Probleme avec un formulaire en mailto!
salut a tous
j’ai un probleme avec se formulaire:
<html?#62;
<head>
  <title>Formulaire</title>
</head>
<body style="background-color: rgb(255, 255, 255);">
<form
 action="mailto:webmaster@toutjavascript.com?subject=Message%20en%20mailto"
 name="envoi" method="post" enctype="text/plain"><font
 color="#000099" face="Arial" size="-1">
  </font>
  <p><font color="#000099" face="Arial" size="-1"><font
 color="#000099" face="Arial" size="-1"><b><span
 style="color: rgb(0, 0, 0);">Pseudo
:</span> </b><input name="Pseudo "
 value="Votre Pseudo "></font></font></font></p>
 color="#000099" face="Arial" size="-1"><b>Age
: <input name="Age : " value="Votre Age "></b></font></font></p>
 color="#000099" face="Arial" size="-1"><b>Email
: <input name="Email : " value="Votre Email"></b></font></font></p>
 color="#000099" face="Arial" size="-1"><b>Pays
: <input name="Pays : " value="Votre Pays"></b></font></font></p>
 color="#000099" face="Arial" size="-1"><b>Connexion
: <input name="Connexion : "
 value="Votre Connexion internet"></b></font></font></p>
 color="#000099" face="Arial" size="-1"><b>Exp&eacute;rience
: <input name="Exp&eacute;rience : " value="Votre Exp&eacute;rience "></b></font></font></p>
 color="#000099" face="Arial" size="-1"><b>Disponibilit&eacute;
:  </b><font color="#000099" face="Arial"
 size="-1"><input name="forum" value="oui"
 type="radio"> </font><font face="Arial"
 size="2">Week-</font><font face="Arial"
 size="2">e</font><font face="Arial" size="2">nd
et Soir</font><font color="#000099" face="Arial"
 size="-1"> <input name="forum" value="non"
 size="-1"><input name="forum" value="non"
 type="radio"></font><font face="Arial"
 size="2"> Soir</font><font color="#000099"
 face="Arial" size="-1"> </font></font></font></p>
 color="#000099" face="Arial" size="-1"><b>Les
jeux:  </b><input name="forum" value="oui"
 type="radio">Battlefield 2   <input name="forum"
 value="non" type="radio">Counter Strike
 type="radio"> Counter Strike Source
 type="radio"> Warcraft III </font></font></p>
  <input value="Envoyer" onclick="Envoyer(this.form)"
 type="button"><br>
  </font>
  </font></font>
  <hr><font color="#000099" face="Arial"
 size="-1"><font color="#000099" face="Arial"
 size="-1"><br>
  </font></font></font></form>
</body>
</html?#62;
il ne vais pas s’envoyer par mailto!quand je clique sur le bouton "envoyer" il ne se passe rien!pourquoi??merci de m’aider A+
Le clique sur le bouton appelle une fonction Js nommée Envoyer(…) qui prend un formulaire en paramètre.
Cette fonction n’existe pas dans ton code.
OMG ^^ c’est pas propre ce code :slight_smile: Voilà une version BEAUCOUP plus clean :slight_smile:
<html>
<head>
<style type="text/css">
p{
	color: blue;
	font-size:12px;
	font-weight:bold;
	font-family:arial;
input{
	color:green;
	font-size:12px;
	font-family:verdana;
li{
list-style-type:none;
</style>
</head>
<body>
<form method="post" action="mailto:tonadresse@tonfai.tld" name="Adhésion" ENCTYPE="text/plain">
<p>Pseudo : <input name="Pseudo" value="Votre Pseudo "></p>
<p>Age : <input name="Age" value="Votre Age "></p>
<p>Email : <input name="Email" value="Votre Email"></p>
<p>Pays : <input name="Pays" value="Votre Pays"></p>
<p>Connexion : <input name="Connexion" value="Connexion internet"></p>
<p>Expérience :<br /><textarea cols="50" rows="5">Décrivez vos expériences en matière de jeu vidéo;)</textarea></p>
<p>Disponibilité :</p>
<ul>
	<li><input name="dispo" value="we+soir" type="radio">Week-end et Soir</li>
	<li><input name="dispo" value="we" type="radio">Week-end</li>
	<li><input name="dispo" value="soir" type="radio">Soir</li>
</ul>
<p>Les jeux :</p>
<ul>
	<li><input name="games" value="BF2" type="checkbox">Battlefield 2</li>
	<li><input name="games" value="CS" type="checkbox">Counter Strike</li>
	<li><input name="games" value="CS:S" type="checkbox">Counter Strike Source</li>
	<li><input name="games" value="War3" type="checkbox"> Warcraft III</li>
</ul>
<input value="Envoyer" type="submit">
</form>
</body>
</html>
S’il y a des trucs que tu ne comprends pas dedans… A noter que pour le mailto: il faut naturellement un client mail (outlook, thunderbird) d’installé sur la machine pour que cela fonctionne :slight_smile:
merci!!
