j’espère que tu parlais de xf86config-4.
donc voila le contenu :
Section "ServerLayout"
Identifier "XFree86 Configured"
Screen 0 "Screen0" 0 0
InputDevice "Keyboard0" "CoreKeyboard"
PS/2 Mouse using /dev/input/mice in Kernel 2.6
Serial Mouse not detected
InputDevice "USB Mouse" "CorePointer"
EndSection
Section "ServerFlags"
Option "AllowMouseOpenFail" "true"
EndSection
Section "Files"
RgbPath "/usr/X11R6/lib/X11/rgb"
ModulePath "/usr/X11R6/lib/modules"
FontPath "/usr/X11R6/lib/X11/fonts/misc:unscaled"
FontPath "/usr/X11R6/lib/X11/fonts/misc"
FontPath "/usr/X11R6/lib/X11/fonts/75dpi:unscaled"
FontPath "/usr/X11R6/lib/X11/fonts/75dpi"
FontPath "/usr/X11R6/lib/X11/fonts/100dpi:unscaled"
FontPath "/usr/X11R6/lib/X11/fonts/100dpi"
FontPath "/usr/X11R6/lib/X11/fonts/Speedo"
FontPath "/usr/X11R6/lib/X11/fonts/PEX"
Additional fonts: Locale, Gimp, TTF…
FontPath "/usr/X11R6/lib/X11/fonts/cyrillic"
FontPath "/usr/X11R6/lib/X11/fonts/latin2/75dpi"
FontPath "/usr/X11R6/lib/X11/fonts/latin2/100dpi"
True type and type1 fonts are also handled via xftlib, see /etc/X11/XftConfig!
FontPath "/usr/X11R6/lib/X11/fonts/Type1"
FontPath "/usr/share/fonts/ttf/western"
FontPath "/usr/share/fonts/ttf/decoratives"
FontPath "/usr/share/fonts/truetype"
FontPath "/usr/share/fonts/truetype/openoffice"
FontPath "/usr/share/fonts/truetype/ttf-bitstream-vera"
FontPath "/usr/share/fonts/latex-ttf-fonts"
FontPath "/usr/X11R6/lib/X11/fonts/defoma/CID"
FontPath "/usr/X11R6/lib/X11/fonts/defoma/TrueType"
EndSection
Section "Module"
Load "ddc" # ddc probing of monitor
Load "GLcore"
Load "dbe"
Load "dri"
Load "extmod"
Load "glx"
Load "bitmap" # bitmap-fonts
Load "speedo"
Load "type1"
Load "freetype"
Load "record"
EndSection
Section "InputDevice"
Identifier "Keyboard0"
Driver "keyboard"
Option "CoreKeyboard"
Option "XkbRules" "xfree86"
Option "XkbModel" "pc105"
Option "XkbLayout" "fr"
EndSection
Identifier "Serial Mouse"
Driver "mouse"
Option "Protocol" "Microsoft"
Option "Device" "/dev/ttyS0"
Option "Emulate3Buttons" "true"
Option "Emulate3Timeout" "70"
Option "SendCoreEvents" "true"
EndSection
Identifier "PS/2 Mouse"
Driver "mouse"
Option "Protocol" "auto"
Option "ZAxisMapping" "4 5"
Option "Device" "/dev/psaux"
EndSection
Identifier "USB Mouse"
Driver "mouse"
Option "Device" "/dev/input/mice"
Option "Protocol" "IMPS/2"
Option "Buttons" "5"
EndSection
Auto-generated by KNOPPIX mkxf86config
Section "Monitor"
Identifier "Monitor0"
Option "DPMS" "true"
VendorName "IQT"
ModelName "IQT217d"
