Windows XP 5.1
IA32
WinAspi: -
NT-SPTI used
Nero Version: 8.1.1.0
Internal Version: 8, 1, 1, 0
Recorder: Version: 1.41 - HA 1 TA 1 - 8.1.1.0
Adapter driver: HA 1
Drive buffer : 2000kB
Bus Type : default
CD-ROM: Version: 7Z14 - HA 1 TA 0 - 8.1.1.0
=== Scsi-Device-Map ===
CdRomPeripheral : MATSHITA DVD-ROM SR-8588 atapi Port 0 ID 0 DMA: On
CdRomPeripheral : PIONEER DVD-RW DVR-110D atapi Port 0 ID 1 DMA: On
DiskPeripheral : ST3320620A atapi Port 1 ID 0 DMA: On
=== CDRom-Device-Map ===
MATSHITA DVD-ROM SR-8588 D: CdRom0
PIONEER DVD-RW DVR-110D E: CdRom1
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
BUFE : 0
Physical memory : 1023MB (1048048kB)
Free physical memory: 314MB (321696kB)
Memory in use : 69 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
9.11.2007
CD-ROM (ISO)
18:35:08 #1 Text 0 File SCSIPTICommands.cpp, Line 450
LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
18:35:08 #2 Text 0 File Isodoc.cpp, Line 6671
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : FALSE
Multisession : TRUE
Multisession type: : Start multisession
Burning mode : DAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
18:35:08 #3 Text 0 File Burncd.cpp, Line 3212
Buffer underrun protection activated
18:35:08 #4 ISO9660GEN -11 File Geniso.cpp, Line 3347
First writeable address = 0 (0x00000000)
18:35:08 #5 Text 0 File Burncd.cpp, Line 3530
Turn on Disc-At-Once, using CD-R/RW media
18:35:09 #6 Text 0 File FilesystemSettingsValidator.cpp, Line 142
FS Settings: using validator ‹ CUDFSettingsValidatorCD ›
ParamMode = ‹ automatic ›, changing UDF partition type from ‹ physical › to ‹ physical ›
Changing UDF revision from ‹ 1.02 › to ‹ 1.02 ›
18:35:10 #7 Text 0 File DlgWaitCD.cpp, Line 307
Last possible write address on media: 359847 ( 79:59.72)
Last address to be written: 358414 ( 79:40.64)
18:35:10 #8 Text 0 File DlgWaitCD.cpp, Line 319
Write in overburning mode: NO (enabled: CD)
18:35:10 #9 Text 0 File DlgWaitCD.cpp, Line 2972
Recorder: PIONEER DVD-RW DVR-110D;
CDR code: 00 97 34 23; OSJ entry from: Mitsubishi Chemical
ATIP Data:
Special Info [hex] 1: C0 00 98, 2: 61 22 17 (LI 97:34.23), 3: 4F 3B 49 (LO 79:59.73)
Additional Info [hex] 1: FF FF FF (invalid), 2: FF FF FF (invalid), 3: FF FF FF (invalid)
18:35:10 #10 Text 0 File DlgWaitCD.cpp, Line 493
>>> Protocol of DlgWaitCD activities: <<<
18:35:10 #11 Text 0 File ThreadedTransferInterface.cpp, Line 785
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 358415 (358415) = #358415/79:38.65
relocatable, disc pos for caching/writing not required/ required
→ TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 358415 blocks [E: PIONEER DVD-RW DVR-110D]
18:35:11 #12 Text 0 File ThreadedTransferInterface.cpp, Line 986
Prepare [E: PIONEER DVD-RW DVR-110D] for write in CUE-sheet-DAO
DAO infos:
MCN: « »
TOCType: 0x00; Session Closed, disc not fixated
Tracks 1 to 1: Idx 0 Idx 1 Next Trk
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 307200 734341120, ISRC « »
DAO layout:
__Start|___Track|Idx|CtrlAdr|Size|NWA|RecDep
-150 | lead-in | 0 | 0x41 | 0 | 0 | 0x00
-150 | 1 | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 1 | 0x41 | 358415 | 0 | 0x00
358415 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
18:35:11 #13 Text 0 File SCSIPTICommands.cpp, Line 240
SPTILockVolume - completed successfully for FSCTL_LOCK_VOLUME
18:35:11 #14 Text 0 File Burncd.cpp, Line 4316
Caching options: cache CDRom or Network-Yes, small files-No (<64KB)
18:35:11 #15 Phase 24 File dlgbrnst.cpp, Line 1764
Caching of files started
18:35:11 #16 Text 0 File Burncd.cpp, Line 4435
Cache writing successful.
