Je viens de m’offrir bs4, malheureusement il ne veut pas demarrer, j’ai le son mais pas d’image, enfin si, c’est comme des flach en haut de mon ecran.
Je joue habituellement avec metaboli, j’avais teste mon pc pour ce jeu, et le test etait ok. Quelqu’un as t’il une idée ?
Merci beaucoup pour votre aide
Je vous envoie un dxdiag ?
System Information
Time of this report: 1/15/2007, 15:01:53
Machine name: SN2242687043
Operating System: Windows XP Home Edition (5.1, Build 2600) (2600.xpclient.010817-1148)
Language: French (Regional Setting: French)
System Manufacturer: Packard Bell NEC
System Model: 00000000000000000000000
BIOS: Default System BIOS
Processor: AMD Athlon� XP 1800+, ~1.5GHz
Memory: 256MB RAM
Page File: 271MB used, 347MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.0001.0904 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce2 MX/MX 400
Manufacturer: NVIDIA
Chip type: GeForce2 MX/MX 400
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_0110&SUBSYS_D351107D&REV_B2
Display Memory: 64.0 MB
Current Mode: 1024 x 768 (32 bit) (60Hz)
Monitor: Monitor A727 Packard Bell
Monitor Max Res: 1280,1024
Driver Name: nv4_disp.dll
Driver Version: 6.14.0010.9371 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 10/22/2006 12:22:00, 4527488 bytes
WHQL Logo’d: Yes
WHQL Date Stamp: n/a
VDD: n/a
Mini VDD: nv4_mini.sys
Mini VDD Date: 10/22/2006 12:22:00, 3994624 bytes
Device Identifier: {D7B71E3E-4250-11CF-5657-5BF313C2CB35}
Vendor ID: 0x10DE
Device ID: 0x0110
SubSys ID: 0xD351107D
Revision ID: 0x00B2
Revision ID: 0x00B2
Video Accel: ModeMPEG2_A ModeMPEG2_B ModeMPEG2_C ModeMPEG2_D
Deinterlace Caps: {212DC723-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_MedianFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{212DC723-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_MedianFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{212DC723-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_MedianFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{212DC723-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_MedianFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Sound Devices
Description: NEC VIA Audio
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: PCI\VEN_1106&DEV_3058&SUBSYS_20031631&REV_50
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: cviaaud.sys
Driver Version: 6.13.0010.8060 (English)
WHQL Logo’d: Yes
Date and Size: 9/20/2001 11:33:40, 320864 bytes
Other Files:
Driver Provider: NEC
HW Accel Level: Full
Cap Flags: 0xF5F
Min/Max Sample Rate: 8000, 48000
Static/Strm HW Mix Bufs: 7, 6
Static/Strm HW 3D Bufs: 7, 6
HW Memory: 0
Voice Management: No
EAX� 2.0 Listen/Src: Yes, Yes
I3DL2� Listen/Src: No, No
Sensaura� ZoomFX�: No
Registry: OK
Sound Test Result: Not run
Sound Capture Devices
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x41
Format Flags: 0xFFF
DirectMusic
DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS
DLS Version: 1.00.0016.0002
Acceleration: n/a
Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port
NEC VIA Audio, Software (Kernel Mode), Output, DLS, Internal
Mappeur MIDI Microsoft [Émulé], Hardware (Not Kernel Mode), Output, No DLS, Internal
Synthé. SW table de sons GS Mic [Émulé], Hardware (Not Kernel Mode), Output, No DLS, Internal
Registry: OK
DirectInput Devices
Device Name: Souris
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Clavier
Attached: 1
Controller ID: n/a
FF Driver: n/a
Device Name: USB Keyboard
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x1631, 0x5002
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Poll w/ Interrupt: No
Registry: OK
USB Devices
- Concentrateur USB racine
| Vendor/Product ID: 0x1106, 0x3038
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 8/28/2001 12:00:00, 50688 bytes
| Driver: usbd.sys, 8/28/2001 12:00:00, 4736 bytes
Gameport Devices
PS/2 Devices