encore besoin de votre aide!!
voila j’ai trouve se script qui sere a se connecter a une page protege par un login et un mot de passe mais je ne sais pas comment cree d’aute compte sur se script!
voila merci A++
<html>
<head>
  <title>Tout JavaScript.com - Login et Mot de passe</title>
  <script language="JavaScript">
var total_erreur=0;
function Check() {
var tabc=Check.arguments; var ok=0;
var tab=" azertyuiopqsdfghjklmwxcvbnAZERTYUIOPQSDFGHJKLMWXCVBN0123456789_$&#@";
for (var no=0;no<tabc.length;no++) {
checksum=tabc[no];
// table des caracters autorises
var login=document.forms["flog"].elements["login"].value;
var password=document.forms["flog"].elements["password"].value;
var nblog=login.length;
var nbpass=password.length;
var sum=1;
var n=Math.max(nblog,nbpass)
for (var i=0;i<n;i++) {
var index1=tab.indexOf(login.substring(i,i+1))+10;
var index2=tab.indexOf(password.substring(i,i+1))+10;
sum=sum+(index1*n*(i+1))*(index2*(i+1)*(i+1));
// calcul de la checksum. La fonction est modifiable !
if (sum==checksum) {window.location=login+".html"; ok=1; no=100;}
// test de la checksum
if (ok==0) {
total_erreur++; alert("Mauvais login ou mot de passe");
if (total_erreur>2) { // apres 3 essais, redirection...
alert("Vous avez atteint les 3 essais !\nVous allez voir la page d'explication");
window.location="passlog2.html";
function Verifie() {
Check(3498440,4367299)
  </script>
</head>
 alink="#000066" link="#000066" vlink="#000066">
</font>
<center><font color="#000099" face="Arial"
 size="-1"><br>
</font>
<form onsubmit="Verifie();return false;" action="#"
 method="get" name="flog"><font color="#000099"
  <table border="0">
    <tbody>
      <tr>
        <td><font face="arial" size="2">LOGIN
: </font></td>
        <td><input name="login" size="8"
 type="text"></td>
      </tr>
      <tr>
        <td><font face="arial" size="2">PASSWORD
: </font></td>
        <td><input name="password" size="8"
 type="text"></td>
      </tr>
      <tr>
        <td colspan="2" align="center"><input
 name="bouton" value="Entrer" type="submit"></td>
      </tr>
    </tbody>
  </table>
  </font><br>
</form>
</center>
 size="-1"><a href="http://www.toutjavascript.com"><font
 color="#ccccff" face="arial" size="1">Tout
JavaScript.com</font></a></font></center>
</body>
</html>
Peut être faudrait-il lire tout ce qui est écrit sur le site qui donne ces javascripts, et éventuellement demander à l’auteur ?
PS : javascript == pas sécurisé :slight_smile:
et tu me conseille quoi??
ben php ^^
le javascript fonctionne côté client, et donc par conséquent sa sécurité est connue… côté client :slight_smile: tu vois le genre de problèmes que ca cause : on peut lire le mot de passe avec plus ou moins de facilité :slight_smile:
merci et comme script en php tu en connait pour une partie membre??
