J’ai un probleme avec le player hifi de fun radio, sur leurs site!Avant mon formatage, tout mrchait bien!La le probleme, c’est que aucuns des boutons(+,-,ecouter,stop) ne marchent!
Il me manque un logiciel?
:hello:
Personne ne peut m’aider?
Chez moi, il y a aucun souci.
Sinon lien direct: http://radio.funradio.fr/funradio.pls
C’est quoi un fchier pls?
:hello:
http://www.filext.com/detaillist.php?extde…s&Search=Search
Used by different programs as a playlist for audio files. Can also be used as a redirector for .OGG Vorbis files although this is a non-standard use. Use a text editor to create a .PLS file that contains a single line: the full URL to the .OGG file (e.g., MYAUDIO.PLS contains http://mysite.com/myaudio.ogg as its only entry). Use ASCII mode to upload the .PLS file and binary mode to upload the .OGG file. Be certain the server has application/ogg as the MIME type for the .OGG file extension and audio/x-scpls for the .PLS file extension. You can then link to the .PLS file with the following HTML code: <a href="myaudio.pls" type="audio/x-scpls">Play My Audio</a>
