Hello !
J’ai tenté d’installer IE7 pour XP SP2, en désinstallant mes anti-spyware et désactivant mon antivirus et firewall (McAfee Security Suite), pourtant il n’arrive toujours pas à s’installer :
http://img68.imageshack.us/img68/8962/internet7problmedb0.jpg
J’ai bien cherché à comprendre ceci, mais je n’y entend rien :
0.344: ================================================================================
0.344: 2006/11/02 08:58:45.437 (local)
0.344: c:\2cb1e4be6711541cde4088eb24\update\update.exe (version 6.2.29.0)
0.360: Hotfix started with following command line: /quiet /norestart /er /log:C:\WINDOWS
1.688: IECUSTOM: Scanning for proper registry permissions...
2.157: IECUSTOM: Unwriteable key HKCR\giffile\shell\Open
2.157: IECUSTOM: Unwriteable key HKCR\giffile\shell\Open\command
2.610: IECUSTOM: Unwriteable key HKCR\jpegfile\CLSID
2.641: IECUSTOM: Unwriteable key HKCR\pngfile\CLSID
3.157: IECUSTOM: Scanning for proper registry permissions...
3.391: IECUSTOM: Scanning for proper registry permissions...
3.704: IECUSTOM: Unwriteable key HKCR\giffile\shell\Open
3.704: IECUSTOM: Unwriteable key HKCR\giffile\shell\Open\command
3.797: IECUSTOM: Unwriteable key HKCR\jpegfile\CLSID
3.829: IECUSTOM: Unwriteable key HKCR\pngfile\CLSID
3.922: IECUSTOM: Backing up registry permissions...
3.938: IECUSTOM: Finished backing up registry permissions...
3.938: IECUSTOM: Setting new registry permissions...
3.954: IECUSTOM: Unable to clear DACLs HKCR\pngfile
3.954: IECUSTOM: Finished setting new registry permissions...
3.954: IECUSTOM: An error occured verifying registry permissions. ERROR: 0x80070534
3.954: DoInstallation: CustomizeCall Failed: 0x3f5
3.969: IECUSTOM: Restoring registry permissions...
4.094: IECUSTOM: Finished restoring registry permissions...
4.125: Impossible d'écrire la clé du Registre de configuration.
4.141: L'installation du [Internet Explorer](http://www.clubic.com/telecharger-fiche18706-internet-explorer.html) 7 ne s'est pas terminée.
4.141: Update.exe extended error code = 0x3f5
Une solution à proposer pour tous ceux qui ont le mêm problème ? Merci d’avance :jap:
