hi everyone i just have this problem with my network
http://im39.gulfup.com/rsXIU.jpg
I’d like to remind you that this board is oriented towards French speaking people. So you will have less answers - if none - than an English speaking one.
Onto your problem, what is it ?
ok thank you
i just have this problem with my Wlan its killing me happens several time a day(like 10 times) the internet cuts off and reconnect in about 2 min
when that triangle appears the problem happens
Hi,
This connection was configured multiple times? (WPA changed, etc. …)
If yes, did you try:
=> Network (sharing) center> manage wireless> delete the second connection (which has problem)?
=> Delete the entry of your machine on router or reset the router ? (by admin pannel or reset button)
Br,
thank you Beneflo
i ve reset my router and formatted my pc but same problem
that second connection shows up in about 2 min and then the internet stops then the connection turn off automatically and turn back on
