Windows XP 5.1
IA32
WinAspi: -
NT-SPTI used
Nero Version: 8.3.6.0
Internal Version: 8, 3, 6, 0
Recorder: Version: 1.50 - HA 1 TA 0 - 8.3.6.0
Adapter driver: HA 1
Drive buffer : 2048kB
Bus Type : default
CD-ROM: Version: 2.0B - HA 1 TA 1 - 8.3.6.0
=== Scsi-Device-Map ===
CdRomPeripheral : MATSHITA DVD-RAM UJ-841S atapi Port 0 ID 0 DMA: On
DiskPeripheral : FUJITSU MHV2080BH atapi Port 1 ID 0 DMA: On
CdRomPeripheral : VJ2052O MXO807C 2.0B vaxscsi Port 3 ID 0 DMA: Off
=== CDRom-Device-Map ===
MATSHITA DVD-RAM UJ-841S D: CdRom0
VJ2052O MXO807C F: CdRom1
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
BUFE : 0
Physical memory : 1014MB (1038768kB)
Free physical memory: 594MB (608692kB)
Memory in use : 41 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
25.9.2008
Compilation ISO
18:32:18 #1 Text 0 File SCSIPTICommands.cpp, Line 450
LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
18:32:19 #2 Text 0 File Isodoc.cpp, Line 6713
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : FALSE
Multisession : TRUE
Multisession type: : Start multisession
Burning mode : DAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
18:32:19 #3 ISO9660GEN -11 File Geniso.cpp, Line 3349
First writeable address = 0 (0x00000000)
18:32:19 #4 ISO9660GEN -11 File Geniso.cpp, Line 3349
First writeable address = 816 (0x00000330)
18:32:19 #5 Text 0 File Burncd.cpp, Line 3568
Turn on Disc-At-Once, using DVD media
18:32:19 #6 Text 0 File FilesystemSettingsValidator.cpp, Line 142
FS Settings: using validator ‹ CUDFSettingsValidatorDVD ›
ParamMode = ‹ automatic ›, changing UDF partition type from ‹ physical › to ‹ physical ›
Changing UDF revision from ‹ 1.02 › to ‹ 1.02 ›
18:32:19 #7 Text 0 File FilesystemSettingsValidator.cpp, Line 142
18:32:23 #8 Text 0 File DlgWaitCD.cpp, Line 311
Last possible write address on media: 2295103 (510:01.28, 4482MB)
Last address to be written: 2220111 (493:21.36, 4336MB)
18:32:23 #9 Text 0 File DlgWaitCD.cpp, Line 323
Write in overburning mode: NO (enabled: CD)
18:32:23 #10 Text 0 File DlgWaitCD.cpp, Line 2948
Recorder: MATSHITA DVD-RAM UJ-841S, Media type: DVD+R
Disc Manufacturer ID: , Media Type ID: , Product revision number: 0
Disc Application Code: 0, Extended Information Indicators: 7
18:32:23 #11 Text 0 File DlgWaitCD.cpp, Line 497
>>> Protocol of DlgWaitCD activities: <<<
Insert the disc to write to.
(Medium in drive: DVD+R. Medium required by compilation: DVD R/RW; DVD DL; DVD-RAM.)
18:32:23 #12 Text 0 File ThreadedTransferInterface.cpp, Line 754
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 2219296 (2219296) = #2219296/493:10.46
relocatable, disc pos for caching/writing not required/ required
→ TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2219296 blocks [D: MATSHITA DVD-RAM UJ-841S]
18:32:23 #13 Text 0 File ThreadedTransferInterface.cpp, Line 956
Prepare [D: MATSHITA DVD-RAM UJ-841S] for write in CUE-sheet-DAO
DAO infos:
MCN: « »
TOCType: 0x00; Session Closed, disc not fixated
Tracks 2 to 2: Idx 0 Idx 1 Next Trk
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4545118208, ISRC « »
DAO layout:
__Start|___Track|Idx|CtrlAdr|Size|NWA|RecDep
816 | lead-in | 0 | 0x41 | 0 | 0 | 0x00
816 | 2 | 0 | 0x41 | 0 | 0 | 0x00
816 | 2 | 1 | 0x41 | 2219296 | 816 | 0x00
2220112 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
18:32:23 #14 Text 0 File SCSIPTICommands.cpp, Line 240
SPTILockVolume - completed successfully for FSCTL_LOCK_VOLUME
18:32:23 #15 Text 0 File Burncd.cpp, Line 4359
Caching options: cache CDRom or Network-Yes, small files-No (<64KB)
18:32:23 #16 Phase 24 File dlgbrnst.cpp, Line 1767
Caching of files started
18:32:23 #17 Text 0 File Burncd.cpp, Line 4481
Cache writing successful.
