File Name
Benchmark
Version 1.1.0
Width 1280
Height 1024
Anti-Aliasing None
Anti-Aliasing Quality 0
Texture Filtering Optimal
Anisotropic Level 1
VS Profile 3_0
PS Profile 3_0
Force full precision No
Disable HW shadow mapping No
Disable post-processing No
Force software vertex shader No
Color mipmaps No
Force software FP filtering No
Repeat tests Off
Fixed framerate Off
Comment
3DMark Score 7566 3DMarks
SM2.0 Score 3053
HDR/SM3.0 Score 4319
CPU Score 1503
Game Score N/A N/A
GT1 - Return To Proxycon 24,743 FPS SM2.0 Graphics Tests
GT2 - Firefly Forest 26,135 FPS SM2.0 Graphics Tests
CPU1 - Red Valley 0,475 FPS CPU Tests
CPU2 - Red Valley 0,761 FPS CPU Tests
HDR1 - Canyon Flight 53,390 FPS HDR/SM3.0 Graphics Tests
HDR2 - Deep Freeze 32,999 FPS HDR/SM3.0 Graphics Tests
Fill Rate - Single-Texturing 0,000 N/A N/A Feature Tests
Fill Rate - Multi-Texturing 0,000 N/A N/A Feature Tests
Pixel Shader 0,000 N/A N/A Feature Tests
Vertex Shader - Simple 0,000 N/A N/A Feature Tests
Vertex Shader - Complex 0,000 N/A N/A Feature Tests
Shader Particles (SM3.0) 0,000 N/A N/A Feature Tests
Perlin Noise (SM3.0) 0,000 N/A N/A Feature Tests
8 Triangles 0,000 N/A N/A Batch Size Tests
32 Triangles 0,000 N/A N/A Batch Size Tests
128 Triangles 0,000 N/A N/A Batch Size Tests
512 Triangles 0,000 N/A N/A Batch Size Tests
2048 Triangles 0,000 N/A N/A Batch Size Tests
32768 Triangles 0,000 N/A N/A Batch Size Tests
System Info
Version 3,12
CPU Info
Physical Processors 1
Logical Processors 2
Central Processing Units
Manufacturer AMD
Family AMD Athlon(tm) 64 X2 Dual Core Processor 3800+
Architecture 64-bit
Internal Clock 1990 MHz
Internal Clock Maximum 1990 MHz
External Clock 200 MHz
Socket Designation CPU 1
Type
Upgrade Socket 939
MultiCore 2 Processor Cores
HyperThreadingTechnology N/A
Capabilities MMX, CMov, RDTSC, 3DNow!, Extended 3DNow!, SSE, SSE2, SSE3, PAE, NX
Version AMD Athlon(tm) 64 X2 Dual Core Processor 3800+
Caches Level Capacity Type Type Details Error Correction Type Associativity
1 64 KB Data, Internal Pipeline Burst Single-bit ECC 4-way Set-Associative
2 512 KB Instruction, Data, Internal Pipeline Burst Single-bit ECC 4-way Set-Associative
3 0 B Disabled at Boot, Internal
CPUIDs EAX EBX ECX EDX Order
0x00000001 0x68747541 0x444d4163 0x69746e65 0
0x00020fb1 0x00020800 0x00000001 0x178bfbff 1
Ext CPUIDs EAX EBX ECX EDX Order
0x80000018 0x68747541 0x444d4163 0x69746e65 0
0x00020fb1 0x00000150 0x00000003 0xe3d3fbff 1
0x20444d41 0x6c687441 0x74286e6f 0x3620296d 2
0x32582034 0x61754420 0x6f43206c 0x50206572 3
0x65636f72 0x726f7373 0x30383320 0x00002b30 4
0xff08ff08 0xff20ff20 0x40020140 0x40020140 5
0x00000000 0x42004200 0x02008140 0x00000000 6
0x00000000 0x00000000 0x00000000 0x0000000f 7
0x00003028 0x00000000 0x00000001 0x00000000 8
0x00000000 0x00000000 0x00000000 0x00000000 9
0x00000000 0x00000000 0x00000000 0x00000000 10
0x00000000 0x00000000 0x00000000 0x00000000 11
0x00000000 0x00000000 0x00000000 0x00000000 12
0x00000000 0x00000000 0x00000000 0x00000000 13
0x00000000 0x00000000 0x00000000 0x00000000 14
0x00000000 0x00000000 0x00000000 0x00000000 15
DirectX Info
Version 9.0c
Long Version 4.09.00.0904
DirectDraw Info
Version 5.03.2600.5512
Primary Device ATI Radeon HD 4800 Series
Linked Display Adapters FAUX
Display Devices
Display Device
Description ATI Radeon HD 4800 Series
Manufacturer ATI Technologies Inc.
