Probleme avec Nero 6 - Avec InCD plus precisement
Salut et bonne année à tous :slight_smile:
Voila, j’ai un gros probleme avec InCD se trouvant dans ma version 6 de Nero. En faite tout c’est bien installé dans la suite SAUF InCD, c’est aussi simple que ça. Dans le dossier InCD, dans le dossier Nero 6 du dossier Programs Files, il y a uniquement deux fichier que voici: SrvError.log et Error.log.
Pour le premiers fichier je vais faire court et le coupé car ce serait trop longt. Voici une partie:
0578 05:12:26 17:45:04:15 e=0. Suspected firmware defect: media capacities re
turned by command 82 and command 37 do not match.
0578 05:12:26 17:45:04:15 e=0. Suspected firmware defect: Failed to guess cor
rect value.
0578 05:12:26 17:45:04:10 e=22497. Not mounting UDF disc read-only because na
tive reader is present.()
0578 05:12:26 17:45:04:10 e=22021. Could not mount subfile system for volume.
0544 05:12:27 02:19:45:13 e=0. Enqueing Notify: iDrive=FFFFFFFFh u32Info=0h e
vt=9h (kevtShutdown)
0544 05:12:27 02:19:45:15 e=0. Terminating User FS server.
0544 05:12:27 02:19:45:15 e=0. UserFS Server terminating.
0544 05:12:27 02:19:50:15 e=0. Terminating IPC servers.
0544 05:12:27 02:19:50:24 e=1686. Attempt to stop IPC server which is not up.
0544 05:12:27 02:19:50:09 e=1686. Attempt to stop IPC server which is not up.
0544 05:12:27 02:19:50:19 e=1686. Attempt to stop IPC server which is not up.
0544 05:12:27 02:19:50:19 e=0. Terminating FS server.
0548 05:12:27 15:21:30:18 e=0. SetEnumErrLevel: errorlevel is 1 [Dflt]
0548 05:12:27 15:21:30:18 e=0. Setting up notifier.
0548 05:12:27 15:21:30:18 e=0. Notifier is running.
0548 05:12:27 15:21:30:18 e=0. Starting file system manager.
0548 05:12:27 15:21:30:18 e=0. Connecting to kernel FS.
0548 05:12:27 15:21:30:18 e=0. Resetting FSD.
0548 05:12:27 15:21:30:18 e=0. Mounting drives.
0548 05:12:27 15:21:30:18 e=0. File system manager started.
0548 05:12:27 15:21:30:18 e=0. Starting IPC class servers.
0548 05:12:27 15:21:30:18 e=0. Starting Usermode FS server.
0548 05:12:27 15:21:30:18 e=0. UserFS Server starting.
0548 05:12:27 15:21:30:18 e=23950. Could not open driver.(\\.\)
0548 05:12:27 15:21:30:18 e=0. Server started.
0578 05:12:27 15:21:30:18 e=0. Mounting drive E: with UDF cache size 16777216
 bytes (8192 sectors)
0578 05:12:27 15:21:30:00 e=0. Suspected firmware defect: media capacities re
turned by command 37 and command 82 do not match.
Et sa continue à n’en plus finir…
Pour le deuxieme fichier, le voici en integralité:
0ee0 05:12:16 23:13:40:25 e=0. SetEnumErrLevel: errorlevel is 1 [Dflt]
0ee0 05:12:16 23:13:40:25 e=0. – Starting C:\Program Files\Ahead\InCD\InCD.
exe, version 4.3.12.0 –
0ee0 05:12:16 23:13:45:16 e=0. Process exiting…
083c 05:12:16 23:13:48:04 e=0. SetEnumErrLevel: errorlevel is 1 [Dflt]
083c 05:12:16 23:13:48:04 e=0. – Starting C:\Program Files\Ahead\InCD\InCD.
083c 05:12:16 23:13:49:16 e=0. Process exiting…
0d04 05:12:16 23:20:14:01 e=0. SetEnumErrLevel: errorlevel is 1 [Dflt]
0d04 05:12:16 23:20:14:01 e=0. – Starting C:\Program Files\Ahead\InCD\InCD.