18:32:23 #18 Phase 25 File dlgbrnst.cpp, Line 1767
Caching of files completed
18:32:23 #19 Phase 36 File dlgbrnst.cpp, Line 1767
Burn process started at 2.4x (3 324 Ko/s)
18:32:23 #20 Text 0 File ThreadedTransferInterface.cpp, Line 2673
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #816
18:32:23 #21 Text 0 File Cdrdrv.cpp, Line 10187
---- Disc Structure: Physical Format Information (00h) ----
Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD+R (10), Part Version: 1.0x (1)
Disc Size: 120 mm, Maximum Transfer Rate: (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 26053F h
Data in Burst Cutting Area (BCA) does not exist
Disc Application Code: 0 / 0 h
Extended Information indicators: 7 h
Disc Manufacturer ID: INFOME…
Media type ID: R30
Number of Physical format information bytes in use in ADIP up to byte 63: 56
Media Specific [16…783]:
00 00 07 49 4E 46 4F 4D - 45 00 00 52 33 30 00 38 …INFOME…R30.8
23 54 37 13 02 52 6C 02 - 7C 5D 15 15 0B 0A 08 08 #T7…Rl.|]…
01 19 1B 0C 0C 0C 0D 01 - 00 00 00 00 00 00 00 00 …
01 00 38 38 02 25 5D 1A - 07 2E 23 10 04 1E 1D 01 …88.%]…#…
00 00 02 25 5D 1A 07 2E - 23 10 04 1E 1D 01 00 00 …%]…#…
02 00 54 70 02 38 6A 35 - 23 15 0B 0B 02 20 00 00 …Tp.8j5#…
00 00 02 49 6C 3A 23 15 - 0B 0B 02 20 00 00 00 2B …Il:#…+
03 00 54 DF 02 38 6A 35 - 23 15 0B 0B 02 20 00 00 …T…8j5#…
00 00 02 77 61 56 22 15 - 08 07 01 20 00 00 00 3A …waV"…:
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 …
18:32:24 #22 Text 0 File DVDPlusRW.cpp, Line 675
Start write address at LBA 816
DVD high compatibility mode: No
18:32:24 #23 Text 0 File ThreadedTransfer.cpp, Line 269
Pipe memory size 83836800
18:32:45 #24 SPTI -1 File SCSIPassThrough.cpp, Line 214
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1)
CDB Data: 0x2A 00 00 00 06 50 00 00 20 00 00 00
Sense Key: 0x04 (KEY_HARDWARE_ERROR)
Sense Code: 0x03
Sense Qual: 0x00
Sense Area: 0xF1 00 04 00 00 03 50 0A 00 29 00 00 03
Buffer x094e0680: Len x10000
0xA1 C7 05 26 E7 06 4E 78 5C 08 41 48 64 F0 B4 08
0x07 73 9E 16 C0 D8 32 39 CF 0A D6 78 64 F1 C5 DC
0xF4 71 DD 90 CC 3E 47 CA 0F 50 70 D1 EE 77 8D 0B
18:32:45 #25 CDR -1 File Writer.cpp, Line 306
Unspecified Recorder Error
18:32:51 #26 SPTI -1 File SCSIPassThrough.cpp, Line 214
CDB Data: 0x00 00 00 00 00 00 00 00 00 00 00 00
Sense Code: 0x03
Sense Qual: 0x00
Sense Area: 0x71 00 04 00 00 00 00 0A 00 29 00 00 03
18:32:51 #27 SPTI -1046 File SCSIPassThrough.cpp, Line 214
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1046)
CDB Data: 0x5B 01 02 00 00 00 00 00 00 00 00 00
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x30
Sense Qual: 0x05
Sense Area: 0x70 00 05 00 00 00 00 0A 00 82 00 00 30 05
18:32:51 #28 Text 0 File DVDPlusRW.cpp, Line 943
EndDAO: Last written address 1616
18:32:51 #29 CDR -1 File WriterStatus.cpp, Line 292
18:32:51 #30 TRANSFER -24 File WriterStatus.cpp, Line 292
Could not perform end of Disc-at-once
18:32:52 #31 Phase 38 File dlgbrnst.cpp, Line 1767
Burn process failed at 2.4x (3 324 Ko/s)
18:32:52 #32 Text 0 File SCSIPTICommands.cpp, Line 287
SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
18:32:55 #33 Text 0 File Cdrdrv.cpp, Line 11450
DriveLocker: UnLockVolume completed
18:32:55 #34 Text 0 File SCSIPTICommands.cpp, Line 450
UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
Existing drivers:
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
