J’ai un formulaire qui fait appel a un script d’upload en php
Il fonctionne tres bien mais j’ai besion de faire un ajout sql pour enregistrer le nom de chaque fichier envoyé
La partie sql ne fonctionne pas du tout quelqu’un pourrait m’aider
mon code du script
<?php include("admin/parametres.php"); ?> <?php include("JSON.php"); $result = array(); $types = array('swf','flv','txt','pdf','jpg'); if (isset($_FILES['photoupload']) ) { $file = $_FILES['photoupload']['tmp_name']; $error = false; $size = false; $filename = basename($_FILES['photoupload']['name']); $ext = substr($filename, strrpos($filename, '.') + 1); if (!is_uploaded_file($file) || ($_FILES['photoupload']['size'] > 2 * 1024 * 1024) ) { $error = 'Please upload only files smaller than 2Mb!'; } elseif (!in_array($ext, $types)) { $error = 'Unsupported file format.'; } else { move_uploaded_file($_FILES['photoupload']['tmp_name'], "./uploadedfiles/".$_FILES['photoupload']['name']); chmod("./uploadedfiles/".$_FILES['photoupload']['name'], 0777); } $addr = gethostbyaddr($_SERVER['REMOTE_ADDR']); $log = fopen('script.log', 'a'); fputs($log, ($error ? 'FAILED' : 'SUCCESS') . ' - ' . preg_replace('/^[^.]+/', '***', $addr) . ": {$_FILES['photoupload']['name']} - {$_FILES['photoupload']['size']} byte\n" ); fclose($log); if ($error) { $result['result'] = 'failed'; $result['error'] = $error; } else { // requete sql mysql_query("INSERT INTO images VALUES('', '" . $filename . "', '')"); $result['result'] = 'success'; $result['size'] = "Uploaded successful."; } } else { $result['result'] = 'error'; $result['error'] = 'Missing file or internal error!'; } if (!headers_sent() ) { header('Content-type: application/json'); } echo json_encode($result); ?>
