.SYS ›: Ver=4.71 (0002) built by: WinDDK, size=16512 bytes, created 21/11/2005 07:48:20
File ‹ Drivers\atapi.sys ›: Ver=5.1.2600.1106 (xpsp1.020828-1920), size=86912 bytes, created 29/08/2002 11:17:04 (Adapter driver for src)
Registry Keys:
MECHANT
ELHADE
Windows XP 5.1
IA32
(Nero Express)
Drive buffer :
AutoRun : 1
Excluded drive IDs:
ShowDrvBufStat : 0
BUFE : 0
Free physical memory: 202MB (207856kB)
Memory in use : 60
Use Inquiry : 1
13.5.2007
CD-ROM (ISO)
18:02:57 #1 Text 0 File Isodoc.cpp, Line 6314
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Burning mode : TAO
Mode : 1
Joliet : TRUE
18:02:57 #2 Text 0 File Reader.cpp, Line 127
Reader running
18:02:57 #3 ISO9660GEN -11 File geniso.cpp, Line 3309
18:02:57 #4 Text 0 File Burncd.cpp, Line 3231
Turn on Track-At-Once, using CD-R/RW media
18:03:07 #5 Phase 40 File dlgbrnst.cpp, Line 1832
Aborted by user
18:03:07 #6 Text 0 File DlgWaitCD.cpp, Line 267
Last possible write address on media: 445499 ( 99:01.74)
Last address to be written: 451536 (100:22.36)
18:03:07 #7 Text 0 File DlgWaitCD.cpp, Line 279
18:03:07 #8 Text 0 File DlgWaitCD.cpp, Line 2457
ATIP Data: ?
18:03:07 #9 Text 0 File DlgWaitCD.cpp, Line 445
(Medium in drive: DVD+R/RW; DVD-R/RW; DVD-RAM; DVD+R DL; CD-R/RW. Medium required by compilation: CD-R/RW.)
Existing drivers:
Registry Keys:
MECHANT
ELHADE
Windows XP 5.1
IA32
(Nero Express)
Drive buffer :
AutoRun : 1
Excluded drive IDs:
ShowDrvBufStat : 0
BUFE : 0
Free physical memory: 199MB (204304kB)
Memory in use : 60
Use Inquiry : 1
13.5.2007
Compilation ISO
18:03:29 #1 Text 0 File Isodoc.cpp, Line 6314
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Burning mode : DAO
Mode : 1
Joliet : TRUE
18:03:29 #2 Text 0 File Reader.cpp, Line 127
Reader running
18:03:29 #3 Text 0 File Writer.cpp, Line 122
18:03:29 #4 ISO9660GEN -11 File geniso.cpp, Line 3309
18:03:29 #5 Text 0 File Burncd.cpp, Line 3231
18:03:29 #6 Text 0 File DlgWaitCD.cpp, Line 267
Last address to be written: 451551 (100:20.51, 881MB)
18:03:29 #7 Text 0 File DlgWaitCD.cpp, Line 279
18:03:29 #8 Text 0 File DlgWaitCD.cpp, Line 2457
ATIP Data: ?
18:03:29 #9 Text 0 File DlgWaitCD.cpp, Line 445
18:03:29 #10 Text 0 File ThreadedTransferInterface.cpp, Line 830
original disc pos #0 + 451552 (451552) = #451552/100:20.52
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 451552 blocks [Image Recorder]
18:03:31 #11 Text 0 File ThreadedTransferInterface.cpp, Line 1043
DAO infos:
MCN: ""
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 924778496, ISRC ""
DAO layout:
451552 | lead-out | 1 | 0x41 | 0x00
18:03:31 #12 Phase 65 File dlgbrnst.cpp, Line 1832
18:03:31 #13 Text 0 File ThreadedTransferInterface.cpp, Line 2643
18:03:38 #14 TRANSFER -25 File Reader.cpp, Line 382
Error reading data
18:03:38 #15 Text 0 File Reader.cpp, Line 385
Exception value: -1
18:03:38 #16 Text 0 File ThreadedTransfer.cpp, Line 228
18:03:38 #17 Phase 67 File dlgbrnst.cpp, Line 1832
Burn process failed
Existing drivers:
Registry Keys:
MECHANT
ELHADE
Windows XP 5.1
IA32
WinAspi: -
(Nero Express)
CdRomPeripheral : Generic DVD-ROM 1.0 d344prt Port 2 ID 1 DMA: Off
Generic DVD-ROM F: CDRom2
AutoRun : 1
Excluded drive IDs:
ShowDrvBufStat : 0
BUFE : 0
Free physical memory: 220MB (225956kB)
Memory in use : 56
Use Inquiry : 1
19.5.2007
CD Audio
14:23:45 #1 CDADOC -1 File Cdadoc.cpp, Line 1465
Audio item log info:
Audio document burn settings:
Burn mode: DAO,
CD Text: On,
Cache disk or network files: No,
Cache small files: No,
Cache files smaller than 65536 bytes.
