Quand j’édite le fichier Xorg.conf j’ai l’option xinerama activée. Pourtant j’arrive pas à différencier mes deux écrans.
Qqun a une idée? Ci-joint mon fichier Xorg.conf. Qu’est-ce que ca donne si je modifie le fichier X86config
Ben
File generated by XFdrake.
Refer to the XF86Config man page for details about the format of
this file.
Section "Files"
# Multiple FontPath entries are allowed (they are concatenated together)
# By default, Mandrake 6.0 and later now use a font server independent of
# the X server to render fonts.
FontPath "unix/:-1"
EndSection
Section "ServerFlags"
#DontZap # disable <Crtl><Alt><BS> (server abort)
#DontZoom # disable <Crtl><Alt><KP_+>/<KP_-> (resolution switching)
AllowMouseOpenFail # allows the server to start up even if the mouse does not work
EndSection
Section "Module"
Load "dbe" # Double-Buffering Extension
Load "v4l" # Video for Linux
Load "extmod"
Load "type1"
Load "freetype"
Load "dri" # direct rendering
Load "/usr/X11R6/lib/modules/extensions/libglx.a"
EndSection
Section "InputDevice"
Identifier "Keyboard1"
Driver "keyboard"
Option "XkbModel" "pc105"
Option "XkbLayout" "fr"
Option "XkbOptions" "compose:rwin"
EndSection
Identifier "Mouse1"
Driver "mouse"
Option "Protocol" "ExplorerPS/2"
Option "Device" "/dev/mouse"
Option "ZAxisMapping" "6 7"
EndSection
Section "Monitor"
Identifier "monitor1"
VendorName "Plug’n Play"
ModelName "Acer AL1721"
HorizSync 30-83
VertRefresh 55-75
# Monitor preferred modeline (60.0 Hz vsync, 64.0 kHz hsync, ratio 5/4)
ModeLine "1280x1024" 108 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync
# TV fullscreen mode or DVD fullscreen output.
# 768x576 @ 79 Hz, 50 kHz hsync
ModeLine "768x576" 50.00 768 832 846 1000 576 590 595 630
# 768x576 @ 100 Hz, 61.6 kHz hsync
ModeLine "768x576" 63.07 768 800 960 1024 576 578 590 616
EndSection
Section "Monitor"
Identifier "monitor2"
HorizSync 30-81
VertRefresh 56-75
EndSection
Section "Device"
Identifier "device1"
VendorName "ATI"
BoardName "ATI Radeon (fglrx)"
Driver "radeon"
Screen 0
BusID "PCI:1:0:0"
Option "DPMS"
EndSection
Section "Device"
Identifier "device2"
VendorName "ATI"
Driver "radeon"
Screen 0
BusID "PCI:1:0:1"
Option "DPMS"
EndSection
Section "Screen"
Identifier "screen1"
Device "device1"
Monitor "monitor1"
DefaultColorDepth 24
Subsection "Display"
Depth 8
Virtual 1280 1024
EndSubsection
Depth 15
Virtual 1280 1024
EndSubsection
Depth 16
Virtual 1280 1024
EndSubsection
Depth 24
Virtual 1280 1024
EndSubsection
EndSection
Section "Screen"
Identifier "screen2"
Device "device2"
Monitor "monitor2"
Depth 8
Virtual 1280 1024
EndSubsection
Depth 15
Virtual 1280 1024
EndSubsection
Depth 16
Virtual 1280 1024
EndSubsection
Depth 24
Virtual 1280 1024
EndSubsection
EndSection
Section "ServerLayout"
Identifier "layout1"
InputDevice "Keyboard1" "CoreKeyboard"
InputDevice "Mouse1" "CorePointer"
Screen "screen1"
Screen "screen2" RightOf "screen1"
Option "Xinerama" "on"
EndSection