Total Local Video Memory 1030 MB
Total Local Texture Memory 1030 MB
AGP Aperture Size 117 MB
Driver File ati2dvag.dll
Driver Version 6.14.10.6891
Driver Details 8.561-081201a1-072274C-ATI
Driver Date 01/12/2008
Driver WHQL Certified VRAI
Max Texture Width 8 Kpx
Max Texture Height 8 Kpx
Max User Clipping Planes 6
Max Active Hardware Lights 8
Max Texture Blending Stages 8
Fixed Function Textures In Single Pass 8
Vertex Shader Version 3
Pixel Shader Version 3
Max Vertex Blend Matrices 37
Max Texture Coordinates 8
PCI
Name ATI Radeon HD 4800 Series
Vendor ID 0x1002
Device ID 0x9440
SubSystem ID 0x24411682
Revision ID 0x0000
Bus
Type PCI Express
Revision 2
Enabled VRAI
Rate 16
Sideband Addressing Not Supported
Fast Write Not Supported
Texture Formats
32-bit ARGB [8888]
32-bit RGB [888]
16-bit RGB [565]
16-bit RGB [555]
16-bit ARGB [1555]
16-bit ARGB [4444]
8-bit A [8]
8-bit YUV [800]
16-bit AYUV [8800]
8-bit AYUV [4400]
FourCC [DXT1]
FourCC [DXT2]
FourCC [DXT3]
FourCC [DXT4]
FourCC [DXT5]
Capabilities AGP Texturing, Hardware Transform and Lighting, Positional Lights, Subpixel Accurate Rasterizing, Stencil Buffers, Range Fog, Table Fog, Vertex Fog, W-Fog, Specular Gouraud Shading, Anisotropic Filtering, Bilinear Filtering, Point Sampling, Trilinear Filtering, Additive Texture Blending, Dot3 Texture Blending, Multiplicative Texture Blending, Subtractive Texture Blending, Environmental Bump Mapping, Environmental Bump Mapping With Luminance, Cube Mapping, Factor Alpha Blending, Vertex Alpha Blending, Texture Alpha Blending, Texture Clamping, Texture Mirroring, Texture Wrapping, Guard Band Support, Mipmap LOD Bias Adjustment, Projected Textures, Volume Textures, Point Primitive Support, Full-Screen Anti-Aliasing, DXT Compressed Textures, Two Sided Stencil Test, Mipmapped Volume Textures, Mipmapped Cube Textures, Texture Border Color, Spherical Mapping, Automatic Mipmap Generation, Hardware Rasterization, Shading, Transform and Lighting, Scissor Test, Legacy Depth Bias
VGA Memory Clock 4500 KHz
VGA Core Clock 9 MHz
Max VGA Memory Clock 0 Hz
Max VGA Core Clock 0 Hz
DirectShow Info
Version 6.05.2600.5512
Registered DirectShow Filters
.RAM file Parser
AC3 Parser Filter
ACELP.net Sipro Lab Audio Decoder
ACM Wrapper
ASF ACM Handler
ASF DIB Handler
ASF DJPEG Handler
ASF ICM Handler
ASF JPEG Handler
ASF URL Handler
ASF embedded stuff Handler
ASX file Parser
ASX v.2 file Parser
ATI MPEG Video Decoder
ATI Media Center Audio Encoder
ATI Media Center Multiplexer
ATI Media Center Video Encoder
ATI Time Shift Reader
ATI Time Shift Splitter
ATI VCR Stream Source
AVI Decompressor
AVI Draw
AVI Splitter
AVI/WAV File Source
BDA MPEG2 Transport Information Filter
Color Space Converter
DV Muxer
DV Splitter
DV Video Decoder
Decrypt/Tag
Default DirectSound Device
Default MidiOut Device
Dtrameur dcalage BDA
File Source (Async.)