0d04 05:12:16 23:20:22:22 e=0. Process exiting…
0dc0 05:12:17 16:17:59:15 e=0. SetEnumErrLevel: errorlevel is 1 [Dflt]
0dc0 05:12:17 16:17:59:15 e=0. – Starting C:\Program Files\Ahead\InCD\InCD.
0dc0 05:12:17 16:18:25:10 e=0. Process exiting…
0fa8 05:12:17 17:07:05:16 e=0. SetEnumErrLevel: errorlevel is 1 [Dflt]
0fa8 05:12:17 17:07:05:16 e=0. – Starting C:\Program Files\Ahead\InCD\InCD.
0fa8 05:12:17 17:14:52:00 e=0. Process exiting…
09d4 05:12:17 17:14:56:18 e=0. SetEnumErrLevel: errorlevel is 1 [Dflt]
09d4 05:12:17 17:14:56:18 e=0. – Starting C:\Program Files\Ahead\InCD\InCD.
09d4 05:12:17 17:15:00:25 e=0. Process exiting…
Alort question: Qu’est-ce qui a put bien ce passer ? Comment regler le probleme ?
Merci d’avance pour vos reponses.
Autant Nero Burning est un très bon graveur, autant InCD ne présente aucun intéret (surtout depuis XP). Ne l’installe pas, c’est plus simple.
Amitiés
Janus
moi je remarque ceci :
essaye de graver le cd dvd avec Nero normalement en choisissant (UDF) , en fait on utilise ce format pour gaver de gros fichiers c’est ce que fait INCD.
Reinscriptible cas ou :slight_smile: cela va te permettre de verifier si INCD est le responsable du plantage , par contre si tu reussis à graver en UDF , c’est bien un conflit quelconque avec INCD et autre chose , peut être disque virtuel .
MasterCode>>> Je pensé, peut étre que le conflit viens d’une autre suite de logiciel de gravure que j’ai installé sur mon pc avant, avec dedans un equivalent de InCD. La suite en question s’apelle Instant CD/DVD Starter. Coincidance ou veritable relation ?
Desolé mais je suis dans l’obligation de faire: UP :bounce:
oui pardon , j’avais perdu le post .
en effet pour CD/DVD Starter ce qui explique peut être : Not mounting UDF disc read-only because native reader is present.
j’aurai desinstallé INCD nero proprement , et réinstaller CD/DVD Starter puis chercher dans ses options le moyen de désactiver l’activité d’un service qui lui est lié .
pas evident de t’aider je n’ai pratiquement jamais utilisé ce mode de gravure mais , peut être que HijackThis pourrait t’aider à cerner le problm trouvant un processus encore actif de CD/DVD Starter.
voir même desactiver le logiciel de gravure incorporé d’ XP .
si jtrouve une info, je te la soumettrai
Ouais donc en gros le mieux c’est desinstallé CD/DVD Starter definitivement (vu que j’en aurais put besion apres avec Nero, a moins que tu connaisse cette Suite et que tu peut me dire les avantages que n’a pas Nero ?) puis Nero 6, et enfin reinstallé ce dernier et voir si InCD peut passé. Quand pense-tu ?
Re UP
Bon finalement j’ai fait comme j’avais suggerré. J’ai viré Pinacle CD/DVD Starter definitivement, ensuite j’ai deinstallé Nero 6, je l’ai reinstallé et là j’ai remarqué qu’il me mes même pas un dossier InCD (cette fois-ci) dans mon dossier Nero dans Program Files. Mais d’apres un pote ce serait normal, cela dit je suis sur et certain que InCD ne tourne toujours pas derierre. Deja y a pas le logo InCD qui s’affiche normalement au demarage de l’ordi. Ensuite quand je tente de copier/coller (comme sur un disc dur) un fichier quelqu’onque de mon DD à un CDRW, il me sort l’assistance WindowsXP pour gravé sur CD (chose dont je me fou royalement), donc c’est certain InCD n’est pas installé sur mon ordi sauf que cette fois j’ai même pas des fichier d’erreur qui m’aurais permis de resoudre le probleme.
Alort quelqu’un a t’il une idée parce que là je commence a perdre patience… :frowning:
Merci d’avance.
Re Re UP
J’ai vraiment besoin de votre aide alort svp :cry:
