Openldap ne démarre pas!
Bonjour toule monde
je suis entrain de mettre en place un serveur openldap sous FreeBSD.
j’ai installé la version openldap-2.3.41
ensuite jai configuré les fichiers nécessaire( slapd.conf, ldap.conf ) pour faire marcher le serveur.
mon souci c’est que j’arrive pas à demarrer mon serveur ni a rajouter une entrée dans mon annuaire.
voici mes fichiers de configuration :
stavril# cat slapd.conf
See slapd.conf(5) for details on configuration options.
This file should NOT be world readable.
include /usr/local/etc/openldap/schema/core.schema
include /usr/local/etc/openldap/schema/cosine.schema
include /usr/local/etc/openldap/schema/inetorgperson.schema
#include /usr/local/etc/openldap/schema/nis.schema
schemacheck on
Define global ACLs to disable default read access.
Do not enable referrals until AFTER you have a working directory
service AND an understanding of referrals.
#referral root.openldap.org…
pidfile /var/run/openldap/slapd.pid
argsfile /var/run/openldap/slapd.args
Load dynamic backend modules:
modulepath /usr/local/libexec/openldap
moduleload back_bdb
moduleload back_ldap
moduleload back_ldbm
moduleload back_passwd
moduleload back_shell
Sample security restrictions
Require integrity protection (prevent hijacking)
Require 112-bit (3DES or better) encryption for updates
Require 63-bit encryption for simple bind
security ssf=1 update_ssf=112 simple_bind=64
Sample access control policy:
Root DSE: allow anyone to read it
Subschema (sub)entry DSE: allow anyone to read it
Other DSEs:
Allow self write access
Allow authenticated users read access
Allow anonymous users to authenticate
Directives needed to implement policy:
access to dn.base=«  » by * read
access to dn.base=« cn=Subschema » by * read
access to *
by self write
by users read
by anonymous auth
if no access controls are present, the default policy
allows anyone and everyone to read anything but restricts
updates to rootdn. (e.g., « access to * by * read »)
rootdn can always read and write EVERYTHING!
access to attrs=userPassword
by dn=« cn=Manager,dc=uvsq,dc=fr » write
by dn=« cn=proxyuser,dc=uvsq,dc=fr » read
by self write
by anonymous auth
by * none
access to attrs=uidNumber,gidNumber
by * read
access to *
by self write
by * read
BDB database definitions
database bdb
suffix « dc=uvsq,dc=fr »
rootdn « cn=Manager,dc=uvsq,dc=fr »
Cleartext passwords, especially for the rootdn, should
be avoid. See slappasswd(8) and slapd.conf(5) for details.
Use of strong authentication encouraged.
rootpw secret
The database directory MUST exist prior to running slapd AND
should only be accessible by the slapd and slap tools.
Mode 700 recommended.
directory /var/db/openldap-data
mode 700
indice to maintain
index objectClass eq
#last modification
lastmod on
stavril# cat ldap.conf
LDAP Defaults
See ldap.conf(5) for details
This file should be world readable but not world writable.
#BASE dc=example, dc=com
#URI ldap.example.com…[/url] [url=ldap://ldap-master.example.com:666]ldap-master.example.com:666…
BASE dc=uvsq, dc=fr
URI 127.0.0.1…
ldap_version 3
#SIZELIMIT 12
#TIMELIMIT 15
#DEREF never
J’attends vos idées svp.
Merci d’avance
Bonsoir
J’ai le même problème que toi, j’arrive à démarrer le service OpenLdap, mais le process n’est pas présent
Pour info je suis sous Xubuntu 8.04 LTS
Dois-je créer un nouveau sujet ?
Merci.
avez vous lu les lors pour savoir d ou vient le problème??
