Faut voir combien de temps elle est garantie, m’enfin contacte les tout de même :jap: .
Voici mon pathétique anglais xD:
I bought a power supply TX 650W one years and eight days ago. I have lot of problem with my computer and after some test i saw like OCCT test my power supply turn at 12,8V - 12,9V but ATX’s norm is 12V.
My problem is when i’m playing(or not) the computer goes to sleep and red led switch on in my graphic card. Ventilation’s graphic card go so fast and i can’t make anything
I bought a power supply TX 650W one years and eight days ago. I have lot of problems with my computer and after some test i saw as OCCT test my power supply turn at 12,8V - 12,9V but ATX’s norm is at 12,6V.
My problem is when i’m playing(or not) the computer shuts down and red led switch on on (paye ta répétition :paf: mais ça se dit comme ça
) my graphic card. The ventilation of my graphic card go so fast and i can make nothing.
Voilà j’ai fait quelques petites corrections, pour moi ça se dit mieux, mais en gros c’est ça. Tu peux fournir en plus ton graph’ et ton support va sûrement pouvoir marcher.
Voila c’est envoyé. Merci à vous deux pour vos réponses je vous dis quoi incessamment sous peu ![]()
Ouch … pas fort les gars au niveau de la langue universelle…
Hi,
I bought a power supply TX 650W one years and eight days ago. Since I’ve got this power supply unit, I had lot of problems with my computer. After some tests with the OCCT Power Supply Test, the 12V rail of the unit is measured at 12,8V - 12,9V while the ATX’s norm authorizes a 12,6V limit.
My problem is when the PC is in operation, it shuts down by itself and a red led turns on on my graphics card. The rotation speed of the fansink goes faster and the PC is blocked. There is nothing I can do to debug the computer. I have to turn off the power supply switch and then turn it on to make the computer restart.
Can you please guide me to a solution or, if there is none, through a RMA process ?
Thank you very much.
[votre nom]
C’est un peu mieux.
Damn, j’ai poster trop tard. Pauvre gars qui va lire ca a l’autre bout. OUch…
Edité le 23/02/2011 à 19:21
xD il va même pas le lire j’pense
En effet …
Comment pouvez vous faire en france pour pas savoir l’Anglais alors que l’Angleterre est directement de l’autre cote de la Manche ? Ca, je l’ai toujours pas compris … lol
Simplement parce qu’en cours on nous apprend l’anglais à partir du CM2 (à mon époque xD), et que l’on nous apprend à lire des textes et non pas à parler ou écrire anglais :s système scolaire français dégueulasse comparait aux autres systèmes comme par exemple la hollande où ils parlent 2 voir 3 langues :x
Ah fait le truc vite fait, pour un faceux c’est la honte je sais [:shy]. [quote=« benji_l »]
[/quote]
La France au niveau de l’éducation, il n’y a pas mieux :ane: .
eee quoi ?
Un mec qui va à la fac quoi [:shy].
Edité le 23/02/2011 à 20:30
C’est quoi la face ?
Enlève le e, j’ai fait une faute. En gros c’est l’université, les études supérieures quoi [:dago].
aaa la FAC a ok
aaa la FAC a ok
Désolé de t’avoir embrouiller :ane: .
Ah ah pas grave. Je connais juste tres peu le systeme francais
Je vous avoue que le quebec ca doit etre encore pire.
Bonjour me revoici après quelques semaines d’absences (dû au temps du SAV), ils ne se sont pas « embêtés » et m’ont renvoyés une nouvelle alim (plus la TX650W mais la TX650 V2 sa remplacante je présume), j’ai fait les test OCCT de suite et voici les résultats:
http://img4.hostingpics.net/pics/6588922011031617h20CPU1.png
http://img4.hostingpics.net/pics/5323632011031617h20CPU2.png
http://img4.hostingpics.net/pics/3052962011031617h20GPU1.png
http://img4.hostingpics.net/pics/8306022011031617h20VCore.png
http://img4.hostingpics.net/pics/6089742011031617h20Volt3.png
http://img4.hostingpics.net/pics/6678282011031617h20Volt5.png
http://img4.hostingpics.net/pics/1456672011031617h20Volt12.png
Je présume donc que je dois acheter un Onduleur et que le problème provient de chez moi et non de l’alim? ou tout est en ordre la?
Merci d’avance ![]()
Essaie de tester les tensions avec un voltmètre, il y a souvent des erreurs avec OCCT.
je mets le volmetre a quel niveau ?
20 V si j’ai bien compris ta question
tuto
Edité le 16/03/2011 à 21:21
