Salut a tous !
Voila je possede un asus a6t portable, et tout surchauffe !
Mes données speedfan :
Your hard disk is a ST9120821A with firmware 3.04.
Your hard disk is not in the current database.
Your hard disk’s temperature is 50C.
New hard disks are added as soon as valid statistics can be computed.
Come back soon to check your hard disk against a new database.
Your hard disk’s S.M.A.R.T. attributes are now being analyzed and a full report about the reliability, health and status of your hard disk is generated:
Your hard disk is not below any attribute threshold. This is good.
Your hard disk was never below any attribute threshold. This is good.
Since your hard disk is not in the current database, overall ratings and pictures will be based upon realistic values, but you should carefully check the results.
Attribute Current Raw Overall
10 Raw Read Error Rate 100 0 Very good
10 Spin Up Time 96 0 Very good
10 Start/Stop Count 100 408 Very good
10 Reallocated Sector Count 100 0 Very good
7 Seek Error Rate 80 102255359 Good
10 Power On Hours Count 97 3166 Very good
10 Spin Retry Count 100 0 Very good
10 Power Cycle Count 100 398 Very good
10 Unknown attribute 187 98 2 Very good
4 Unknown attribute 189 52 48 Good
0 Unknown attribute 190 50 925761586 Watch
Warning: Unknown attribute 190 is below the average limits (63-100).
10 Power Off Retract Count 100 258 Very good
3 Load Cycle Count 49 103830 Normal
4 Hardware ECC Recovered 55 94707005 Good
10 Current Pending Sector 100 0 Very good
10 Offline Uncorrectable Sector Count 100 0 Very good
8 Ultra DMA CRC Error Rate 200 0 Very good
10 Write Error Rate 100 0 Very good
10 TA Increase Count 100 0 Very good
NOTE: not all warnings are reflected on fitness and performance overall values as relevancy is based upon the settings from the hard disk manufacturer who is the best entity deputed to define such relationships.
The overall fitness for this drive is 97%.
The overall performance for this drive is 97%.
The link to get back and see a new report about this hard disk in the future is this. Consider that new hard disks and new checks are added over time.
Je voudrais savoir se que signifie les deux 97%, et si il y a un moyen de voir si mes ventilateurs marchent ou pas…
Il y a aussi :
local temp : 62c
remote temp 67c
hd0 50
temp 1 63c
core 70c
voila voila… héhé help