Sous linux, les lors sont très utiles et apportent beaucoup d infos contrairement a un certain autre OS…
Bonsoir KP2
Dans le fichier syslog j’obtiens ceci dès que je veux le lancer :
May 2 22:11:14 hostlinux slapd[5993]: @(#) $OpenLDAP: slapd 2.4.7 (Apr 7 2008 21:31:23) $ ^Ibuildd@rothera:/build/buildd/openldap2.3-2.4.7/debian/build/servers/slapd
May 2 22:11:15 hostlinux slapd[5995]: hdb_db_open: database « dc=example,dc=com »: alock package is unstable.
May 2 22:11:15 hostlinux slapd[5995]: backend_startup_one: bi_db_open failed! (-1)
May 2 22:11:15 hostlinux slapd[5995]: slapd stopped.
May 2 22:11:15 hostlinux slapd[5995]: connections_destroy: nothing to destroy.
Bonsoir les gens!
Ce fichier " syslog " je le trouve meme pas !!!
meme en faisant locate machin sa donne rien!
tu peux parler de ton prob kom tu veux
on va tous s’aider pour resoudre nos ptit souci!!
tu l’as compile ton openldap ??? pourquoi tu l’as pas installe avec les packages ?
[quote="lololo60"] Bonsoir les gens! Ce fichier " syslog " je le trouve meme pas !!! meme en faisant locate machin sa donne rien! [/quote]
c’est dans /var/log
Bonsoir à tous
lololo60 merci :slight_smile:
KP2, Openldap est bien installé, j’ai suivi ce tuto : doc.ubuntu-fr.org…
Lorsque je relance le service ldap après avoir ajouté le contenu du fichier .ldif, il me dit bien que le service ldap a bien été lancé, mais dans les process je ne vois rien, d’où le log dans mon précédent post.
Si ça peut vous aider, voici le contenu du fichier slapd.conf :
[b]# Features to permit
allow bind_v2
Schema and objectClass definitions
include /etc/ldap/schema/core.schema
include /etc/ldap/schema/cosine.schema
include /etc/ldap/schema/nis.schema
include /etc/ldap/schema/inetorgperson.schema
Where the pid file is put. The init.d script
will not stop the server if you change this.
pidfile /var/run/slapd/slapd.pid
List of arguments that were passed to the server
argsfile /var/run/slapd/slapd.args
Read slapd.conf(5) for possible values
loglevel 256
Where the dynamically loaded modules are stored
modulepath /usr/lib/ldap
moduleload back_hdb
The maximum number of entries that is returned for a search operation
sizelimit 500
The tool-threads parameter sets the actual amount of cpu’s that is used
for indexing.
tool-threads 1
Specific Backend Directives for hdb:
Backend specific directives apply to this backend until another
‹ backend › directive occurs
backend hdb
Specific Backend Directives for ‹ other ›:
#backend
Specific Directives for database #1, of type hdb:
Database specific directives apply to this databasse until another
‹ database › directive occurs
database hdb
The base of your directory in database #1
suffix « dc=example,dc=com »
rootdn directive for specifying a superuser on the database. This is needed
for syncrepl.
rootdn « cn=admin,dc=example,dc=com »
Where the database file are physically stored for database #1
directory « /var/lib/ldap »
The dbconfig settings are used to generate a DB_CONFIG file the first
time slapd starts. They do NOT override existing an existing DB_CONFIG
file. You should therefore change these settings in DB_CONFIG directly
or remove DB_CONFIG and restart slapd for changes to take effect.
For the Debian package we use 2MB as default but be sure to update this
value if you have plenty of RAM
dbconfig set_cachesize 0 2097152 0
Sven Hartge reported that he had to set this value incredibly high
to get slapd running at all. See bugs.debian.org… for more
information.