Audio Multisession: No
List of audio tracks:
Track 01: Length: 25:42.20, Pause frames: 150, Filters: 0, Name: ‹ 01 Piste 1.wma ›.
Track 02: Length: 34:29.09, Pause frames: 150, Filters: 0, Name: ‹ 02 Piste 2.wma ›.
Total size: 60:15.29
14:23:45 #2 Text 0 File Burncd.cpp, Line 2946
14:23:45 #3 Text 0 File Reader.cpp, Line 127
Reader running
14:23:45 #4 Text 0 File Writer.cpp, Line 122
14:23:45 #5 Text 0 File AudioCompilationImpl.cpp, Line 842
DRM: StartDrmRecording(RealRec:1, ImageRec:0, Copies:1)
DRM: Beginning burn process.
14:23:45 #6 Text 0 File Burncd.cpp, Line 3231
14:23:45 #7 Text 0 File DlgWaitCD.cpp, Line 267
Last address to be written: 271003 ( 60:15.28)
14:23:45 #8 Text 0 File DlgWaitCD.cpp, Line 279
14:23:45 #9 Text 0 File DlgWaitCD.cpp, Line 2457
ATIP Data:
14:23:45 #10 Text 0 File DlgWaitCD.cpp, Line 445
14:23:45 #11 Text 0 File ThreadedTransferInterface.cpp, Line 830
0: TRM_AUDIO_NOPRE (01 Piste 1.wma)
original disc pos #0 + 115670 (115670) = #115670/25:42.20
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 115670 blocks [MATSHITA DVD-RAM UJ-831S]
1: TRM_AUDIO_NOPRE (02 Piste 2.wma)
original disc pos #0 + 155184 (155184) = #155184/34:29.9
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 155184 blocks [MATSHITA DVD-RAM UJ-831S]
14:23:45 #12 Text 0 File ThreadedTransferInterface.cpp, Line 1043
DAO infos:
MCN: ""
Tracks 1 to 2:
1: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 0 352800 272408640, ISRC ""
2: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 272408640 272761440 637754208, ISRC ""
DAO layout:
-150 | lead-in | 0 | 0x01 | 0x00
-150 | 1 | 0 | 0x21 | 0x00
0 | 1 | 1 | 0x21 | 0x00
115670 | 2 | 0 | 0x21 | 0x00
115820 | 2 | 1 | 0x21 | 0x00
271004 | lead-out | 1 | 0x01 | 0x00
14:23:45 #13 Phase 36 File dlgbrnst.cpp, Line 1832
14:23:45 #14 Text 0 File ThreadedTransferInterface.cpp, Line 2643
Verifying disc position of item 0 (relocatable, no disc pos, no patch infos, orig at #0): write at #0
14:23:45 #15 Text 0 File ThreadedTransferInterface.cpp, Line 2643
Verifying disc position of item 1 (relocatable, no disc pos, no patch infos, orig at #0): write at #115820
14:23:45 #16 Text 0 File Mmc.cpp, Line 16845
StartDAO : CD-Text - On
14:23:45 #17 Text 0 File Mmc.cpp, Line 21627
14:23:45 #18 Text 0 File Mmc.cpp, Line 17134
CueData, Len=48
21 00 00 41 00 00 00 00
21 01 00 00 00 00 00 00
21 01 01 00 00 00 02 00
21 02 00 00 00 19 2c 14
21 02 01 00 00 19 2e 14
01 aa 01 01 00 3c 0f 1d
14:24:49 #19 SCSI -1135 File Cdrdrv.cpp, Line 1436
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x068B0000
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x2A 0x00 0x00 0x00 0x42 0x57 0x00 0x00 0x1B 0x00 0x00 0x00
14:24:49 #20 CDR -1135 File Writer.cpp, Line 311
Write error
14:24:49 #21 Text 0 File ThreadedTransfer.cpp, Line 228
14:24:49 #22 Text 0 File ThreadedTransfer.cpp, Line 222
conversion idle, stopping reader
14:24:49 #23 Phase 38 File dlgbrnst.cpp, Line 1832
14:24:49 #24 Text 0 File AudioCompilationImpl.cpp, Line 867
DRM: DRM burn session terminated.