- Périphérique clavier PIH
| Matching Device ID: hid_device_system_keyboard
| Service: kbdhid
| Driver: kbdhid.sys, 8/28/2001 12:00:00, 14080 bytes
| Driver: kbdclass.sys, 8/28/2001 12:00:00, 24064 bytes
| - Pilote clavier de Terminal Server
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: termdd.sys, 8/18/2001 06:38:00, 37896 bytes
| - HID-compliant Wheel Mouse
| Vendor/Product ID: 0x046D, 0xC001
| Matching Device ID: hid\vid_046d&pid_c001
| Lower Filters: LHidFlt2
| Service: mouhid
| Driver: mouhid.sys, 8/23/2001 17:04:42, 12288 bytes
| Driver: mouclass.sys, 8/23/2001 17:04:42, 22656 bytes
| Driver: LHidFlt2.sys, 8/20/2001 09:40:00, 21934 bytes
| Driver: LMouFlt2.sys, 8/20/2001 09:40:00, 67406 bytes
| Driver: LKbdFlt2.sys, 8/20/2001 09:40:00, 5838 bytes
| Driver: LCoInst.dll, 8/20/2001 09:40:00, 19180 bytes
| - Pilote souris de Terminal Server
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
DirectPlay Service Providers
DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.0000.0900)
DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.0000.0900)
DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.0000.0900)
DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.0000.0900)
Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.0001.0904)
IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.0001.0904)
Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.0000.0900)
Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.0000.0900)
DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Not run, Mic: Not run
DirectPlay Test Result: Not run
Registry: OK
DirectPlay Adapters
DirectPlay8 Modem Service Provider: Aztech CNR V.92 Modem
DirectPlay8 Serial Service Provider: COM1
DirectPlay8 Serial Service Provider: COM3
DirectPlay8 TCP/IP Service Provider: Wanadoo - IPv4 -
DirectPlay Voice Codecs
Voxware VR12 1.4kbit/s
Voxware SC06 6.4kbit/s
Voxware SC03 3.2kbit/s
MS-PCM 64 kbit/s
MS-ADPCM 32.8 kbit/s
Microsoft GSM 6.10 13 kbit/s
TrueSpeech� 8.6 kbit/s
DirectPlay Lobbyable Apps
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 13.1 GB
Total Space: 36.2 GB
File System: NTFS
Model: ST340810A
Drive: D:
Model: HL-DT-ST DVD-ROM GDR8160B
Driver: c:\windows\system32\drivers\cdrom.sys, 5.01.2600.0000 (French), 8/28/2001 12:00:00, 47488 bytes
Drive: E:
Model: IDE-CD R/RW 12x8x32
System Devices
Name: Contrôleur CPU vers AGP VIA Tech
Device ID: PCI\VEN_1106&DEV_8305&SUBSYS_00000000&REV_00\3&61AAA01&0&08
Driver: C:\WINDOWS\System32\DRIVERS\VIAAGP.SYS, 5.01.2600.0000 (English), 8/17/2001 21:58:02, 27392 bytes
Name: Aztech CNR V.92 Modem
Device ID: PCI\VEN_1106&DEV_3068&SUBSYS_30031631&REV_30\3&61AAA01&0&3E
Driver: C:\WINDOWS\Modio\SLAMRNTO\slclean.exe, 1.00.0000.0013 (English), 11/29/2001 16:09:22, 192512 bytes
Driver: C:\WINDOWS\Modio\SLAMRNTO\slclean.ini, 1/14/2002 14:57:20, 2309 bytes
Driver: C:\WINDOWS\Modio\SLAMRNTO\slclean.dll, 11/29/2001 16:09:22, 98304 bytes
Driver: C:\WINDOWS\System32\Drivers\mtlmnt5.sys, 1.53.0001.0001 (English), 11/29/2001 16:09:14, 172708 bytes
Driver: C:\WINDOWS\System32\Drivers\mtlstrm.sys, 0.98.0001.0001 (English), 11/29/2001 16:09:18, 2383460 bytes
Driver: C:\WINDOWS\System32\Drivers\v90drv.sys, 4.00.0001.0001 (English), 11/29/2001 16:09:32, 1432836 bytes
Driver: C:\WINDOWS\System32\Drivers\slnthal.sys, 4.00.1381.0001 (English), 11/29/2001 16:09:26, 175160 bytes
Driver: C:\WINDOWS\System32\Drivers\ntmtlfax.sys, 4.00.0001.0001 (English), 11/29/2001 16:09:20, 607732 bytes
Driver: C:\WINDOWS\System32\Drivers\slntamr.sys, 5.00.0001.0000 (English), 12/5/2001 14:48:12, 322948 bytes
Driver: C:\WINDOWS\System32\Drivers\slwdmsup.sys, 4.00.0001.0001 (English), 11/29/2001 16:09:28, 33028 bytes
Driver: C:\WINDOWS\System32\slcpappl.cpl, 2.83.0000.0000 (English), 11/29/2001 16:09:44, 475136 bytes
Driver: C:\WINDOWS\System32\amr_cpl.dll, 2.81.0000.0000 (English), 11/29/2001 16:09:36, 151552 bytes