Number of objects that can be locked at the same time.
dbconfig set_lk_max_objects 1500
Number of locks (both requested and granted)
dbconfig set_lk_max_locks 1500
Number of lockers
dbconfig set_lk_max_lockers 1500
Indexing options for database #1
Save the time that the entry gets modified, for database #1
lastmod on
Checkpoint the BerkeleyDB database periodically in case of system
failure and to speed slapd shutdown.
checkpoint 512 30
Where to store the replica logs for database #1
replogfile /var/lib/ldap/replog
The userPassword by default can be changed
by the entry owning it if they are authenticated.
Others should not be able to see it, except the
admin entry below
These access lines apply to database #1 only
access to attrs=userPassword,shadowLastChange
by dn=« cn=admin,dc=nodomain » write
by anonymous auth
by self write
by * none
Ensure read access to the base for things like
supportedSASLMechanisms. Without this you may
have problems with SASL not knowing what
mechanisms are available and the like.
Note that this is covered by the ‹ access to * ›
ACL below too but if you change that as people
are wont to do you’ll still need this if you
want SASL (and possible other things) to work
happily.
The admin dn has full write access, everyone else
can read everything.
access to *
by * read
For Netscape Roaming support, each user gets a roaming
profile for which they have write access to
#access to dn=« .*,ou=Roaming,o=morsnet »
by dnattr=owner write[/b]
Merci du coup de main :slight_smile:
Edité le 03/05/2008 à 18:20
et y’a quoi dans dans ton fichier .ldif ? D’après les logs y’a une inconsistance entre ta conf (example.com) et le contenu de tes données
Bonjour à tous
pour le fichier syslog dont vous m’avez parlé je le trouve tjrs pas, j’ai bien cherché dans /var/log par contre j’ai un fichier qui contient les probleme que j’ai, c’est « debug.log »
le voici en détail :
May 2 09:51:30 stavril slapd[967]: @(#) $OpenLDAP: slapd 2.3.41 (Apr 25 2008 14:56:51) $ root@stavril.gtr.iut-velizy.uvsq.fr:/usr/ports/net/openldap23-server/work/openldap-2.3.41/servers/slapd
May 2 09:51:30 stavril slapd[967]: connections_destroy: nothing to destroy.
May 2 09:51:30 stavril slapd[967]: /usr/local/etc/openldap/slapd.conf: line 83: failed init (bdb)!
May 2 09:51:30 stavril slapd[967]: slapd stopped.
May 2 10:04:13 stavril slapd[55570]: connections_destroy: nothing to destroy.
May 2 11:15:17 stavril slapd[62838]: @(#) $OpenLDAP: slapd 2.3.41 (Apr 25 2008 14:56:51) $ root@stavril.gtr.iut-velizy.uvsq.fr:/usr/ports/net/openldap23-server/work/openldap-2.3.41/servers/slapd
May 2 11:15:17 stavril slapd[62838]: daemon: getaddrinfo() failed: hostname nor servname provided, or not known
May 2 11:15:17 stavril slapd[62838]: slapd stopped.
May 2 11:15:17 stavril slapd[62838]: connections_destroy: nothing to destroy.
j’esper que vous allez pouvoir m’aider.
bon courage à tous
tu l’as lu le log ?
regarde bien, l’erreur est marquee dedans…
As tu configure ton service? OpenLDAP n’est pas un service qu’on installe et qui marche immediatement… faut le preconfigurer un minimum avant.
As tu lu un tutorial de demarrage rapide sur le site officiel OpenLDAP ?
Edité le 05/05/2008 à 11:15
Oui je sais , biensur il faut faire des preconfiguration.
donc les fichier de cnfiguration tel : slapd.conf , ldap.conf je les ai bien configuré en suivant ce tutorial. julp.developpez.com…
et j’ai bien vu les erreurs que j’ai dans le fichier debug.log mais j’arrive pas à les resoudre j’essai de trouvé une solution mais sans succé!!pi voila
en fait kand j’essai de démarrer le service : sa me donne sa
starvil#/usr/local/etc/rc.d/slapd start
Strating slapd
mais kand je fais sa :
starvil#/usr/local/etc/rc.d/slapd status
slapd is not running
as-tu une idée ?
bon on a fai du progré , le serveur arrive a démarrer pendant 7 minutes.