File Source (Netshow URL)
File Source (URL)
File stream renderer
Filtre BDA MPE
Indeo audio software
Indeo video 4.4 Decompression Filter
Indeo video 5.10 Decompression Filter
Internal Script Command Renderer
Line 21 Decoder
Line 21 Decoder 2
MIDI Parser
MJPEG Decompressor
MPEG Audio Decoder
MPEG Layer-3 Decoder
MPEG Video Decoder
MPEG-2 Demultiplexer
MPEG-2 Sections and Tables
MPEG-2 Splitter
MPEG-I Stream Splitter
Microsoft MPEG-4 Video Decompressor
Microsoft Screen Video Decompressor
Multi-file Parser
NSC file Parser
Overlay Mixer2
QT Decompressor
QuickTime Movie Parser
SAMI (CC) Parser
VBI Surface Allocator
VGA 16 Color Ditherer
Video Port Manager
Video Renderer
WM ASF Reader
WM ASF Writer
WST Decoder
Wave Parser
Windows Media Audio Decoder
Windows Media Multiplexer
Windows Media Update Filter
Windows Media Video Decoder
Windows Media source filter
XML Playlist
DirectSound Info
Version 5.3.2600.5512
Speaker Configuration Surround
Speaker Geometry
Primary Device Realtek AC97 Audio
Sound Devices
Sound Device
Description Realtek AC97 Audio
Manufacturer Realtek
Driver File ALCXWDM.SYS
Driver Version 5.10.0.6300
Driver Date 24/09/2008
Max Supported 3D Hardware Sounds 26
PCI
Name Realtek AC'97 Audio
Vendor ID 0x1002
Device ID 0x4370
SubSystem ID 0xd0081631
Revision ID 0x0001
Capabilities Continuous Rate, Primary Buffer with 16-bit Samples, Primary Buffers with 8-bit Samples, Monophonic Primary Buffers, Stereo Primary Buffers, Hardware-mixed Secondary Buffers with 16-bit Samples, Hardware-mixed Secondary Buffers with 8-bit Samples, Hardware-mixed Monophonic Secondary Buffers, Hardware-mixed Stereo Secondary Buffers
HD Audio Support FAUX
EAX Support Supported
Memory Info
Total Physical Memory 3040 MB
Free Physical Memory 2541 MB
Total Pagefile Memory 4415 MB
Free Pagefile Memory 3971 MB
Memory Arrays
Memory Array
Max Module Capacity 8 MB
Location System Board
Use System
Supported Error DC
Supported Speeds
Supported Types
Supported Voltages
Memory Slots
Motherboard Info
Supported Slot Types ISA, PCI, PCI Express
Manufacturer NEC COMPUTERS INTERNATIONAL
Model MS-7168
Version 1
BIOS Vendor American Megatrends Inc.