14:24:49 #25 Text 0 File AudioCompilationImpl.cpp, Line 896
DRM: Closing entire DRM handling. Bye.
Existing drivers:
Registry Keys:
MECHANT
ELHADE
Windows XP 5.1
IA32
WinAspi: -
(Nero Express)
AutoRun : 1
Excluded drive IDs:
ShowDrvBufStat : 0
BUFE : 0
Free physical memory: 121MB (124168kB)
Memory in use : 76
Use Inquiry : 1
24.5.2007
CD-ROM (ISO)
17:52:26 #1 Text 0 File Isodoc.cpp, Line 6314
Simulate : FALSE
Write : TRUE
Finalize CD : FALSE
Multisession : TRUE
Multisession type: : Start multisession
Burning mode : TAO
Mode : 1
Joliet : TRUE
17:52:26 #2 Text 0 File Burncd.cpp, Line 2946
17:52:26 #3 Text 0 File Reader.cpp, Line 127
Reader running
17:52:26 #4 Text 0 File Writer.cpp, Line 122
17:52:26 #5 ISO9660GEN -11 File geniso.cpp, Line 3309
17:52:26 #6 Text 0 File Burncd.cpp, Line 3231
17:52:26 #7 Text 0 File DlgWaitCD.cpp, Line 267
Last address to be written: 336448 ( 74:47.73)
17:52:26 #8 Text 0 File DlgWaitCD.cpp, Line 279
17:52:26 #9 Text 0 File DlgWaitCD.cpp, Line 2457
ATIP Data:
17:52:26 #10 Text 0 File DlgWaitCD.cpp, Line 445
17:52:26 #11 Text 0 File ThreadedTransferInterface.cpp, Line 830
original disc pos #0 + 336449 (336449) = #336449/74:45.74
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 336447 blocks [MATSHITA DVD-RAM UJ-831S]
17:52:26 #12 Text 0 File ThreadedTransferInterface.cpp, Line 1043
Prepare recorder [MATSHITA DVD-RAM UJ-831S] for write in TAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc not fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 307200 689354752, ISRC ""
DAO layout:
336449 | lead-out | 1 | 0x41 | 0x00
17:52:26 #13 Text 0 File ThreadedTransferInterface.cpp, Line 1111
Removed 2 run-out blocks from end of track 1. Length: 336449 -> 336447.
17:52:26 #14 Phase 24 File dlgbrnst.cpp, Line 1832
17:52:31 #15 Text 0 File Burncd.cpp, Line 4116
17:52:31 #16 Phase 25 File dlgbrnst.cpp, Line 1832
17:52:31 #17 Phase 36 File dlgbrnst.cpp, Line 1832
Burn process started at 12x (1 800 Ko/s)
17:52:31 #18 Text 0 File ThreadedTransferInterface.cpp, Line 2643
17:52:31 #19 Text 0 File Mmc.cpp, Line 21627
17:53:10 #20 SCSI -1135 File Cdrdrv.cpp, Line 1436
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x0AEB0000
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x2A 0x00 0x00 0x00 0x42 0x40 0x00 0x00 0x20 0x00 0x00 0x00
17:53:10 #21 CDR -1135 File Writer.cpp, Line 311
Write error
17:53:11 #22 Text 0 File ThreadedTransfer.cpp, Line 228
17:53:11 #23 Text 0 File ThreadedTransfer.cpp, Line 222
17:53:11 #24 CDR -201 File WriterStatus.cpp, Line 200
Invalid write state
17:53:11 #25 TRANSFER -18 File WriterStatus.cpp, Line 200
Could not perform EndTrack
17:53:11 #26 Text 0 File Mmc.cpp, Line 16275
<MATSHITADVD-RAM UJ-831S > start Close Session
17:53:42 #27 Phase 38 File dlgbrnst.cpp, Line 1832