May 5 11:24:32 stavril slapd[2965]: @(#) $OpenLDAP: slapd 2.3.41 (Apr 25 2008 14:56:51) $ root@stavril.gtr.iut-velizy.uvsq.fr:/usr/ports/net/openldap23-server/work/openldap-2.3.41/servers/slapd
May 5 11:24:32 stavril slapd[2966]: bdb_db_open: Warning - No DB_CONFIG file found in directory /var/db/openldap-data: (2) Expect poor performance for suffix dc=uvsq,dc=fr.
May 5 11:24:32 stavril slapd[2966]: slapd starting
May 5 11:41:19 stavril slapd[2966]: daemon: shutdown requested and initiated.
May 5 11:41:19 stavril slapd[2966]: slapd shutdown: waiting for 0 threads to terminate
May 5 11:41:19 stavril slapd[2966]: slapd stopped.
j’ai profité des ces minutes pour ajouter mon fichier de base ( test.ldif ) qui contient la racine de mon annuaire.
et pi ensuite il s’est arreté kom un con lol
et en verifiant mon fichier debug.log j’obtient d’autres erreurs que je suis entrain de voir a quoi sa correspond.
May 5 11:56:58 stavril slapd[3101]: @(#) $OpenLDAP: slapd 2.3.41 (Apr 25 2008 14:56:51) $ root@stavril.gtr.iut-velizy.uvsq.fr:/usr/ports/net/openldap23-server/work/openldap-2.3.41/servers/slapd
May 5 11:56:58 stavril slapd[3102]: bdb_db_open: has changed. Performing database recovery to activate new settings.
May 5 11:56:58 stavril slapd[3102]: bdb(dc=uvsq,dc=fr): /var/db/openldap-data/__db.001: Permission denied
May 5 11:56:58 stavril slapd[3102]: bdb_db_open: Database cannot be recovered, err 13. Restore from backup!
May 5 11:56:58 stavril slapd[3102]: bdb(dc=uvsq,dc=fr): DB_ENV->lock_id_free interface requires an environment configured for the locking subsystem
May 5 11:56:58 stavril slapd[3102]: bdb(dc=uvsq,dc=fr): txn_checkpoint interface requires an environment configured for the transaction subsystem
May 5 11:56:58 stavril slapd[3102]: bdb_db_close: txn_checkpoint failed: Invalid argument (22)
May 5 11:56:58 stavril slapd[3102]: backend_startup_one: bi_db_open failed! (13)
May 5 11:56:58 stavril slapd[3102]: bdb_db_close: alock_close failed
May 5 11:56:58 stavril slapd[3102]: slapd stopped.
May 5 11:56:58 stavril slapd[3102]: connections_destroy: nothing to destroy.
voila ! Vos reflexes SVP j’en ai besoins
Voila bonne nouvelle!
j’arrive bien a démarrer slapd.je m’explique :
j’ai tapé la commande suivante :
stavril#/usr/local/libexec/slapd -d 255
Ensuite j’ai fai :
stavril#/usr/local/etc/rc.d/slapd start
en faisant :
stavril#/usr/local/etc/rc.d/slapd status sa donne sa =====> slapd is running as pid 791.
voila voila
pour ceux qui savent pas encore je suis sous FreeBSD 7.0 release!
Hello,
Ayant moi même cherché pendant des heures avant de finir par trouver :
IL FAUT que les DEUX fichiers de configuration du client ldap soient correctement configurés : (pour une CentOS)
/etc/ldap.conf ET
/etc/openldap/ldap.conf
contiennent l’URI du serveur ldap :
exemple :
BASE    dc=exemple, dc=com
URI     ldap ://ns24.ovh.net       ## Enlever le blanc après 'ldap'
Edité le 05/10/2009 à 22:51