Driver: C:\WINDOWS\System32\slcpappl.chm, 11/29/2001 16:09:24, 132570 bytes
Driver: C:\WINDOWS\System32\minirec.exe, 1.00.0000.0001 (English), 11/29/2001 16:09:14, 163840 bytes
Driver: C:\WINDOWS\System32\winddx.sys, 5.00.0001.0001 (English), 11/29/2001 16:09:32, 42296 bytes
Driver: C:\WINDOWS\smcfg.exe, 2.80.0001.0000 (English), 11/29/2001 16:09:28, 73728 bytes
Driver: C:\WINDOWS\sllights.exe, 2.00.0009.0009 (English), 11/29/2001 16:09:26, 425984 bytes
Driver: C:\WINDOWS\sl.lng, 11/29/2001 16:09:20, 49600 bytes
Driver: C:\WINDOWS\System32\coinst.dll, 1.00.0000.0001 (English), 11/29/2001 16:09:12, 45056 bytes
Driver: C:\WINDOWS\System32\slserv.exe, 1.00.0000.0001 (English), 11/29/2001 16:09:28, 45056 bytes
Driver: C:\WINDOWS\System32\slextspk.dll, 1.00.0000.0001 (English), 11/29/2001 16:09:36, 196608 bytes
Name: AC-Link 3D Game Audio
Device ID: PCI\VEN_1106&DEV_3058&SUBSYS_20031631&REV_50\3&61AAA01&0&3D
Driver: C:\WINDOWS\system32\drivers\drmk.sys, 5.01.2600.0000 (English), 8/17/2001 22:01:20, 57344 bytes
Driver: C:\WINDOWS\system32\drivers\portcls.sys, 5.01.2600.0000 (English), 8/18/2001 06:24:38, 135040 bytes
Driver: C:\WINDOWS\system32\drivers\stream.sys, 5.03.0001.0904 (French), 7/9/2004 04:27:28, 48512 bytes
Driver: C:\WINDOWS\System32\wdmaud.drv, 5.01.2600.0000 (English), 8/23/2001 17:47:52, 22016 bytes
Driver: C:\WINDOWS\System32\ksuser.dll, 5.03.0000.0900 (French), 12/12/2002 00:14:32, 4096 bytes
Driver: C:\WINDOWS\system32\drivers\cviaaud.sys, 6.13.0010.8060 (English), 9/20/2001 11:33:40, 320864 bytes
Driver: C:\WINDOWS\system32\drivers\cviahal.sys, 6.13.0010.8060 (English), 9/20/2001 11:36:14, 214688 bytes
Driver: C:\WINDOWS\ciaunwdm.exe, 6.13.0010.8060 (English), 9/20/2001 11:20:46, 28672 bytes
Name: Contrôleur de gestion de l'alimentation VIA Tech
Device ID: PCI\VEN_1106&DEV_3057&SUBSYS_30571106&REV_40\3&61AAA01&0&3C
Driver: n/a
Name: Contrôleur hôte universel USB Rev 5 ou ultérieur VIA
Device ID: PCI\VEN_1106&DEV_3038&SUBSYS_12340925&REV_1A\3&61AAA01&0&3B
Driver: C:\WINDOWS\system32\drivers\usbuhci.sys, 5.01.2600.0000 (English), 8/28/2001 12:00:00, 18944 bytes
Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.0000 (English), 8/28/2001 12:00:00, 123264 bytes
Driver: C:\WINDOWS\System32\usbui.dll, 5.01.2600.0000 (French), 8/23/2001 17:47:20, 70144 bytes
Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.0000 (English), 8/28/2001 12:00:00, 50688 bytes
Device ID: PCI\VEN_1106&DEV_3038&SUBSYS_12340925&REV_1A\3&61AAA01&0&3A
Name: Pont PCI vers ISA VIA Tech
Device ID: PCI\VEN_1106&DEV_0686&SUBSYS_00000000&REV_40\3&61AAA01&0&38
Driver: C:\WINDOWS\System32\DRIVERS\isapnp.sys, 5.01.2600.0000 (French), 8/28/2001 12:00:00, 36224 bytes
Name: Contrôleur IDE Bus Master VIA
Device ID: PCI\VEN_1106&DEV_0571&SUBSYS_05711631&REV_06\3&61AAA01&0&39
Driver: C:\WINDOWS\System32\DRIVERS\viaide.sys, 1.00.0001.0000 (English), 8/28/2001 12:00:00, 4352 bytes
Driver: C:\WINDOWS\System32\DRIVERS\pciidex.sys, 5.01.2600.0000 (French), 8/28/2001 12:00:00, 23680 bytes
Driver: C:\WINDOWS\System32\DRIVERS\atapi.sys, 5.01.2600.0000 (English), 8/28/2001 12:00:00, 86656 bytes
Name: Pont CPU vers PCI VIA Tech
Device ID: PCI\VEN_1106&DEV_0305&SUBSYS_00000000&REV_81\3&61AAA01&0&00
Driver: n/a
Name: NVIDIA GeForce2 MX/MX 400
Device ID: PCI\VEN_10DE&DEV_0110&SUBSYS_D351107D&REV_B2\4&9AEDED5&0&0008
Driver: C:\WINDOWS\System32\DRIVERS\nv4_mini.sys, 6.14.0010.9371 (English), 10/22/2006 12:22:00, 3994624 bytes
Driver: C:\WINDOWS\System32\nv4_disp.dll, 6.14.0010.9371 (English), 10/22/2006 12:22:00, 4527488 bytes
Driver: C:\WINDOWS\System32\nvsvc32.exe, 6.14.0010.9371 (English), 10/22/2006 12:22:00, 159810 bytes
Driver: C:\WINDOWS\System32\nvhwvid.dll, 6.14.0010.9371 (), 10/22/2006 12:22:00, 581632 bytes
Driver: C:\WINDOWS\System32\nvapi.dll, 6.14.0010.9371 (), 10/22/2006 12:22:00, 212992 bytes
