Problème de librairie - Problème de librairie à l'installation
J’essaye d’installer airsnort, mais bonjour la galère (remarqué, j’y connais rien en linux !).
Donc apres une decompression, voila que qu’il me manque gtk±2.0
Ok, ça , je pense que c’est bon :wink: . j’ai installé le packé de dev
mais voila que j’arrive toujours pas a faire mon "make"…pourquoi t’en de haine :stuck_out_tongue:
HELP ME PLEASE …
voila ce qu’il me raconte :
root@HP:/windows/tool-hack/outil/airsnort-0.2.7e# ./install
./install: line 1: The: command not found
checking for a BSD-compatible install… /usr/bin/install -c
checking whether build environment is sane… yes
checking for gawk… no
checking for mawk… mawk
checking whether make sets $(MAKE)… yes
checking whether to enable maintainer-specific portions of Makefiles… no
checking for style of include used by make… GNU
checking for gcc… gcc
checking for C compiler default output file name… a.out
checking whether the C compiler works… yes
checking whether we are cross compiling… no
checking for suffix of executables…
checking for suffix of object files… o
checking whether we are using the GNU C compiler… yes
checking whether gcc accepts -g… yes
checking for gcc option to accept ANSI C… none needed
checking dependency style of gcc… gcc3
checking for library containing strerror… none required
checking for gcc… (cached) gcc
checking whether we are using the GNU C compiler… (cached) yes
checking whether gcc accepts -g… (cached) yes
checking for gcc option to accept ANSI C… (cached) none needed
checking dependency style of gcc… (cached) gcc3
checking how to run the C preprocessor… gcc -E
checking for egrep… grep -E
checking for ANSI C header files… yes
checking for pkg-config… /usr/bin/pkg-config
checking for gtk±2.0 >= 2.0.0… yes
checking PACKAGE_CFLAGS… -I/usr/include/gtk-2.0 -I/usr/lib/gtk-2.0/include -I/usr/include/atk-1.0 -I/usr/include/cairo -I/usr/include/pango-1.0 -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include
checking PACKAGE_LIBS… -lgtk-x11-2.0 -lgdk-x11-2.0 -latk-1.0 -lgdk_pixbuf-2.0 -lm -lpangocairo-1.0 -lfontconfig -lXinerama -lXi -lXrandr -lXext -lXcursor -lXfixes -lpango-1.0 -lcairo -lXrender -lX11 -lgobject-2.0 -lgmodule-2.0 -ldl -lglib-2.0
configure: creating ./config.status
config.status: creating Makefile
config.status: creating src/Makefile
config.status: creating man/Makefile
config.status: creating config.h
config.status: config.h is unchanged
config.status: executing depfiles commands
make all-recursive
make[1]: entrant dans le répertoire « /windows/tool-hack/outil/airsnort-0.2.7e »
Making all in src
make[2]: entrant dans le répertoire « /windows/tool-hack/outil/airsnort-0.2.7e/src »
if gcc -DHAVE_CONFIG_H -I. -I. -I… -DPACKAGE_DATA_DIR=\""/usr/local/share"\" -DPACKAGE_LOCALE_DIR=\""/usr/local//locale"\" -I/usr/include/gtk-2.0 -I/usr/lib/gtk-2.0/include -I/usr/include/atk-1.0 -I/usr/include/cairo -I/usr/include/pango-1.0 -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include -g -O2 -MT main.o -MD -MP -MF ".deps/main.Tpo" -c -o main.o main.c; \
then mv -f ".deps/main.Tpo" ".deps/main.Po"; else rm -f ".deps/main.Tpo"; exit 1; fi
if gcc -DHAVE_CONFIG_H -I. -I. -I… -DPACKAGE_DATA_DIR=\""/usr/local/share"\" -DPACKAGE_LOCALE_DIR=\""/usr/local//locale"\" -I/usr/include/gtk-2.0 -I/usr/lib/gtk-2.0/include -I/usr/include/atk-1.0 -I/usr/include/cairo -I/usr/include/pango-1.0 -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include -g -O2 -MT support.o -MD -MP -MF ".deps/support.Tpo" -c -o support.o support.c; \
then mv -f ".deps/support.Tpo" ".deps/support.Po"; else rm -f ".deps/support.Tpo"; exit 1; fi
if gcc -DHAVE_CONFIG_H -I. -I. -I… -DPACKAGE_DATA_DIR=\""/usr/local/share"\" -DPACKAGE_LOCALE_DIR=\""/usr/local//locale"\" -I/usr/include/gtk-2.0 -I/usr/lib/gtk-2.0/include -I/usr/include/atk-1.0 -I/usr/include/cairo -I/usr/include/pango-1.0 -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include -g -O2 -MT interface.o -MD -MP -MF ".deps/interface.Tpo" -c -o interface.o interface.c; \
then mv -f ".deps/interface.Tpo" ".deps/interface.Po"; else rm -f ".deps/interface.Tpo"; exit 1; fi