BIOS Version 80012
BIOS Release Date 06/09/2005
BIOS Properties Plug and Play, Flash
Card Slots Order Designation Type Characteristics Data Bus Width Details Device Class Manufacturer Driver File Driver Version Driver Date Name Vendor ID Device ID SubSystem ID Revision ID IRQ
1 PCIE16X1 PCI Express 3.3V, Shared, PME Signal 0 b Available, Long 0x0000 0x0000 0x00000000 0x0000
2 PCIE1X PCI Express 3.3V, Shared, PME Signal 0 b Available, Long 0x0000 0x0000 0x00000000 0x0000
3 PCI1 PCI 3.3V, Shared, PME Signal 32 b Available, Short 0x0000 0x0000 0x00000000 0x0000
4 PCI2 PCI 3.3V, Shared, PME Signal 32 b In Use, Short 0x0000 0x0000 0x00000000 0x0000
PCI Devices Manufacturer Location Type Name Vendor ID Device ID SubSystem ID Revision ID
(Standard mass storage controllers) AXWHISKY SCSI Controller 0x0000 0x0000 0x00000000 0x0000
Realtek Bus PCI 0, priphrique 20, fonction 5 Realtek AC'97 Audio 0x1002 0x4370 0xd0081631 0x0001
(Priphriques systme standard) Bus PCI 0, priphrique 20, fonction 4 Pont PCI vers PCI standard PCI 0x1002 0x4371 0x00000000 0x0000
ATI Technologies Inc Bus PCI 0, priphrique 20, fonction 0 ATI SMBus 0x1002 0x4372 0xd0081631 0x0010
(Contrleur hte USB standard) Bus PCI 0, priphrique 19, fonction 2 Contrleur hte PCI vers USB standard tendu 0x1002 0x4373 0xd0081631 0x0000
(Contrleur hte USB standard) Bus PCI 0, priphrique 19, fonction 0 Contrleur hte USB OpenHCD standard 0x1002 0x4374 0xd0081631 0x0000
(Contrleur hte USB standard) Bus PCI 0, priphrique 19, fonction 1 Contrleur hte USB OpenHCD standard 0x1002 0x4375 0xd0081631 0x0000
Advanced Micro Devices Bus PCI 0, priphrique 20, fonction 1 AMD PCI IDE Controller 0x1002 0x4376 0xd0081631 0x0000
(Priphriques systme standard) Bus PCI 0, priphrique 20, fonction 3 Pont ISA standard PCI 0x1002 0x4377 0x00000000 0x0000
(Contrleurs ATA/ATAPI IDE standard) Bus PCI 0, priphrique 18, fonction 0 Contrleur IDE standard double canal PCI 0x1002 0x4379 0xd0081631 0x0000
(Contrleurs ATA/ATAPI IDE standard) Bus PCI 0, priphrique 17, fonction 0 Contrleur IDE standard double canal PCI 0x1002 0x437a 0xd0081631 0x0000
(Priphriques systme standard) Bus PCI 0, priphrique 0, fonction 0 Pont CPU hte standard PCI 0x1002 0x5950 0x00000000 0x0010
(Priphriques systme standard) Bus PCI 0, priphrique 2, fonction 0 Pont PCI vers PCI standard PCI 0x1002 0x5a34 0x00000000 0x0000
ATI Technologies Inc. Bus PCI 1, priphrique 0, fonction 0 ATI Radeon HD 4800 Series 0x1002 0x9440 0x24411682 0x0000
Microsoft Bus PCI 1, priphrique 0, fonction 1 Pilote de bus Microsoft UAA pour High Definition Audio 0x1002 0xaa30 0xaa301682 0x0000
(Priphriques systme standard) Bus PCI 0, priphrique 24, fonction 0 Pont CPU hte standard PCI 0x1022 0x1100 0x00000000 0x0000
(Priphriques systme standard) Bus PCI 0, priphrique 24, fonction 1 Pont CPU hte standard PCI 0x1022 0x1101 0x00000000 0x0000
(Priphriques systme standard) Bus PCI 0, priphrique 24, fonction 2 Pont CPU hte standard PCI 0x1022 0x1102 0x00000000 0x0000