Driver: C:\WINDOWS\System32\nvoglnt.dll, 6.14.0010.9371 (English), 10/22/2006 12:22:00, 5644288 bytes
Driver: C:\WINDOWS\System32\nvcpl.dll, 6.14.0010.9371 (English), 10/22/2006 12:22:00, 7700480 bytes
Driver: C:\WINDOWS\System32\nvmctray.dll, 6.14.0010.9371 (English), 10/22/2006 12:22:00, 86016 bytes
Driver: C:\WINDOWS\System32\nvwddi.dll, 6.14.0010.9371 (English), 10/22/2006 12:22:00, 81920 bytes
Driver: C:\WINDOWS\System32\nvnt4cpl.dll, 6.14.0010.11060 (English), 10/22/2006 12:22:00, 286720 bytes
Driver: C:\WINDOWS\System32\nvmccs.dll, 6.14.0010.9371 (English), 10/22/2006 12:22:00, 229376 bytes
Driver: C:\WINDOWS\System32\nvdisps.dll, 6.14.0010.9371 (English), 10/22/2006 12:22:00, 5619712 bytes
Driver: C:\WINDOWS\System32\nvdispsr.dll, 6.14.0010.9371 (French), 10/22/2006 12:22:00, 5255168 bytes
Driver: C:\WINDOWS\System32\nvgames.dll, 6.14.0010.9371 (English), 10/22/2006 12:22:00, 3047424 bytes
Driver: C:\WINDOWS\System32\nvgamesr.dll, 6.14.0010.9371 (French), 10/22/2006 12:22:00, 3203072 bytes
Driver: C:\WINDOWS\System32\nvmccss.dll, 6.14.0010.9371 (English), 10/22/2006 12:22:00, 188416 bytes
Driver: C:\WINDOWS\System32\nvmccssr.dll, 6.14.0010.9371 (French), 10/22/2006 12:22:00, 458752 bytes
Driver: C:\WINDOWS\System32\nvmobls.dll, 6.14.0010.9371 (English), 10/22/2006 12:22:00, 888832 bytes
Driver: C:\WINDOWS\System32\nvmoblsr.dll, 6.14.0010.9371 (French), 10/22/2006 12:22:00, 2859008 bytes
Driver: C:\WINDOWS\System32\nvvitvs.dll, 6.14.0010.9371 (English), 10/22/2006 12:22:00, 2924544 bytes
Driver: C:\WINDOWS\System32\nvvitvsr.dll, 6.14.0010.9371 (French), 10/22/2006 12:22:00, 2973696 bytes
Driver: C:\WINDOWS\System32\nvwss.dll, 6.14.0010.9371 (English), 10/22/2006 12:22:00, 1236992 bytes
Driver: C:\WINDOWS\System32\nvwssr.dll, 6.14.0010.9371 (French), 10/22/2006 12:22:00, 1732608 bytes
Driver: C:\WINDOWS\help\nvcpl.hlp, 10/22/2006 12:22:00, 177897 bytes
Driver: C:\WINDOWS\help\nvwcplen.hlp, 10/22/2006 12:22:00, 55444 bytes
Driver: C:\WINDOWS\System32\nvcod.dll, 1.00.0000.0035 (English), 10/22/2006 12:22:00, 35840 bytes
Driver: C:\WINDOWS\System32\nvcodins.dll, 1.00.0000.0035 (English), 10/22/2006 12:22:00, 35840 bytes
DirectX Components
ddraw.dll: 5.03.0001.0904 French Final Retail 7/9/2004 04:27:28 292864 bytes
ddrawex.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 24064 bytes
dxapi.sys: 5.01.2600.0000 English Final Retail 8/28/2001 12:00:00 10496 bytes
d3d8.dll: 5.03.0001.0904 French Final Retail 7/9/2004 04:27:28 1201152 bytes
d3d8thk.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 8192 bytes
d3d9.dll: 5.03.0001.0904 French Final Retail 7/9/2004 04:27:28 1703936 bytes
d3dim.dll: 5.01.2600.0000 English Final Retail 8/28/2001 12:00:00 436224 bytes
d3dim700.dll: 5.03.0001.0902 English Final Retail 5/30/2003 09:00:02 797184 bytes
d3dramp.dll: 5.01.2600.0000 English Final Retail 8/28/2001 12:00:00 590336 bytes
d3drm.dll: 5.01.2600.0000 English Final Retail 8/28/2001 12:00:00 350208 bytes
d3dxof.dll: 5.01.2600.0000 English Final Retail 8/28/2001 12:00:00 47616 bytes
d3dpmesh.dll: 5.01.2600.0000 English Final Retail 8/28/2001 12:00:00 34816 bytes
dplay.dll: 5.00.2134.0001 French Final Retail 8/28/2001 12:00:00 33040 bytes
dplayx.dll: 5.03.0001.0904 English Final Retail 7/9/2004 04:27:28 230400 bytes
dpmodemx.dll: 5.03.0000.0900 French Final Retail 12/12/2002 00:14:32 77824 bytes
dpwsock.dll: 5.00.2134.0001 English Final Retail 8/28/2001 12:00:00 42768 bytes
dpwsockx.dll: 5.03.0001.0904 French Final Retail 7/9/2004 04:27:28 79360 bytes
dplaysvr.exe: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 28160 bytes
dpnsvr.exe: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 16896 bytes
dpnet.dll: 5.03.0000.0900 French Final Retail 12/12/2002 00:14:32 723968 bytes
dpnlobby.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 3072 bytes
dpnaddr.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 3072 bytes