if gcc -DHAVE_CONFIG_H -I. -I. -I… -DPACKAGE_DATA_DIR=\""/usr/local/share"\" -DPACKAGE_LOCALE_DIR=\""/usr/local//locale"\" -I/usr/include/gtk-2.0 -I/usr/lib/gtk-2.0/include -I/usr/include/atk-1.0 -I/usr/include/cairo -I/usr/include/pango-1.0 -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include -g -O2 -MT callbacks.o -MD -MP -MF ".deps/callbacks.Tpo" -c -o callbacks.o callbacks.c; \
then mv -f ".deps/callbacks.Tpo" ".deps/callbacks.Po"; else rm -f ".deps/callbacks.Tpo"; exit 1; fi
callbacks.c:9:18: erreur: pcap.h : Aucun fichier ou répertoire de ce type
In file included from callbacks.c:24:
PacketSource.h:153: erreur: syntax error before ‘pcap_t’
PacketSource.h:153: attention : pas de point virgule à la fin de la structure ou de l’union
PacketSource.h:154: attention : la définition de données n’a pas de type ni de classe de stockage
PacketSource.h:163: erreur: syntax error before ‘}’ token
PacketSource.h:163: attention : la définition de données n’a pas de type ni de classe de stockage
PacketSource.h:173: erreur: syntax error before ‘’ token
PacketSource.h:174: attention : la définition de données n’a pas de type ni de classe de stockage
PacketSource.h:175: erreur: syntax error before ‘
’ token
PacketSource.h:176: erreur: syntax error before ‘’ token
PacketSource.h:176: attention : la définition de données n’a pas de type ni de classe de stockage
PacketSource.h:177: erreur: syntax error before ‘
’ token
PacketSource.h:178: erreur: syntax error before ‘’ token
PacketSource.h:179: erreur: syntax error before ‘
’ token
In file included from bssidlist.h:35,
from display.h:23,
from callbacks.c:29:
capture.h:49: erreur: syntax error before ‘PacketSource’
capture.h:49: attention : pas de point virgule à la fin de la structure ou de l’union
capture.h:51: erreur: syntax error before ‘}’ token
capture.h:51: attention : la définition de données n’a pas de type ni de classe de stockage
callbacks.c:79: erreur: ‘PCAP_ERRBUF_SIZE’ undeclared here (not in a function)
callbacks.c: In function ‘on_Start_clicked’:
callbacks.c:368: erreur: ‘ca’ undeclared (first use in this function)
callbacks.c:368: erreur: (Chaque identificateur non déclaré est rapporté une seule fois
callbacks.c:368: erreur: pour chaque fonction dans laquelle il apparaît.)
callbacks.c:378: erreur: syntax error before ‘)’ token
callbacks.c: In function ‘on_pcap_ok_clicked’:
callbacks.c:670: erreur: ‘ca’ undeclared (first use in this function)
callbacks.c:670: erreur: syntax error before ‘)’ token
make[2]: *** [callbacks.o] Erreur 1
make[2]: quittant le répertoire « /windows/tool-hack/outil/airsnort-0.2.7e/src »
make[1]: *** [all-recursive] Erreur 1
make[1]: quittant le répertoire « /windows/tool-hack/outil/airsnort-0.2.7e »
make: *** [all] Erreur 2
Making install in src
make[1]: entrant dans le répertoire « /windows/tool-hack/outil/airsnort-0.2.7e/src »
’ token
’ token
’ token
from display.h:23,
make[1]: *** [callbacks.o] Erreur 1
make[1]: quittant le répertoire « /windows/tool-hack/outil/airsnort-0.2.7e/src »
make: *** [install-recursive] Erreur 1
./install: line 7: Good: command not found
./configure && make && su -c ‹ make install ›
Lis les fichiers "INSTALL" et "README"…
Et puis, essaye plutot de l’installer avec ton gestionnaire de paquets… (lis la FAQ)
  1. essais d’installer ça avec ton gestionnaire de paquets.
  2. si tu veux vraiment essayer de le compiler, voila l’erreur :
le fichier callbacks.c inclu à la ligne 9 le fichier pcap.h qui n’a pas été trouvé. Donc 2 solutions :
a) une librairie de dev qui contient ce fichier est manquante, mais c’est étrange que le configure ne l’ai pas détecté…
b) le fichier est bien présent sur ton système mais le makefile est mal formé et il manque un répertoire d’include à ta ligne de compilation.
Si tu ne connais rien en compilation, N’ESSAIS PAS de corriger cela toi même…
bon moi mon probleme c 'est ou trouver ce logiciel???g essayer par tous les moyens mais malheureusement …j compte sur votre aide…
ben t’as pas essaye assez…
quelle est ta distrib ?
Airsnort s’installe en 2min si tu utilises ton gestionnaire de paquets