18:35:11 #17 Phase 25 File dlgbrnst.cpp, Line 1764
Caching of files completed
18:35:11 #18 Phase 36 File dlgbrnst.cpp, Line 1764
Burn process started at 32x (4 800 KB/s)
18:35:11 #19 Text 0 File ThreadedTransferInterface.cpp, Line 2735
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
18:35:12 #20 Text 0 File MMC.cpp, Line 17745
StartDAO : CD-Text - Off
18:35:12 #21 Text 0 File MMC.cpp, Line 22430
Set BUFE: Buffer underrun protection → ON
18:35:13 #22 Text 0 File MMC.cpp, Line 17973
CueData, Len=32
41 00 00 14 00 00 00 00
41 01 00 10 00 00 00 00
41 01 01 10 00 00 02 00
41 aa 01 14 00 4f 28 41
18:35:13 #23 Text 0 File ThreadedTransfer.cpp, Line 268
Pipe memory size 83836800
18:35:14 #24 Text 0 File Cdrdrv.cpp, Line 1367
18:35:14.031 - ???D?????? : Queue again later
18:35:38 #25 Text 0 File Cdrdrv.cpp, Line 1367
18:35:38.906 - ???D?????? : Queue again later
18:35:38 #26 Text 0 File Cdrdrv.cpp, Line 1367
18:35:38.921 - ???D?????? : Queue again later
18:35:38 #27 Text 0 File Cdrdrv.cpp, Line 1367
18:35:38.953 - ???D?????? : Queue again later
18:35:38 #28 Text 0 File Cdrdrv.cpp, Line 1367
18:35:38.984 - ???D?????? : Queue again later
18:35:39 #29 Text 0 File Cdrdrv.cpp, Line 1367
18:35:39.000 - ???D?????? : Queue again later
18:35:39 #30 Text 0 File Cdrdrv.cpp, Line 1367
18:35:39.031 - ???D?????? : Queue again later
18:35:39 #31 Text 0 File Cdrdrv.cpp, Line 1367
18:35:39.046 - ???D?????? : Queue again later
18:35:39 #32 Text 0 File Cdrdrv.cpp, Line 1367
18:35:39.078 - ???D?????? : Queue again later
18:35:39 #33 Text 0 File Cdrdrv.cpp, Line 1367
18:35:39.093 - ???D?????? : Queue again later
18:35:39 #34 Text 0 File Cdrdrv.cpp, Line 1367
18:35:39.125 - ???D?????? : Queue again later
18:35:39 #35 Text 0 File Cdrdrv.cpp, Line 1367
18:35:39.140 - ???D?????? : Queue again later
18:35:39 #36 Text 0 File Cdrdrv.cpp, Line 1367
18:35:39.171 - ???D?????? : Queue again later
18:35:39 #37 Text 0 File Cdrdrv.cpp, Line 1367
18:35:39.187 - ???D?????? : Queue again later
18:35:39 #38 Text 0 File Cdrdrv.cpp, Line 1367
18:35:39.250 - ???D?????? : Queue again later
18:35:39 #39 Text 0 File Cdrdrv.cpp, Line 1367
18:35:39.281 - ???D?????? : Queue again later
18:35:39 #40 Text 0 File Cdrdrv.cpp, Line 1367
18:35:39.296 - ???D?????? : Queue again later
18:35:39 #41 Text 0 File Cdrdrv.cpp, Line 1367
18:35:39.328 - ???D?????? : Queue again later
18:35:39 #42 Text 0 File Cdrdrv.cpp, Line 1367
18:35:39.343 - ???D?????? : Queue again later
18:35:39 #43 Text 0 File Cdrdrv.cpp, Line 1367
18:35:39.375 - ???D?????? : Queue again later
18:35:39 #44 Text 0 File Cdrdrv.cpp, Line 1367
18:35:39.390 - ???D?????? : Queue again later
18:35:39 #45 Text 0 File Cdrdrv.cpp, Line 1367
18:35:39.421 - ???D?????? : Queue again later
18:35:39 #46 Text 0 File Cdrdrv.cpp, Line 1367
18:35:39.437 - ???D?????? : Queue again later
18:35:39 #47 Text 0 File Cdrdrv.cpp, Line 1367
18:35:39.468 - ???D?????? : Queue again later
18:35:39 #48 Text 0 File Cdrdrv.cpp, Line 1367
18:35:39.484 - ???D?????? : Queue again later
18:35:39 #49 Text 0 File Cdrdrv.cpp, Line 1367
18:35:39.515 - ???D?????? : Queue again later
18:35:39 #50 Text 0 File Cdrdrv.cpp, Line 1367
18:35:39.593 - ???D?????? : Queue again later
18:35:39 #51 Text 0 File Cdrdrv.cpp, Line 1367
18:35:39.609 - ???D?????? : Queue again later
18:35:39 #52 Text 0 File Cdrdrv.cpp, Line 1367
18:35:39.640 - ???D?????? : Queue again later
18:35:39 #53 Text 0 File Cdrdrv.cpp, Line 1367
18:35:39.656 - ???D?????? : Queue again later
18:35:39 #54 Text 0 File Cdrdrv.cpp, Line 1367
18:35:39.687 - ???D?????? : Queue again later
18:35:39 #55 Text 0 File Cdrdrv.cpp, Line 1367
18:35:39.718 - ???D?????? : Queue again later
18:35:39 #56 Text 0 File Cdrdrv.cpp, Line 1367
18:35:39.734 - ???D?????? : Queue again later
18:35:39 #57 Text 0 File Cdrdrv.cpp, Line 1367
18:35:39.765 - ???D?????? : Queue again later
18:35:39 #58 Text 0 File Cdrdrv.cpp, Line 1367
18:35:39.781 - ???D?????? : Queue again later
18:35:39 #59 Text 0 File Cdrdrv.cpp, Line 1367
18:35:39.812 - ???D?????? : Queue again later
18:35:39 #60 Text 0 File Cdrdrv.cpp, Line 1367
18:35:39.828 - ???D?????? : Queue again later
18:35:39 #61 Text 0 File Cdrdrv.cpp, Line 1367
18:35:39.921 - ???D?????? : Queue again later
18:35:39 #62 Text 0 File Cdrdrv.cpp, Line 1367
18:35:39.937 - ???D?????? : Queue again later
18:35:39 #63 Text 0 File Cdrdrv.cpp, Line 1367
18:35:39.953 - ???D?????? : Queue again later
18:35:39 #64 Text 0 File Cdrdrv.cpp, Line 1367
18:35:39.984 - ???D?????? : Queue again later
18:35:40 #65 Text 0 File Cdrdrv.cpp, Line 1367
18:35:40.000 - ???D?????? : Queue again later
18:35:40 #66 Text 0 File Cdrdrv.cpp, Line 1367
18:35:40.031 - ???D?????? : Queue again later
18:35:40 #67 Text 0 File Cdrdrv.cpp, Line 1367
18:35:40.046 - ???D?????? : Queue again later
18:35:40 #68 Text 0 File Cdrdrv.cpp, Line 1367
18:35:40.078 - ???D?????? : Queue again later
18:35:40 #69 Text 0 File Cdrdrv.cpp, Line 1367
18:35:40.109 - ???D?????? : Queue again later
18:35:40 #70 Text 0 File Cdrdrv.cpp, Line 1367
18:35:40.140 - ???D?????? : Queue again later
18:35:40 #71 Text 0 File Cdrdrv.cpp, Line 1367
18:35:40.156 - ???D?????? : Queue again later
18:35:40 #72 Text 0 File Cdrdrv.cpp, Line 1367
18:35:40.218 - ???D?????? : Queue again later
18:35:40 #73 Text 0 File Cdrdrv.cpp, Line 1367
18:35:40.234 - ???D?????? : Queue again later
18:35:40 #74 Text 0 File Cdrdrv.cpp, Line 1367
18:35:40.265 - ???D?????? : Queue again later
18:35:40 #75 Text 0 File Cdrdrv.cpp, Line 1367
18:35:40.281 - ???D?????? : Queue again later
18:35:40 #76 Text 0 File Cdrdrv.cpp, Line 1367
18:35:40.312 - ???D?????? : Queue again later
18:35:40 #77 Text 0 File Cdrdrv.cpp, Line 1367
18:35:40.328 - ???D?????? : Queue again later
18:35:40 #78 Text 0 File Cdrdrv.cpp, Line 1367
18:35:40.359 - ???D?????? : Queue again later
18:35:40 #79 Text 0 File Cdrdrv.cpp, Line 1367
18:35:40.375 - ???D?????? : Queue again later
18:35:40 #80 Text 0 File Cdrdrv.cpp, Line 1367
18:35:40.406 - ???D?????? : Queue again later
18:35:40 #81 Text 0 File Cdrdrv.cpp, Line 1367
18:35:40.421 - ???D?????? : Queue again later
18:35:40 #82 Text 0 File Cdrdrv.cpp, Line 1367
18:35:40.453 - ???D?????? : Queue again later
18:35:40 #83 Text 0 File Cdrdrv.cpp, Line 1367
18:35:40.468 - ???D?????? : Queue again later
18:35:40 #84 Text 0 File Cdrdrv.cpp, Line 1367
18:35:40.531 - ???D?????? : Queue again later
18:35:40 #85 Text 0 File Cdrdrv.cpp, Line 1367
18:35:40.546 - ???D?????? : Queue again later
18:35:40 #86 Text 0 File Cdrdrv.cpp, Line 1367
18:35:40.578 - ???D?????? : Queue again later
18:35:40 #87 Text 0 File Cdrdrv.cpp, Line 1367
18:35:40.593 - ???D?????? : Queue again later
18:35:40 #88 Text 0 File Cdrdrv.cpp, Line 1367
18:35:40.625 - ???D?????? : Queue again later
18:35:40 #89 Text 0 File Cdrdrv.cpp, Line 1367
18:35:40.640 - ???D?????? : Queue again later
18:35:40 #90 Text 0 File Cdrdrv.cpp, Line 1367
18:35:40.671 - ???D?????? : Queue again later
18:35:40 #91 Text 0 File Cdrdrv.cpp, Line 1367
18:35:40.703 - ???D?????? : Queue again later
18:35:40 #92 Text 0 File Cdrdrv.cpp, Line 1367
18:35:40.718 - ???D?????? : Queue again later
18:35:40 #93 Text 0 File Cdrdrv.cpp, Line 1367
18:35:40.750 - ???D?????? : Queue again later
18:35:40 #94 Text 0 File Cdrdrv.cpp, Line 1367
18:35:40.765 - ???D?????? : Queue again later
18:35:40 #95 Text 0 File Cdrdrv.cpp, Line 1367
18:35:40.796 - ???D?????? : Queue again later
18:35:40 #96 Text 0 File Cdrdrv.cpp, Line 1367
18:35:40.875 - ???D?????? : Queue again later
18:35:40 #97 Text 0 File Cdrdrv.cpp, Line 1367
18:35:40.890 - ???D?????? : Queue again later
18:35:40 #98 Text 0 File Cdrdrv.cpp, Line 1367
18:35:40.906 - ???D?????? : Queue again later
18:35:40 #99 Text 0 File Cdrdrv.cpp, Line 1367
18:35:40.937 - ???D?????? : Queue again later
18:35:40 #100 Text 0 File Cdrdrv.cpp, Line 1367
18:35:40.953 - ???D?????? : Queue again later
18:35:40 #101 Text 0 File Cdrdrv.cpp, Line 1367
18:35:40.984 - ???D?????? : Queue again later
18:35:41 #102 Text 0 File Cdrdrv.cpp, Line 1367
18:35:41.000 - ???D?????? : Queue again later
18:35:41 #103 Text 0 File Cdrdrv.cpp, Line 1367
18:35:41.031 - ???D?????? : Queue again later
18:35:41 #104 Text 0 File Cdrdrv.cpp, Line 1367
18:35:41.062 - ???D?????? : Queue again later
18:35:41 #105 Text 0 File Cdrdrv.cpp, Line 1367
18:35:41.078 - ???D?????? : Queue again later
18:35:41 #106 Text 0 File Cdrdrv.cpp, Line 1367
18:35:41.109 - ???D?????? : Queue again later
18:35:41 #107 Text 0 File Cdrdrv.cpp, Line 1367
18:35:41.125 - ???D?????? : Queue again later
18:35:41 #108 Text 0 File Cdrdrv.cpp, Line 1367
18:35:41.187 - ???D?????? : Queue again later
18:35:41 #109 Text 0 File Cdrdrv.cpp, Line 1367
18:35:41.203 - ???D?????? : Queue again later
18:35:41 #110 Text 0 File Cdrdrv.cpp, Line 1367
18:35:41.234 - ???D?????? : Queue again later
18:35:41 #111 Text 0 File Cdrdrv.cpp, Line 1367
18:35:41.250 - ???D?????? : Queue again later
18:35:41 #112 Text 0 File Cdrdrv.cpp, Line 1367
18:35:41.281 - ???D?????? : Queue again later
18:35:41 #113 Text 0 File Cdrdrv.cpp, Line 1367
18:35:41.296 - ???D?????? : Queue again later
18:35:41 #114 Text 0 File Cdrdrv.cpp, Line 1367
18:35:41.328 - ???D?????? : Queue again later
18:35:41 #115 Text 0 File Cdrdrv.cpp, Line 1367
18:35:41.359 - ???D?????? : Queue again later
18:35:41 #116 Text 0 File Cdrdrv.cpp, Line 1367
18:35:41.375 - ???D?????? : Queue again later
18:35:41 #117 Text 0 File Cdrdrv.cpp, Line 1367
18:35:41.406 - ???D?????? : Queue again later
18:35:41 #118 Text 0 File Cdrdrv.cpp, Line 1367
18:35:41.421 - ???D?????? : Queue again later
18:35:41 #119 Text 0 File Cdrdrv.cpp, Line 1367
18:35:41.453 - ???D?????? : Queue again later
18:35:41 #120 Text 0 File Cdrdrv.cpp, Line 1367
18:35:41.531 - ???D?????? : Queue again later
18:35:41 #121 Text 0 File Cdrdrv.cpp, Line 1367
18:35:41 #122 Text 0 File Cdrdrv.cpp, Line 1367
18:35:41.562 - ???D?????? : Queue again later
18:35:41 #123 Text 0 File Cdrdrv.cpp, Line 1367
18:35:41.593 - ???D?????? : Queue again later
18:37:09 #124 SPTI -1135 File SCSIPassThrough.cpp, Line 181
CdRom1: SCSIStatus(x02) WinError(0) NeroError(-1135)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x2A 00 00 01 E6 40 00 00 20 00 00 00
Sense Area: 0x71 00 03 00 27 33 52 0E 00 00 00 00 0C
Buffer x096d0e40: Len x10000
0xD9 6E 29 0D E1 E4 6B F3 6C 96 2F 49 9F 7B 94 F0
0x1A 91 F3 2A 48 A0 74 3E 05 0A 46 B6 29 2F CE 06
0xAE 24 AC 19 58 8D E5 57 ED 27 F3 3B 25 B1 A9 B3
18:37:09 #125 CDR -1135 File Writer.cpp, Line 306
Write error
18:37:10 #126 Phase 38 File dlgbrnst.cpp, Line 1764
Burn process failed at 32x (4 800 KB/s)
18:37:11 #127 Text 0 File SCSIPTICommands.cpp, Line 287
SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
18:37:12 #128 Text 0 File Cdrdrv.cpp, Line 11276
DriveLocker: UnLockVolume completed
18:37:12 #129 Text 0 File SCSIPTICommands.cpp, Line 450
UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
Existing drivers:
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