dpvoice.dll: 5.03.0000.0900 French Final Retail 12/12/2002 00:14:32 381952 bytes
dpvsetup.exe: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 80896 bytes
dpvvox.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 112128 bytes
dpvacm.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 19968 bytes
dpnhpast.dll: 5.03.0000.0901 English Final Retail 3/24/2003 09:00:02 32768 bytes
dpnhupnp.dll: 5.03.0000.0901 English Final Retail 3/24/2003 09:00:02 68096 bytes
dpserial.dll: 5.00.2134.0001 French Final Retail 8/28/2001 12:00:00 54032 bytes
dinput.dll: 5.01.2600.1106 French Final Retail 8/29/2002 03:40:00 648704 bytes
dinput8.dll: 5.01.2600.1106 French Final Retail 8/29/2002 03:40:00 667648 bytes
dimap.dll: 5.01.2600.0000 English Final Retail 8/28/2001 12:00:00 44032 bytes
diactfrm.dll: 5.01.2600.0000 French Final Retail 8/28/2001 12:00:00 395264 bytes
joy.cpl: 5.01.2600.1106 French Final Retail 8/29/2002 03:41:00 208896 bytes
gcdef.dll: 5.01.2600.0000 French Final Retail 8/28/2001 12:00:00 77824 bytes
pid.dll: 5.01.2600.1106 English Final Retail 8/29/2002 03:41:00 31744 bytes
dsound.dll: 5.03.0001.0904 French Final Retail 7/9/2004 04:27:28 381952 bytes
dsound3d.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 1294336 bytes
dswave.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 18432 bytes
dsdmo.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 186880 bytes
dsdmoprp.dll: 5.03.0000.0900 French Final Retail 12/12/2002 00:14:32 491520 bytes
dmusic.dll: 5.03.0001.0904 French Final Retail 7/9/2004 04:27:28 122880 bytes
dmband.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 27136 bytes
dmcompos.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 58368 bytes
dmime.dll: 5.03.0001.0904 English Final Retail 7/9/2004 04:27:28 181248 bytes
dmloader.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 33280 bytes
dmstyle.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 98816 bytes
dmsynth.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 100864 bytes
dmscript.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 76800 bytes
dx7vb.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 602624 bytes
dx8vb.dll: 5.03.0001.0902 English Final Retail 5/30/2003 09:00:02 1189888 bytes
dxdiagn.dll: 5.03.0001.0904 French Final Retail 7/9/2004 04:27:28 1769472 bytes
mfc40.dll: 4.01.0000.6140 English Final Retail 8/28/2001 12:00:00 924432 bytes
mfc42.dll: 6.00.8665.0000 English Beta Retail 8/28/2001 12:00:00 995383 bytes
wsock32.dll: 5.01.2600.0000 French Final Retail 8/28/2001 12:00:00 24064 bytes
amstream.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 64512 bytes
devenum.dll: 6.05.0001.0902 French Final Retail 5/30/2003 09:00:02 132608 bytes
dxmasf.dll: 6.04.0009.1120 French Final Retail 8/28/2001 12:00:00 499741 bytes
mciqtz32.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 34304 bytes
mpg2splt.ax: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 136192 bytes
msdmo.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 13312 bytes
encapi.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 18944 bytes
qasf.dll: 10.00.0000.3802 English Final Retail 1/28/2005 12:44:28 221184 bytes
qcap.dll: 6.05.0001.0900 French Final Retail 12/12/2002 00:14:32 257024 bytes
qdv.dll: 6.05.0001.0904 French Final Retail 7/9/2004 04:27:28 316928 bytes
qdvd.dll: 6.05.0001.0904 French Final Retail 7/9/2004 04:27:28 470528 bytes
qedit.dll: 6.05.0001.0900 French Final Retail 12/12/2002 00:14:32 1798144 bytes
qedwipes.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 733184 bytes
quartz.dll: 6.05.0001.0902 French Final Retail 5/30/2003 09:00:02 1962496 bytes
strmdll.dll: 4.01.0000.3925 French Final Retail 8/28/2001 12:00:00 246302 bytes
iac25_32.ax: 2.00.0005.0053 English Final Retail 8/28/2001 12:00:00 199680 bytes
ir41_32.ax: 4.51.0016.0003 English Final Retail 8/28/2001 12:00:00 848384 bytes
