Flasher Bios Geforce 6600 Pny Help !
bonjour
donc voila je voudrais flasher le bios de ma 6600 non gt de marque PNY 256ddr mais je ne trouve pas de bios pny; donc j’aurai bien aimé mettre un bios d’une autre geforce 6600 car je trouve que ma 6600 bug pas mal ?
voila les caractéristiques de ma carte pour comparer avec les autres 6600 :hello: (attention c’est long lol)
=>GeForce™ 6 6600 AGP8X 256MB VGA + DVI + TVOUT
Specifications
NVIDIA® CineFX 3.0 engine
Superscalar GPU architecture
300MHz core clock
128-bit DDR memory interface
500MHz memory data rate
2.4 billion texels/sec. fill rate
225 million vertices/sec. setup
8 pixels per clock (peak)
Dual 400MHz RAMDACs
Maximum display resolution 2048 x 1536 @ 85Hz
Flat-panel display support with resolutions up to 1600 x 1200
FEATURES & BENEFITS
Superscaler GPU architecturee
Delivers up to 8X the shading power of previous generation products for outstanding gaming performance.
64-bit Floating Point Texture Filtering and Blending
NVIDIA’s® 64-bit texture implementation sets new standards for image clarity and quality through floating point capabilities in filtering, texturing and high dynamic range (HDR) lighting.*
NVIDIA® UltraShadow™ II Technology
Enhances the performance of bleeding-edge games that feature complex scenes with multiple light sources and objects. Second-generation technology delivers more than 4x the shadow processing power over the previous generation.
NVIDIA® Intellisample™ 3.0 Technology
Delivers ultra-realistic visuals with no jagged edges at lightning-fast speeds. Visual quality is taken to new heights through a new rotated grid sampling pattern.
NVIDIA® Digital Vibrance Control™ 3.0 Technology
Allows the user to adjust color controls digitally to compensate for the lighting conditions of their workspace, in order to achieve accurate, bright colors in all conditions.
Full MPEG Support
Microsoft® DirectX® 9.0 Shader Model 3.0 Support
Ensures top-notch compatibility and performance for all Microsoft® DirectX 9.0® applications, including gaming titles utilizing Shader Model 3.0.
Microsoft®OpenGL® 1.5 Optimizations and Support
Ensures top-notch compatibility and performance for all OpenGL® applications.
:ane:
Merci de me donnez vos avis et de me dire comment je devrais prosseder :unsure:
merci à tous pour votre aide par avance :wub:
up ! merci
merci sinon je le trouve comment car il n’y a plus les sous sujets comme l’ancien forum; c’est trop le bordel et dans recherche je ne le trouve pas et y a pas aussi la recherche détaillée :o .
puis je dois réedité le primer post :smiley: , bug sur les liens :confused:
lol franchement ce forum c’est le souk :lol: ; on dirait une pub :ane: ; ou va clubic :wacko: ?
préviens moi quand ton topic sera remis à jour car je voudrais bien savoir comment mettre à jour le bios sans tuer ma geforce car j’ai pas de carte pci et comment sauvegarder le bios d’origine. :wub:
http://www.clubic.com/forum/index.php?act=…=0#entry1220363
je dois faire encore quelque modif mais il remarche :slight_smile:
Voila, modif terminée :slight_smile:
signalé les bug si il y a :stuck_out_tongue:
