Probleme d'ecran bleu (bug)
J’ai ce fameux écran bleu qui apparait de temps en temps et qui me stoppe en plein jeu en ligne … ce qui a le don de m’irriter …
J’ai fait également une analyse WHOCRASHED
Voici le résumé :
Crash dump directory: C:\Windows\Minidump
Crash dumps are enabled on your computer.
On Tue 01/05/2012 20:48:54 GMT your computer crashed
crash dump file: C:\Windows\Minidump\050112-6442-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x7CC80)
Bugcheck code: 0xF4 (0x3, 0xFFFFFA8007FD8060, 0xFFFFFA8007FD8340, 0xFFFFF80002F95660)
Error: CRITICAL_OBJECT_TERMINATION
file path: C:\Windows\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
Bug check description: This indicates that a process or thread crucial to system operation has unexpectedly exited or been terminated.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver which cannot be identified at this time.
On Tue 01/05/2012 14:25:32 GMT your computer crashed
crash dump file: C:\Windows\Minidump\050112-5366-01.dmp
Bugcheck code: 0xF4 (0x3, 0xFFFFFA8007FD08E0, 0xFFFFFA8007FD0BC0, 0xFFFFF80002F8B660)
On Sun 18/03/2012 09:53:05 GMT your computer crashed
crash dump file: C:\Windows\Minidump\031812-6037-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x7CD40)
Bugcheck code: 0xF4 (0x3, 0xFFFFFA8007627830, 0xFFFFFA8007627B10, 0xFFFFF80002DE15F0)
On Sat 17/03/2012 15:02:20 GMT your computer crashed
crash dump file: C:\Windows\Minidump\031712-5382-01.dmp
Bugcheck code: 0xF4 (0x3, 0xFFFFFA8007623B30, 0xFFFFFA8007623E10, 0xFFFFF80002D895F0)
On Sat 25/02/2012 14:24:08 GMT your computer crashed
crash dump file: C:\Windows\Minidump\022512-5974-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x7CC40)
Bugcheck code: 0xF4 (0x3, 0xFFFFFA8007867B30, 0xFFFFFA8007867E10, 0xFFFFF80002D8E8B0)
On Tue 24/01/2012 17:43:40 GMT your computer crashed
crash dump file: C:\Windows\Minidump\012412-5319-01.dmp
Bugcheck code: 0xF4 (0x3, 0xFFFFFA800784EB30, 0xFFFFFA800784EE10, 0xFFFFF80002DDE8B0)
On Wed 18/01/2012 14:38:02 GMT your computer crashed
crash dump file: C:\Windows\Minidump\011812-5756-01.dmp
Bugcheck code: 0xF4 (0x3, 0xFFFFFA80075CE060, 0xFFFFFA80075CE340, 0xFFFFF80002DD88B0)
On Wed 11/01/2012 22:55:05 GMT your computer crashed
crash dump file: C:\Windows\Minidump\011112-5257-01.dmp
Bugcheck code: 0xF4 (0x3, 0xFFFFFA8007F9EB30, 0xFFFFFA8007F9EE10, 0xFFFFF80002DE88B0)
On Wed 04/01/2012 11:43:48 GMT your computer crashed
crash dump file: C:\Windows\Minidump\010412-5101-01.dmp
Bugcheck code: 0xF4 (0x3, 0xFFFFFA800733E9B0, 0xFFFFFA800733EC90, 0xFFFFF80002D808B0)
The following dump files were found but could not be read. These files may be corrupt:
C:\Windows\Minidump\022712-5974-01.dmp
C:\Windows\Minidump\043012-6006-01.dmp
Quelqu’un pourrait il me donner une solution pour supprimer ce problème ?
Merci d’avance
Thématique sélectionnée : Les dangers informatiques
salut
je commencerais par tester la memoire dans ce cas : www.clubic.com…
tuto : www.commentcamarche.net…
Edité le 05/05/2012 à 16:14
Merci mais vive la galère pour trouver un soft qui permet de boot à partir de ma clé usb sur windows seven…
J’ai test je ne sais combien de soft, et rien n’y fait…
Tu aurais un tuto pour vérifer si le problème vient bien de la ?
Download - Auto-installer for USB Key (Win 9x/2k/xp/7) ne marche pas sur www.memtest.org… ??
dans le bios je mets USB HDD pour booter sur ma clé usb (depend du bios en fait)
mais il n’y a pas de solution miracle pour un ecran bleu de ce style mais beaucoup de cause possible:
  • ram
  • instabilité de tension
  • overclocking
  • chaleur (sur chipset par exemple)
  • drivers ou logiciels residents daubé
  • incompatibilités diverses entre processus
  • carte mere ou autre qui commence a laché
  • virus
pour la ram tu peux eventuellement enlever des barretes de ram ,cela depend de ta config
si tu as 4go tu peux passer a 2go , et si cela le fait toujours tu inverses et mets les 2 autres
si tu as que 2go, tu peux eventuellement tester en les deplacant dans les autres port si il y en a de disponible
tu peux tester en baissant la frequence de la ram
si tu as un disque dur vide, tu mets un windows propre dessus et tu vois si avec un windows propre (sans mettre les même logiciels) cela plante ou pas (pour au moins éliminer le materiel si cela ne le fait pas)
ton pilote de carte reseau est a jour ? (vu que jeu en ligne)
le reste du pc, a jour ?
tu as mis des pilotes raid/sata avancés ou tu es avec ceux de windows ?
tu as quoi comme windows/config finalement ?
un ecran bleu c’est chiant, à une epoque les modems USB provoquaient parfois ce genre de probleme pendant telechargement, les pilotes amd/nvidia aussi (mais normalement c’est leur dll qui est mis en cause dans le BSOD, et parfois malgrés cette annonce sur le pilote graphique c’etait quand même la ram systeme qui deconnait)
Edité le 07/05/2012 à 21:44
