Hello,
j’ai installé Doom3 et j’ai logiquement installé le dernier patch sorti pour la compatibilité avec Vista..
seulement quand je le lance j’ai ce message qui s’affiche:
DOOM 1.3.1.1304 win-x86 Jan 16 2007 15:36:51
2399 MHz Intel CPU with MMX & SSE & SSE2 & SSE3 & HTT
2048 MB System Memory
320 MB Video Memory
Winsock Initialized
Found interface: {D2E66A5F-8A7D-491B-A33F-0CE6F389BB63} Carte client LAN sans fil Marvell Libertas 802.11b/g - 192.168.1.38/255.255.255.0
Found interface: {851A4A3F-F448-498F-9554-52E8C1A200B6} Contrôleur de réseau NVIDIA nForce - 0.0.0.0 NULL netmask - skipped
Sys_InitNetworking: adding loopback interface
doom using MMX & SSE & SSE2 & SSE3 for SIMD processing
enabled Flush-To-Zero mode
enabled Denormals-Are-Zero mode
------ Initializing File System ------
Loaded pk4 D:\Doom3\Doom 3\base\game01.pk4 with checksum 0x51c6981f
Loaded pk4 D:\Doom3\Doom 3\base\game02.pk4 with checksum 0xf3ec6f7
Loaded pk4 D:\Doom3\Doom 3\base\game03.pk4 with checksum 0x5d4230ea
Loaded pk4 D:\Doom3\Doom 3\base\pak005.pk4 with checksum 0x8ffc3621
Loaded pk4 D:\Doom3\Doom 3\base\pak006.pk4 with checksum 0x95b65ab
Loaded pk4 D:\Doom3\Doom 3\base\pak007.pk4 with checksum 0x666bdb3c
Loaded pk4 D:\Doom3\Doom 3\base\pak008.pk4 with checksum 0x23ae5993
Loaded pk4 D:\Doom3\Doom 3\base\zpak003.pk4 with checksum 0xc5fc4000
Current search path:
D:\Doom3\Doom 3/base
D:\Doom3\Doom 3\base\zpak003.pk4 (5 files)
D:\Doom3\Doom 3\base\pak008.pk4 (3 files)
D:\Doom3\Doom 3\base\pak007.pk4 (38 files)
D:\Doom3\Doom 3\base\pak006.pk4 (48 files)
D:\Doom3\Doom 3\base\pak005.pk4 (63 files)
D:\Doom3\Doom 3\base\game03.pk4 (2 files)
D:\Doom3\Doom 3\base\game02.pk4 (2 files)
D:\Doom3\Doom 3\base\game01.pk4 (2 files)
game DLL: 0x0 in pak: 0x0
Addon pk4s:
file system initialized.
Unknown command ‹ vid_restart ›
idRenderSystem::Shutdown()
Shutting down OpenGL subsystem
…shutting down QGL
Couldn’t load default.cfg
auriez vous une idée??ca vient surement pas de ma config(E6660,2gb de RAM,8800gts)