Burn process failed at 12x (1 800 Ko/s)
Existing drivers:
Registry Keys:
MECHANT
ELHADE
Windows XP 5.1
IA32
WinAspi: -
(Nero Express)
AutoRun : 1
Excluded drive IDs:
ShowDrvBufStat : 0
BUFE : 0
Free physical memory: 111MB (113856kB)
Memory in use : 78
Use Inquiry : 1
24.5.2007
CD-ROM (ISO)
18:56:23 #1 Text 0 File Isodoc.cpp, Line 6314
Simulate : FALSE
Write : TRUE
Finalize CD : FALSE
Multisession : TRUE
Burning mode : TAO
Mode : 1
Joliet : TRUE
18:56:23 #2 Text 0 File Burncd.cpp, Line 2946
18:56:23 #3 Text 0 File Reader.cpp, Line 127
Reader running
18:56:23 #4 Text 0 File Writer.cpp, Line 122
18:56:23 #5 ISO9660GEN -11 File geniso.cpp, Line 3309
18:56:23 #6 Text 0 File Burncd.cpp, Line 3231
18:56:24 #7 Text 0 File DlgWaitCD.cpp, Line 267
18:56:24 #8 Text 0 File DlgWaitCD.cpp, Line 279
18:56:24 #9 Text 0 File DlgWaitCD.cpp, Line 2457
ATIP Data:
18:56:24 #10 Text 0 File DlgWaitCD.cpp, Line 445
18:56:24 #11 Text 0 File ThreadedTransferInterface.cpp, Line 830
18:56:24 #12 Text 0 File ThreadedTransferInterface.cpp, Line 1043
DAO infos:
MCN: ""
Tracks 1 to 1:
DAO layout:
18:56:24 #13 Text 0 File ThreadedTransferInterface.cpp, Line 1111
18:56:24 #14 Phase 24 File dlgbrnst.cpp, Line 1832
18:56:28 #15 Text 0 File Burncd.cpp, Line 4116
18:56:28 #16 Phase 25 File dlgbrnst.cpp, Line 1832
18:56:28 #17 Phase 36 File dlgbrnst.cpp, Line 1832
Burn process started at 16x (2 400 Ko/s)
18:56:28 #18 Text 0 File ThreadedTransferInterface.cpp, Line 2643
18:56:28 #19 Text 0 File Mmc.cpp, Line 21627
18:57:14 #20 SCSI -1135 File Cdrdrv.cpp, Line 1436
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x0AD80000
Sense Code: 0x0C
Sense Qual: 0x00
18:57:14 #21 CDR -1135 File Writer.cpp, Line 311
Write error
18:57:14 #22 Text 0 File ThreadedTransfer.cpp, Line 228
18:57:14 #23 Text 0 File ThreadedTransfer.cpp, Line 222
18:57:14 #24 CDR -201 File WriterStatus.cpp, Line 200
Invalid write state
18:57:14 #25 TRANSFER -18 File WriterStatus.cpp, Line 200
18:57:14 #26 Text 0 File Mmc.cpp, Line 16275
18:57:45 #27 Phase 38 File dlgbrnst.cpp, Line 1832
Burn process failed at 16x (2 400 Ko/s)
Existing drivers:
Registry Keys:
MECHANT
ELHADE
Windows XP 5.1
IA32
WinAspi: -
(Nero Express)
AutoRun : 1
Excluded drive IDs:
ShowDrvBufStat : 0
BUFE : 0
Free physical memory: 128MB (131912kB)
Memory in use : 74
Use Inquiry : 1
24.5.2007
CD-ROM (ISO)
19:57:19 #1 Text 0 File Isodoc.cpp, Line 6314
Simulate : FALSE
Write : TRUE
Finalize CD : FALSE
Multisession : TRUE
Burning mode : TAO
Mode : 1
Joliet : TRUE
19:57:19 #2 Text 0 File Burncd.cpp, Line 2946
19:57:19 #3 Text 0 File Reader.cpp, Line 127
Reader running
19:57:19 #4 Text 0 File Writer.cpp, Line 122
19:57:19 #5 ISO9660GEN -11 File geniso.cpp, Line 3309
19:57:19 #6 Text 0 File Burncd.cpp, Line 3231
<br /
