J’ai installer les pacths correctifs et depuis je n’arrive plus a jouer a Cod. Jai le message suivant qui apparait « Erreur fatale »
« Error during initialization: Failed to initialize renderer: version mismatch » ???
Et voici le rapport de la console:
CoD2 1.0 build win-x86 Oct 6 2005
----- FS_Startup -----
Current language: english
Current search path:
C:\Program Files\Activision\Call of Duty 2\main\iw_15.iwd (85 files)
C:\Program Files\Activision\Call of Duty 2\main\iw_14.iwd (4038 files)
C:\Program Files\Activision\Call of Duty 2\main\iw_13.iwd (22624 files)
C:\Program Files\Activision\Call of Duty 2\main\iw_12.iwd (1016 files)
C:\Program Files\Activision\Call of Duty 2\main\iw_11.iwd (1462 files)
C:\Program Files\Activision\Call of Duty 2\main\iw_10.iwd (1936 files)
C:\Program Files\Activision\Call of Duty 2\main\iw_09.iwd (2142 files)
C:\Program Files\Activision\Call of Duty 2\main\iw_08.iwd (2723 files)
C:\Program Files\Activision\Call of Duty 2\main\iw_07.iwd (3384 files)
C:\Program Files\Activision\Call of Duty 2\main\iw_06.iwd (990 files)
C:\Program Files\Activision\Call of Duty 2\main\iw_05.iwd (928 files)
C:\Program Files\Activision\Call of Duty 2\main\iw_04.iwd (698 files)
C:\Program Files\Activision\Call of Duty 2\main\iw_03.iwd (26 files)
C:\Program Files\Activision\Call of Duty 2\main\iw_02.iwd (40 files)
C:\Program Files\Activision\Call of Duty 2\main\iw_01.iwd (16 files)
C:\Program Files\Activision\Call of Duty 2\main\iw_00.iwd (102 files)
C:\Program Files\Activision\Call of Duty 2/main
C:\Program Files\Activision\Call of Duty 2/raw
C:\Program Files\Activision\Call of Duty 2/raw_shared
C:\Program Files\Activision\Call of Duty 2/devraw
C:\Program Files\Activision\Call of Duty 2/devraw_shared
File Handles:
80316 files in iwd files
execing default.cfg
couldn’t exec language.cfg
========= autoconfigure
configure.csv: using CPU configuration 2 GHz 512 MB
execing configure.cfg
configure.csv: using GPU configuration « Radeon X3* »
Measured CPU speed is 2.99 GHz
System memory is 1024 MB (capped at 1 GB)
Video card is « RADEON X300/X550 Series »
Streaming SIMD Extensions (SSE) supported
A première vue, je dirais que tu as eu un problème avec l’installation des patchs.
A ta place, je déinstallerais tout (n’oublie pas de sauvegarder tes sauvegardes ailleurs pour en pas les perdre), puis réinstallerais le jeu suivi du patch 1.2, puis le 1.3 (attention à bien prendre celui pour PC et non pas celui pour MacOS)
Ok merci je vais essayé mais sa fait deja 3 fois que je désinstalle tt et je réinstalle tout !Je vais retélécharger dotres patchs que ceux que j’ai pour voir
Ba enfaite la avant de tout désinstaller je viens d’installer la mise a jour du directx 9c d’août 2007, mais sa ne marche toujours pas et le fameux message réaparrait et il ya toujours:
----- Client Initialization -----
----- Initializing Renderer ----
Mismatched REF_API_VERSION: expected 60, got 59
Failed to initialize renderer: version mismatch.
Donc voila :o(
Ps; j’ai télécharger de nouveaux patchs ou cas ou
Re
Ba enfaite moi ce qui m'intrigue c'est ça :
execing default.cfg
couldn't exec language.cfg
"couldn't exec language.cfg"
:confused::confused:
Bonjour
Ba enfaite le rapport de console je l’ai à la fin quand il me dit version mismatch je click sur ok et après j’ai la console qui apparait avec les erreus de marqer voila
Ah bon,je pensais essayer d’afficher ce rapport chez moi pour voir ce qui était indiqué,mais s’il faut que le jeu plante…
Les mots « initialize renderer » me font vraiment penser à un problème DirectX,mais à part ce que tu as fait : réinstaller le dernier Dx,réinstaller le jeu et tout les patchs (j’ai pris les miens sur Clubic),alors je ne vois pas ,désolé :neutre:
EDIT: si tu as d’autres jeux qui utilisent DirectX qui fonctionnent,on peut déjà l’éliminer,reste donc le problème d’installation ou de patchs
Edité le 25/09/2007 à 20:43
