Je suis allée sur le site NEc computer . Je n’y ais pas trouvé de mise de firmware . Tout ce que j’ai vu est noté ci dessous . Ce qui me dit pas grand chose . si quelqu’un a une idee , qu’il n’hesite surtout pas à m’en faire part … car là , je seche lamentablement :(:(
MErci
Accueil >Support >>>NEC ND-1300A DVD±RW Drive
(cliquez sur l’image pour l’agrandir)
Features
Front Panel
Manual Load/Eject Button Drive State and Single LED Specification (green) Form Factor: 5.25" half height Disc media: 120 mm or 80 mm discs (80 mm discs: playback only/adapter required) Mounting Orientation: horizontal & vertical; In vertical orientation the right side down Enhanced IDE Interface Multifunction device Transfer Rate (Write) Transfer Rate (Read)
DVD-R
4x CLV 5.5 MB/s
2x CLV 2.7 MB/s
DVD-RW
2x CLV 2.7 MB/s
1x CLV 1.38 MB/s
DVD+R
4x CLV 5.5 MB/s
2.4x CLV 3.3 MB/s
DVD+RW
2.4x CLV 3.3 MB/s
CD-R
16x CLV 2400 KB/s
8x CLV 1200 KB/s
4x CLV 600 KB/s
CD-RW
10xCLV 1500 KB/s
4xCLV 600 KB/s DVD-ROM
Single Layer 5-12x CAV 6.9-16.6 MB/s
Dual Layer 3-7x CAV 4.1-10 MB/s
DVD-R/-RW/+R/+RW
2-5x CAV 2.7-6.9 MB/s
DVD-Video with CSS protection
CD-ROM/CD-R
Mode 1 and Mode 2 Form 1 (2048 bytes)
17-40x CAV 2550 - 6000 KB/s
CD-RW
Mode 1 and Mode 2 Form 1 (2048 Bytes)
13-32x CAV 1950 - 4800 KB/s
DAE
Mode 2 and Mode 2 Form2
8x CLV 1200 KB/s
Data buffer: 2 MB Physical and Environmental Specifications
Dimensions
L x W x H: 146 x 198 x 42 mm Operating Non-operating
Ambient temperature 0 to 45°C (ambient) -40 to 65°C for 72 hours
Relative humidity (no condensation) Max 70% 20 to 90%
Shock (6 G) read /(1.5 G) write -
Vibration 5-500 Hz: 0.25 G, 6 directions. 5-300 Hz: 1.0 G, 3 sides, 10 sweeps/side.
- Compatibility
Media
Read capability All CD-ROM, Audio-CD, Video-CD, CD-R, CD-RW, DVD, DVD+R , DVD-RW, DVD-R, DVD+RW MEDIA, CD EXTRA
Write capability DVD-R, DVD-RW, DVD+R, DVD+RW, CD Digital Audio, CD Extra, CD-ROM Video-CD, CD Text
Reliability
Tray loader Mechanism life: at least 30,000 tray load/unload cycles Mean Time Between Failures: 70,000 Power on hours Compliance
Safety
UL: UL60950 (safety, US) C-UL: CSA C22.2 N°60950 (safety, Canada) TÜV: EN60950 BSMI (Taiwan) NEMKO EMC
FCC part 15 class B (USA) IC ICES-003 Class B CE marking (EMC directive 89/336/EEC) C-Tick (Australia) Laser Safety
DHHS EN 60825-1 (Europe) Performance
Access Time Full Stroke
Access Time Random 200 ms (random average) DVD, 200 ms CD
100 ms (random average) DVD, 120 ms CD
DVD Rotation speed 5-12x CAV 6940 rpm
3-7x CAV 4580 rpm
2-5x CAV 2780 rpm
4x CLV 2298 ~ 5554 rpm
2.4x CLV 1379 ~ 3333 rpm
2x CLV 1149 ~ 2777 rpm
1x CLV 574 ~ 1389 rpm
CD Rotation speed 17-40x CAV 8350 rpm
13-32x CAV 6950 rpm
4-10x CAV 2100 rpm
16x CLV 3424 ~ 7952 rpm
10x CLV 2140 ~ 4970 rpm
8x CLV 1712 ~ 3976 rpm
4x CLV 856 ~ 1988 rpm
Spin up time 5 seconds
Data Transfers Protocol
ATA PIO Mode 4 (16.7 MB/s) ATA Multi Word DMA Mode2 (16.7 MB/s) ATA Ultra DMA Mode 2 (33.3 MB/s) Audio Capability
Line Out
Output levels 0.75 V ± 3.0 dB at 10 kW
Distortion <0.10%
Signal to Noise ratio 75 dB
6.3 Noise Specification
Mode Max (dB(A))
Normal Read/Write/Seek 45
Current Requirements (typical)
5 V DC 12 V DC
Voltage Tolerance ± 5% ± 5%
Ripple Noise <120 mVpp <120 mVpp
Seek <1100 / 530 mA 1200 / 800 mA
Idle 530 / 450 mA 320 / 260 mA
Spin Up <800 / 480 mA <1400 / 1150 mA
Tray Open/Close <650 / 380 mA <650 / 330 mA
Sleep <80 / 55 mA <170 / 130 mA
Settings
Jumpers Function
off off on Master
on off off Cable Select
off on off Slave (default, as shown on picture)
Typical Connections
Drive connector Type of plug
DC Power Connector 4-pin plug (AMP)
IDE Interface Connector 40-pin male
Master/Slave/Cable Select 6-pin
Analogue Audio Output 4-pin male