ir41_qc.dll: 4.30.0062.0002 English Final Retail 8/28/2001 12:00:00 120320 bytes
ir41_qcx.dll: 4.30.0064.0001 English Final Retail 8/28/2001 12:00:00 338432 bytes
ir50_32.dll: 5.2562.0015.0055 English Final Retail 8/28/2001 12:00:00 755200 bytes
ir50_qc.dll: 5.00.0063.0048 English Final Retail 8/28/2001 12:00:00 200192 bytes
ir50_qcx.dll: 5.00.0064.0048 English Final Retail 8/28/2001 12:00:00 183808 bytes
ivfsrc.ax: 5.10.0002.0051 English Final Retail 8/28/2001 12:00:00 154624 bytes
mswebdvd.dll: 6.05.0001.0900 French Final Retail 12/12/2002 00:14:32 324096 bytes
msdvdopt.dll: 5.01.2600.0000 French Final Retail 8/28/2001 12:00:00 75776 bytes
ks.sys: 5.03.0000.0900 French Final Retail 12/12/2002 00:14:32 130304 bytes
ksproxy.ax: 5.03.0000.0900 French Final Retail 12/12/2002 00:14:32 117248 bytes
ksuser.dll: 5.03.0000.0900 French Final Retail 12/12/2002 00:14:32 4096 bytes
stream.sys: 5.03.0001.0904 French Final Retail 7/9/2004 04:27:28 48512 bytes
mspclock.sys: 5.03.0000.0900 French Final Retail 12/12/2002 00:14:32 5248 bytes
mspqm.sys: 5.01.2600.0000 French Final Retail 8/23/2001 05:00:00 4608 bytes
mskssrv.sys: 5.03.0000.0900 French Final Retail 12/12/2002 00:14:32 7424 bytes
swenum.sys: 5.03.0000.0900 French Final Retail 12/12/2002 00:14:32 4096 bytes
mstee.sys: 5.03.0000.0900 French Final Retail 12/12/2002 00:14:32 5504 bytes
bdaplgin.ax: 5.03.0000.0900 French Final Retail 7/9/2004 04:26:38 16896 bytes
bdasup.sys: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:38 11392 bytes
msdvbnp.ax: 6.05.0001.0900 English Final Retail 7/9/2004 04:26:38 52224 bytes
psisdecd.dll: 6.05.0001.0900 English Final Retail 7/9/2004 04:26:40 354816 bytes
psisrndr.ax: 6.05.0001.0900 English Final Retail 7/9/2004 04:26:40 30208 bytes
ipsink.ax: 5.03.0000.0900 French Final Retail 7/9/2004 04:26:38 14848 bytes
mpeg2data.ax: 6.05.0001.0900 English Final Retail 7/9/2004 04:26:38 57856 bytes
ndisip.sys: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:38 10112 bytes
mpe.sys: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:38 15104 bytes
streamip.sys: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:40 14976 bytes
msvidctl.dll: 6.05.0001.0900 English Final Retail 7/9/2004 04:26:38 1230336 bytes
slip.sys: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:40 10880 bytes
nabtsfec.sys: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:38 83968 bytes
ccdecode.sys: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:38 16384 bytes
vbisurf.ax: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:40 27648 bytes
msyuv.dll: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:38 16896 bytes
kstvtune.ax: 5.03.0001.0904 French Final Retail 7/19/2004 16:19:30 285696 bytes
ksxbar.ax: 5.03.0001.0902 English Final Retail 7/9/2004 04:26:38 39424 bytes
kswdmcap.ax: 5.03.0000.0900 French Final Retail 7/9/2004 04:26:40 226304 bytes
wstcodec.sys: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:40 18688 bytes
wstdecod.dll: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:40 47104 bytes
msdv.sys: 5.01.2600.0000 English Final Retail 7/9/2004 04:26:38 52096 bytes
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,
WMAPro over S/PDIF DMO,0x00600800,1,1,
WMSpeech Decoder DMO,0x00600800,1,1,
WMVideo Advanced Decoder DMO,0x00800001,1,1,
Mpeg4s Decoder DMO,0x00800001,1,1,
WMV Screen decoder DMO,0x00800001,1,1,
WMVideo Decoder DMO,0x00800001,1,1,
Mpeg43 Decoder DMO,0x00800001,1,1,
Mpeg4 Decoder DMO,0x00800001,1,1,
Full Screen Renderer,0x00200000,1,0,quartz.dll,6.05.0001.0902
DV Muxer,0x00400000,0,0,qdv.dll,6.05.0001.0904
Color Space Converter,0x00400001,1,1,quartz.dll,6.05.0001.0902
WM ASF Reader,0x00400000,0,0,qasf.dll,10.00.0000.3802
Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,10.00.0000.3802
AVI Splitter,0x00600000,1,1,quartz.dll,6.05.0001.0902
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.05.0001.0902
Indeo® video 5.10 Compression Filter,0x00200000,1,1,IR50_32.DLL,5.2562.0015.0055
Windows Media Audio Decoder,0x00800001,1,1,msadds32.ax,8.00.0000.4477
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.05.0001.0900
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.05.0001.0902
Indeo® video 5.10 Decompression Filter,0x00640000,1,1,IR50_32.DLL,5.2562.0015.0055
Microsoft Screen Video Decompressor,0x00800000,1,1,msscds32.ax,8.00.0000.4477
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.05.0001.0902
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.05.0001.0902
MPEG Layer-3 Decoder,0x00810000,1,1,l3codecx.ax,1.05.0000.0050
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.05.0001.0900
ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,acelpdec.ax,1.04.0000.0000
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.05.0001.0902
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.05.0001.0902
File Source (Netshow URL),0x00400000,0,1,wmpasf.dll,10.00.0000.3802
DV Splitter,0x00600000,1,2,qdv.dll,6.05.0001.0904
Windows Media Video Decoder,0x00800000,1,1,wmvds32.ax,8.00.0000.4477
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.05.0001.0902
Windows Media Video Decoder,0x00800000,1,1,wmv8ds32.ax,8.00.0000.4000
Windows Media Multiplexer,0x00600000,1,1,wmpasf.dll,10.00.0000.3802
ASX file Parser,0x00600000,1,1,wmpasf.dll,10.00.0000.3802
ASX v.2 file Parser,0x00600000,1,0,wmpasf.dll,10.00.0000.3802
NSC file Parser,0x00600000,1,1,wmpasf.dll,10.00.0000.3802
ACM Wrapper,0x00600000,1,1,quartz.dll,6.05.0001.0902
Windows Media source filter,0x00600000,0,2,wmpasf.dll,10.00.0000.3802
Video Renderer,0x00800001,1,0,quartz.dll,6.05.0001.0902
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.05.0001.0904
Video Port Manager,0x00600000,2,1,quartz.dll,6.05.0001.0902
WST Decoder,0x00600000,1,1,wstdecod.dll,5.03.0000.0900
Video Renderer,0x00400000,1,0,quartz.dll,6.05.0001.0902
DivX Decoder Filter,0xff800000,1,1,divxdec.ax,6.01.0001.1031
WM ASF Writer,0x00400000,0,0,qasf.dll,10.00.0000.3802
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,5.03.0000.0900
Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,mpg4ds32.ax,8.00.0000.4477
DivX Demux,0x00600000,1,0,DivXMedia.ax,0.00.0000.0026
File writer,0x00200000,1,0,qcap.dll,6.05.0001.0900
DVD Navigator,0x00200000,0,2,qdvd.dll,6.05.0001.0904
CyberLink Audio Decoder,0x00601000,1,1,claud.ax,3.05.0000.0813
CyberLink Video/SP Decoder,0x00600000,2,2,clvsd.ax,3.05.0000.0903
Overlay Mixer2,0x00400000,1,1,qdvd.dll,6.05.0001.0904
AVI Draw,0x00600064,9,1,quartz.dll,6.05.0001.0902
.RAM file Parser,0x00600000,1,0,wmpasf.dll,10.00.0000.3802
G.711 Codec,0x00200000,1,1,g711codc.ax,5.01.2600.0000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.05.0001.0900
DV Video Decoder,0x00800000,1,1,qdv.dll,6.05.0001.0904
Indeo® audio software,0x00500000,1,1,IAC25_32.AX,2.00.0005.0053
Windows Media Update Filter,0x00400000,1,0,wmpasf.dll,10.00.0000.3802
ASF DIB Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3802
ASF ACM Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3802
ASF ICM Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3802
ASF URL Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3802
ASF JPEG Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3802
ASF DJPEG Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3802
ASF embedded stuff Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3802
DivX Subtitle Decoder,0x00600000,1,1,DivXMedia.ax,0.00.0000.0026
WIA Stream Snapshot Filter,0x00200000,1,1,wiasf.ax,1.00.0000.0000
SampleGrabber,0x00200000,1,1,qedit.dll,6.05.0001.0900
Null Renderer,0x00200000,1,0,qedit.dll,6.05.0001.0900
MPEG-2 Sections and Tables,0x005fffff,1,0,mpeg2data.ax,6.05.0001.0900
IVF source filter,0x00600000,0,1,ivfsrc.ax,5.10.0002.0051
Smart Tee,0x00200000,1,2,qcap.dll,6.05.0001.0900