(Priphriques systme standard) Bus PCI 0, priphrique 24, fonction 3 Pont CPU hte standard PCI 0x1022 0x1103 0x00000000 0x0000
Realtek Semiconductor Corp. Bus PCI 2, priphrique 3, fonction 0 Realtek RTL8139/810x Family Fast Ethernet NIC 0x10ec 0x8139 0xd0081631 0x0010
VIA Bus PCI 2, priphrique 4, fonction 0 Contrleur hte compatible IEE 1394 VIA OHCI 0x1106 0x3044 0xd0081631 0x0080
ASUSTeK Bus PCI 2, priphrique 1, fonction 0 ASUSTeK Tiger Capture Device 0x1131 0x7133 0x48571043 0x00d0
System Devices Manufacturer Name Vendor ID Device ID SubSystem ID Revision ID
(Priphriques systme standard) Pont PCI vers PCI standard PCI 0x1002 0x4371 0x00000000 0x0000
ATI Technologies Inc ATI SMBus 0x1002 0x4372 0xd0081631 0x0010
(Priphriques systme standard) Pont ISA standard PCI 0x1002 0x4377 0x00000000 0x0000
(Priphriques systme standard) Pont CPU hte standard PCI 0x1002 0x5950 0x00000000 0x0010
(Priphriques systme standard) Pont PCI vers PCI standard PCI 0x1002 0x5a34 0x00000000 0x0000
(Priphriques systme standard) Pont CPU hte standard PCI 0x1022 0x1100 0x00000000 0x0000
(Priphriques systme standard) Pont CPU hte standard PCI 0x1022 0x1101 0x00000000 0x0000
(Priphriques systme standard) Pont CPU hte standard PCI 0x1022 0x1102 0x00000000 0x0000
(Priphriques systme standard) Pont CPU hte standard PCI 0x1022 0x1103 0x00000000 0x0000
AGP
Revision
Rate
Available Rate 0x00000000
Selected Rate 0x00000000
Aperture Size 0 B
Sideband Addressing
EnumValue
String
Hex 0x00000000
Fast Write
EnumValue
String
Hex 0x00000000
USB Devices Description Driver Date Driver Version Device Class
Concentrateur USB racine 01/07/2001 5.1.2600.5512 Universal Serial Bus Controller
Hewlett-Packard ScanJet 3300C 01/07/2001 5.1.2600.0 Imaging Device
Priphrique USB composite 01/07/2001 5.1.2600.0 Universal Serial Bus Controller
Prise en charge d'impression USB 01/07/2001 5.1.2600.0 Universal Serial Bus Controller
HP Photosmart 8000 Series (DOT4USB) 25/01/2007 10.1.1.3 Universal Serial Bus Controller
Priphrique de stockage de masse USB 01/07/2001 5.1.2600.0 Universal Serial Bus Controller
Priphrique d'interface utilisateur USB 01/07/2001 5.1.2600.5512 Human Interface Device
FireWire Devices
FireWire Device
Description Carte rseau 1394
Driver Date 01/07/2001
Driver Version 5.1.2535.0
Device Class Network Adapter
Monitor Info
Monitors
Monitor
Name cran Plug-and-Play
Manufacturer (Types d'crans standard)
Max Width 1600 px
Max Height 1200 px
Power Supply Info
Batteries
Operating System Info
Name Microsoft Windows XP
Version 5.1.2600
PlatformId 2
Service Pack
Version 3
Name Service Pack 3
Suite 768
Product Type 1
Media Center FAUX
Windows Environment 32-bit
DEP
Hardware Support VRAI
Applications Protected VRAI
Drivers Protected VRAI
User Option On for essential Windows programs and services only
Locale FR
Desktop Width 1024 px
Desktop Height 768 px
Desktop BPP 32 b
Internet Explorer Version 75730
Applications
Scanning your system configuration
3DMark06 - Professional Edition
AMD:CCC-AEMCapturingWindow
Processes Name PID Memory Usage
System Idle Process 0 28 KB
System 4 244 KB
smss.exe 604 388 KB
csrss.exe 656 4144 KB
winlogon.exe 700 4268 KB
services.exe 744 3612 KB
lsass.exe 756 1664 KB
ati2evxx.exe 928 3252 KB
svchost.exe 944 4836 KB
svchost.exe 1060 4260 KB
svchost.exe 1160 28 MB
svchost.exe 1228 3552 KB
ati2evxx.exe 1336 3844 KB
svchost.exe 1480 4440 KB
aswUpdSv.exe 1532 252 KB
ashServ.exe 1600 14 MB
explorer.exe 1756 24 MB
ashDisp.exe 212 2572 KB
soundman.exe 220 3856 KB
spoolsv.exe 312 5 MB
issch.exe 352 2332 KB
MOM.exe 412 3368 KB
ctfmon.exe 432 4716 KB
SuperCopier2.exe 460 4652 KB
HOMERunner.exe 508 4576 KB
SetPoint.exe 648 10 MB
CCC.exe 1436 8 MB
KHALMNPR.exe 1648 6 MB
MDM.EXE 2448 2840 KB
PnkBstrA.exe 2560 2468 KB
svchost.exe 2648 5 MB
ashMaiSv.exe 2936 1040 KB
ashWebSv.exe 2960 10 MB
alg.exe 3408 3552 KB
3DMark06.exe 1972 41 MB
verclsid.exe 3692 4288 KB
wmiprvse.exe 3816 6 MB
Logical Drives Drive Letter Label Type Capacity Available
A: Floppy 0 B 0 B
C: Hard Disk 149 GB 70 GB
D: MesDocument Hard Disk 149 GB 59 GB
E: SAUVEGARDE Hard Disk 298 GB 152 GB
F: CD-ROM 0 B 0 B
G: Floppy 0 B 0 B
H: Floppy 0 B 0 B
I: Floppy 0 B 0 B
J: Floppy 0 B 0 B
K: Floppy 0 B 0 B
L: CD-ROM 0 B 0 B
Storage Devices Device Drive Type Name Manufacturer Model Vendor ID String Product ID String Product Revision String Serial Number Interface Type Device Bus Type Capacity Drive Letters CD Max Read Speed CD Read Capabilities CD Write Capabilities DVD Read Capabilities DVD Write Capabilities SMART Acoustic Management
Hard Disk ST3160023AS (Lecteurs de disque standard) ST3160023AS ST316002 ST3160023AS 3 4LJ22VNM IDE SATA 149 GB C: 0 Supported (disabled) Not Supported
Hard Disk ST3160023AS (Lecteurs de disque standard) ST3160023AS ST316002 ST3160023AS 3 4LJ22G3A IDE SATA 149 GB D: 0 Supported (disabled) Not Supported
Hard Disk <unknown> <unknown> <unknown> Generic USB CF Reader 1,01 <unknown> USB 0 B 0 Not Supported Not Supported
Hard Disk <unknown> <unknown> <unknown> Generic USB MS Reader 1,03 <unknown> USB 0 B 0 Not Supported Not Supported
Hard Disk <unknown> <unknown> <unknown> Generic USB SD Reader 1 <unknown> USB 0 B 0 Not Supported Not Supported
Hard Disk <unknown> <unknown> <unknown> Generic USB SM Reader 1,02 <unknown> USB 0 B 0 Not Supported Not Supported
Hard Disk <unknown> <unknown> <unknown> HP Photosmart 8000 1 <unknown> USB 0 B 0 Not Supported Not Supported
Hard Disk WD 3200JB External USB Device (Lecteurs de disque standard) WD 3200JB External USB Device WD 3200JB External 107 USB USB 298 GB E: 0 Not Supported Not Supported
DVD _NEC DVD_RW ND-3530A (Lecteurs de CD-ROM standard) _NEC DVD_RW ND-3530A _NEC _NEC DVD_RW ND-3530A 2,01 <unknown> ATA 0 B F: 0 +R, -RW, +RW -R, +R, -RW, +RW Not Supported Not Supported
DVD <unknown> <unknown> <unknown> AXV CD/DVD-ROM 2.0B <unknown> SCSI 0 B 0 -R, -RW -ROM, -R, +RW, -RAM Not Supported Not Supported