HorizSync 31 - 80 # DDC-probed
VertRefresh 56 - 75 # DDC-probed
# These are the DDC-probed settings reported by your monitor.
# 640x480, 75.0Hz; hfreq=37.50, vfreq=75.00
ModeLine "640x480" 31.50 640 656 720 840 480 481 484 500 -hsync -vsync
# Extended modelines with GTF timings
# 640x480 @ 100.00 Hz (GTF) hsync: 50.90 kHz; pclk: 43.16 MHz
ModeLine "640x480" 43.16 640 680 744 848 480 481 484 509 -HSync +Vsync
# 768x576 @ 60.00 Hz (GTF) hsync: 35.82 kHz; pclk: 34.96 MHz
ModeLine "768x576" 34.96 768 792 872 976 576 577 580 597 -HSync +Vsync
# 768x576 @ 72.00 Hz (GTF) hsync: 43.27 kHz; pclk: 42.93 MHz
ModeLine "768x576" 42.93 768 800 880 992 576 577 580 601 -HSync +Vsync
# 768x576 @ 75.00 Hz (GTF) hsync: 45.15 kHz; pclk: 45.51 MHz
ModeLine "768x576" 45.51 768 808 888 1008 576 577 580 602 -HSync +Vsync
# 768x576 @ 85.00 Hz (GTF) hsync: 51.42 kHz; pclk: 51.84 MHz
ModeLine "768x576" 51.84 768 808 888 1008 576 577 580 605 -HSync +Vsync
# 768x576 @ 100.00 Hz (GTF) hsync: 61.10 kHz; pclk: 62.57 MHz
ModeLine "768x576" 62.57 768 816 896 1024 576 577 580 611 -HSync +Vsync
# 800x600 @ 100.00 Hz (GTF) hsync: 63.60 kHz; pclk: 68.18 MHz
ModeLine "800x600" 68.18 800 848 936 1072 600 601 604 636 -HSync +Vsync
# 1024x768 @ 100.00 Hz (GTF) hsync: 81.40 kHz; pclk: 113.31 MHz
ModeLine "1024x768" 113.31 1024 1096 1208 1392 768 769 772 814 -HSync +Vsync
# 1152x864 @ 60.00 Hz (GTF) hsync: 53.70 kHz; pclk: 81.62 MHz
ModeLine "1152x864" 81.62 1152 1216 1336 1520 864 865 868 895 -HSync +Vsync
# 1152x864 @ 85.00 Hz (GTF) hsync: 77.10 kHz; pclk: 119.65 MHz
ModeLine "1152x864" 119.65 1152 1224 1352 1552 864 865 868 907 -HSync +Vsync
# 1152x864 @ 100.00 Hz (GTF) hsync: 91.50 kHz; pclk: 143.47 MHz
ModeLine "1152x864" 143.47 1152 1232 1360 1568 864 865 868 915 -HSync +Vsync
# 1280x960 @ 72.00 Hz (GTF) hsync: 72.07 kHz; pclk: 124.54 MHz
ModeLine "1280x960" 124.54 1280 1368 1504 1728 960 961 964 1001 -HSync +Vsync
# 1280x960 @ 75.00 Hz (GTF) hsync: 75.15 kHz; pclk: 129.86 MHz
ModeLine "1280x960" 129.86 1280 1368 1504 1728 960 961 964 1002 -HSync +Vsync
# 1280x960 @ 100.00 Hz (GTF) hsync: 101.70 kHz; pclk: 178.99 MHz
ModeLine "1280x960" 178.99 1280 1376 1520 1760 960 961 964 1017 -HSync +Vsync
# 1280x1024 @ 100.00 Hz (GTF) hsync: 108.50 kHz; pclk: 190.96 MHz
ModeLine "1280x1024" 190.96 1280 1376 1520 1760 1024 1025 1028 1085 -HSync +Vsync
# 1400x1050 @ 60.00 Hz (GTF) hsync: 65.22 kHz; pclk: 122.61 MHz
ModeLine "1400x1050" 122.61 1400 1488 1640 1880 1050 1051 1054 1087 -HSync +Vsync
# 1400x1050 @ 72.00 Hz (GTF) hsync: 78.77 kHz; pclk: 149.34 MHz
ModeLine "1400x1050" 149.34 1400 1496 1648 1896 1050 1051 1054 1094 -HSync +Vsync
# 1400x1050 @ 75.00 Hz (GTF) hsync: 82.20 kHz; pclk: 155.85 MHz
ModeLine "1400x1050" 155.85 1400 1496 1648 1896 1050 1051 1054 1096 -HSync +Vsync
# 1400x1050 @ 85.00 Hz (GTF) hsync: 93.76 kHz; pclk: 179.26 MHz
ModeLine "1400x1050" 179.26 1400 1504 1656 1912 1050 1051 1054 1103 -HSync +Vsync
# 1400x1050 @ 100.00 Hz (GTF) hsync: 111.20 kHz; pclk: 214.39 MHz
ModeLine "1400x1050" 214.39 1400 1512 1664 1928 1050 1051 1054 1112 -HSync +Vsync
# 1600x1200 @ 100.00 Hz (GTF) hsync: 127.10 kHz; pclk: 280.64 MHz
ModeLine "1600x1200" 280.64 1600 1728 1904 2208 1200 1201 1204 1271 -HSync +Vsync
# 1920x1200 @ 60.00 Hz (GTF) hsync: 74.52; pclk: 193.16 MHz
Modeline "1920x1200" 193.16 1920 2048 2256 2592 1200 1201 1204 1242 -HSync +HSync
EndSection
Section "Device"
### Available Driver options are:-
sw_cursor is needed for some ati and radeon cards
#Option "sw_cursor"
#Option "hw_cursor"
#Option "NoAccel"
#Option "ShowCache"
#Option "ShadowFB"
#Option "UseFBDev"
#Option "Rotate"
Identifier "Card0"
The following line is auto-generated by KNOPPIX mkxf86config
Driver "vesa"
VendorName "All"
BoardName "All"
BusID "PCI:1:0:0"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Card0"
Monitor "Monitor0"
DefaultColorDepth 16
SubSection "Display"
Depth 1
Modes "640x480"
EndSubSection
Depth 4
Modes "640x480"
EndSubSection
Depth 8
Modes "640x480"
EndSubSection
Depth 15
Modes "640x480"
EndSubSection
Depth 16
Modes "640x480"
EndSubSection
Depth 24
Modes "640x480"
EndSubSection
Depth 32
Modes "640x480"
EndSubSection
EndSection
Section "DRI"
Mode 0666
EndSection
