Bonjour , Pour donner suite à mon Pb
J ai effectué une mise à jour du Bios sur le site ASUS.
carte mère P8P67-M PRO BIOS 3701. version 2013.
Problème identique environs 1 heures aprés > crash !!
à 4 reprises aujourd 'hui
Voici mon rapport avec « Whocrashed » Merci d 'avance pour votre Aide !!!:(
System Information (local)
Computer name: NICO-PC
Windows version: Windows 7 Service Pack 1, 6.1, build: 7601
Windows dir: C:Windows
Hardware: ASUSTeK COMPUTER INC., P8P67-M PRO
CPU: GenuineIntel Intel(R) Core™ i7-2600K CPU @ 3.40GHz Intel586, level: 6
8 logical processors, active mask: 255
RAM: 8553099264 bytes total
Crash Dump Analysis
Crash dump directory: C:WindowsMinidump
Crash dumps are enabled on your computer.
On Sun 08/10/2017 01:52:04 your computer crashed
crash dump file: C:WindowsMinidump100817-11668-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x6F980)
Bugcheck code: 0x101 (0x19, 0x0, 0xFFFFF88003565180, 0x2)
Error: CLOCK_WATCHDOG_TIMEOUT
file path: C:Windowssystem32ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
Bug check description: This indicates that an expected clock interrupt on a secondary processor, in a multi-processor system, was not received within the allocated interval.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem. This problem might also be caused because of overheating (thermal issue).
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
crash dump file: C:Windowsmemory.dmp
This was probably caused by the following module: farflt.sys (farflt+0x8560)
file path: C:Windowssystem32driversfarflt.sys
product: Malwarebytes Anti-Ransomware Protection
company: Malwarebytes
description: Malwarebytes Anti-Ransomware Protection
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: farflt.sys (Malwarebytes Anti-Ransomware Protection, Malwarebytes).
Google query: Malwarebytes CLOCK_WATCHDOG_TIMEOUT
On Sun 08/10/2017 00:25:07 your computer crashed
crash dump file: C:WindowsMinidump100817-12916-01.dmp
Bugcheck code: 0x101 (0x19, 0x0, 0xFFFFF880009B3180, 0x4)
On Fri 06/10/2017 21:13:20 your computer crashed
crash dump file: C:WindowsMinidump100617-14944-01.dmp
Bugcheck code: 0x101 (0x19, 0x0, 0xFFFFF88003365180, 0x2)
Conclusion
4 crash dumps have been found and analyzed. A third party driver has been identified to be causing system crashes on your computer. It is strongly suggested that you check for updates for these drivers on their company websites. Click on the links below to search with Google for updates for these drivers:
If no updates for these drivers are available, try searching with Google on the names of these drivers in combination with the errors that have been reported for these drivers. Include the brand and model name of your computer as well in the query. This often yields interesting results from discussions on the web by users who have been experiencing similar problems.
Read the topic general suggestions for troubleshooting system crashes for more information.
Note that it’s not always possible to state with certainty whether a reported driver is responsible for crashing your system or that the root cause is in another module. Nonetheless it’s suggested you look for updates for the products that these drivers belong to and regularly visit Windows update or enable automatic updates for Windows. In case a piece of malfunctioning hardware is causing trouble, a search with Google on the bug check errors together with the model name and brand of your computer may help you investigate this further.
