Problème de gravage avec Nero
Je solicite votre aide car j’ai un problème quand je grave un CD avec Nero.
Il commence à graver et une erreur se produit avant la fin. Ca commence à me couter cher en CD car ça les bousille à chaque fois. :frowning:
Voilà quelques infos :
20:48:28 #1 Text 0 File Isodoc.cpp, Line 5095
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : TAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9600
Joliet : TRUE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
20:48:28 #2 Phase 72 File dlgbrnst.cpp, Line 1449
BURN-Proof activated
20:48:28 #3 Text 0 File Reader.cpp, Line 118
Reader running
20:48:28 #4 Text 0 File Writer.cpp, Line 129
Writer PLEXTOR CD-R PX-W4012A running
20:48:28 #5 Text 0 File Burncd.cpp, Line 2636
Turn on Track-At-Once, using CD-R/RW media
20:48:28 #6 ISO9660GEN -11 File geniso.cpp, Line 4428
First writeable address = 0 (0x00000000)
20:48:28 #7 Text 0 File ThreadedTransferInterface.cpp, Line 684
Setup items (original item values)
0: TRM_DATA_MODE1 (CTransferItem)
2 indices, index0 (150) not provided
original CD pos #0 + 358343 (358343) = #358343/79:37.68
relocatable, CD pos for caching/writing not required/required, no patch infos
20:48:29 #8 Text 0 File DlgWaitCD.cpp, Line 199
Last possible write address on media: 359848 (79:59.73)
Last address to be written: 358342 (79:39.67)
20:48:31 #9 Text 0 File DlgWaitCD.cpp, Line 1387
Recorder: PLEXTOR CD-R PX-W4012A;
CDR code: 00 97 17 06; CD manufacturer unknown
ATIP Data:
Special Info [hex] 1: D0 00 A0, 2: 61 11 06 (LI 97:17.06), 3: 4F 3B 4A (LO 79:59.74)
Additional Info [hex] 1: 2B 00 D0 (invalid), 2: 3C B8 00 (invalid), 3: 22 D2 80 (invalid)
20:48:33 #10 Text 0 File ThreadedTransferInterface.cpp, Line 834
Prepare recorder PLEXTOR CD-R PX-W4012A for write in TAO
DAO infos:
MCN:
TOCTYPE: 0x0 Close CD
Tracks 1 to 1:
TRM_DATA_MODE1, 2048/0x0, ISRC "", FilePos 0 307200 734193664
20:48:33 #11 Text 0 File ThreadedTransferInterface.cpp, Line 862
Removed 2 run-out blocks from end of track 1.
20:48:33 #12 Text 0 File ThreadedTransferInterface.cpp, Line 684
Setup items (after recorder preparation)
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 358341 blocks [PLEXTOR CD-R PX-W4012A]
20:48:33 #13 Phase 24 File dlgbrnst.cpp, Line 1449
Caching of files started
20:48:33 #14 Phase 25 File dlgbrnst.cpp, Line 1449
Caching of files completed
20:48:33 #15 Phase 36 File dlgbrnst.cpp, Line 1449
Burn process started at 40x (6 000 Ko/s)
20:48:33 #16 Text 0 File ThreadedTransferInterface.cpp, Line 1960
Verifying CD position of item 0 (relocatable, CD pos, no patch infos, orig at #0): write at #0
20:48:33 #17 Text 0 File Mmc.cpp, Line 15361
Set BUFE: BURN-Proof -> ON
20:56:13 #18 SCSI -1093 File Cdrdrv.cpp, Line 1413
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x027E0000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x02
Sense Qual: 0x00
CDB Data: 0x2A 0x00 0x00 0x03 0xFD 0x2F 0x00 0x00 0x1F 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x03 0xFD 0xC5 0x0A
0x00 0x00 0x00 0x00 0x02 0x00
20:56:13 #19 MMC -1093 File Writer.cpp, Line 330
No seek complete
20:56:13 #20 Text 0 File ThreadedTransfer.cpp, Line 222
all writers idle, stopping conversion
20:56:14 #21 Text 0 File ThreadedTransfer.cpp, Line 216
conversion idle, stopping reader
20:56:28 #22 CDR -201 File WriterStatus.cpp, Line 186
Invalid writestate
20:56:28 #23 TRANSFER -18 File WriterStatus.cpp, Line 186
Could not perform EndTrack
20:56:58 #24 Phase 38 File dlgbrnst.cpp, Line 1449
Burn process failed at 40x (6 000 Ko/s)
20:56:58 #25 Text 0 File Burncd.cpp, Line 3827
68 ruptures de flux de données ont été évitées.
20:57:13 #26 Text 0 File Scsicmd.cpp, Line 386
SCSI not using temporary buffers
20 out of 20 temporary buffers allocated
Merci de m’aider car ça me saoule vraiment.
salut, t’as essayé de desinstaller et reinstalle, sinon verifie les aspi dans nero info tool…t’as quoi comme graveur? quel est ta version de nero?
as tu xp sp2 (y a une version non compatible)
je vais essayé de réinstaller.
sinon, c’est quoi les aspi dans nero info tool ?
sinon j’ai un PLEXTOR comme graveur.
j’ai Nero V 5.5.8.0
oui j’ai XP mais je sais pas quelle version.
mais avant ça marchait bien avec le même matos.
The_Bull ;
il est possible que le type de CD ne soit pas compatible avec ton graveur et qu’une mise à jour du firmware pourait résoudre.
je te donne un exemple :
je viens de faire un update de firmware d’un Memup DRW1004IM qui n’arretait pas de me planter toutes mes compil sur des DVD -R (ritek). plus de problème après la mise à jour du firmware.
Attention ce type de flash (si mal fait) peut rendre inutilisable ton graveur.
Ok MasterCode mais comment je peux faire ça ?
Mais c’est un CD norma Verbatim donc je pense pas que ça vienne de là.
sorry pour le retard ;
regarde sur ce post j’explique comment proceder pour l’ugrade du firmware .
les Verbatim en general passent bien partout effectivement c’est "bizaroide" ce plantage.
as-tu essayé en diminuant la vitesse de gravure ?
> il y a eu plusieurs ugrades du firmware site du constructeur ?
> reussis-tu à faire des compil sans erreur avec d’autre marque ?
>quel est la reference exacte de ton graveur Plextor ???
> passer le graveur sur un autre PC pourait aider à cerner mieux d’ou vient le problm.
on finira bien par trouver :wink:
La version 5.5.8.0 est une très vielle version (et incompatible avec XP-SP2 me semble t-il). Fais déjà une mise à jour vers une version 6 pour voir…
Amitiés
Janus