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.05.0001.0904
RealPlayer Audio Filter,0x00200000,1,1,rdsf3260.dll,6.00.0012.1477
AVI Decompressor,0x00600000,1,1,quartz.dll,6.05.0001.0902
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.05.0001.0902
QuickTime Movie Parser,0x00600000,1,1,quartz.dll,6.05.0001.0902
Wave Parser,0x00400000,1,1,quartz.dll,6.05.0001.0902
MIDI Parser,0x00400000,1,1,quartz.dll,6.05.0001.0902
Multi-file Parser,0x00400000,1,1,quartz.dll,6.05.0001.0902
Lyric Parser,0x00400000,1,1,quartz.dll,6.05.0001.0902
File stream renderer,0x00400000,1,1,quartz.dll,6.05.0001.0902
XML Playlist,0x00400000,1,0,wmpasf.dll,10.00.0000.3802
AVI Mux,0x00200000,1,0,qcap.dll,6.05.0001.0900
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.05.0001.0902
File Source (Async.),0x00400000,0,1,quartz.dll,6.05.0001.0902
File Source (URL),0x00400000,0,1,quartz.dll,6.05.0001.0902
Windows Media Pad VU Data Grabber,0x00600000,1,0,wmmfilt.dll,1.01.2427.0000
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.05.0001.0900
BDA MPEG2 Transport Information Filter,0x00200000,1,0,psisrndr.ax,6.05.0001.0900
QT Decompressor,0x00600000,1,1,quartz.dll,6.05.0001.0902
ShotBoundaryDet,0x00200000,1,1,wmmfilt.dll,1.01.2427.0000
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.05.0001.0902
Indeo® video 4.4 Decompression Filter,0x00640000,1,1,IR41_32.AX,4.51.0016.0003
Indeo® video 4.4 Compression Filter,0x00200000,1,1,IR41_32.AX,4.51.0016.0003
Transformateurs de répartition de données WDM:
Suppresseur d’écho acoustique (Noyau Microsoft),0x00200000,2,2,5.03.0000.0900
Synthétiseur de table de sons GC noyau Microsoft,0x00200000,1,1,5.03.0000.0900
Synthétiseur DLS du noyau Microsoft,0x00200000,1,1,5.03.0000.0900
Filtre de décodeur DRM (Noyau Microsoft),0x00200000,1,1,5.03.0000.0900
Video Compressors:
WMVideo Encoder DMO,0x00600800,1,1,
MSScreen encoder DMO,0x00600800,1,1,
WMVideo9 Encoder DMO,0x00600800,1,1,
WMVideo Advanced Encoder DMO,0x00600800,1,1,
MSScreen 9 encoder DMO,0x00600800,1,1,
DV Video Encoder,0x00200000,0,0,qdv.dll,6.05.0001.0904
Indeo® video 5.10 Compression Filter,0x00100000,1,1,IR50_32.DLL,5.2562.0015.0055
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.05.0001.0902
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.05.0001.0900
DivX® 6.1.1 Codec (1 Logical CPU),0x00200000,1,1,qcap.dll,6.05.0001.0900
Intel 4:2:0 Video V2.50,0x00200000,1,1,qcap.dll,6.05.0001.0900
Intel Indeo® Video R3.2,0x00200000,1,1,qcap.dll,6.05.0001.0900
Intel Indeo® Video 4.5,0x00200000,1,1,qcap.dll,6.05.0001.0900
Indeo® video 5.10,0x00200000,1,1,qcap.dll,6.05.0001.0900
Codec Intel IYUV,0x00200000,1,1,qcap.dll,6.05.0001.0900
Microsoft H.261 Video Codec,0x00200000,1,1,qcap.dll,6.05.0001.0900
Microsoft H.263 Video Codec,0x00200000,1,1,qcap.dll,6.05.0001.0900
Microsoft RLE,0x00200000,1,1,qcap.dll,6.05.0001.0900
Microsoft Vidéo 1,0x00200000,1,1,qcap.dll,6.05.0001.0900
Microsoft Windows Media Video 9,0x00200000,1,1,qcap.dll,6.05.0001.0900
DivX® 6.1.1 YV12 Decoder,0x00200000,1,1,qcap.dll,6.05.0001.0900
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,
WMAudio Encoder DMO,0x00600800,1,1,
IAC2,0x00200000,1,1,quartz.dll,6.05.0001.0902
IMA ADPCM,0x00200000,1,1,quartz.dll,6.05.0001.0902
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.05.0001.0902
ACELP.net,0x00200000,1,1,quartz.dll,6.05.0001.0902
DSP Group TrueSpeech�,0x00200000,1,1,quartz.dll,6.05.0001.0902
Windows Media Audio V1,0x00200000,1,1,quartz.dll,6.05.0001.0902
Windows Media Audio V2,0x00200000,1,1,quartz.dll,6.05.0001.0902
GSM 6.10,0x00200000,1,1,quartz.dll,6.05.0001.0902
MSN Messenger Audio Codec,0x00200000,1,1,quartz.dll,6.05.0001.0902
Microsoft G.723.1,0x00200000,1,1,quartz.dll,6.05.0001.0902
CCITT A-Law,0x00200000,1,1,quartz.dll,6.05.0001.0902
CCITT u-Law,0x00200000,1,1,quartz.dll,6.05.0001.0902
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.05.0001.0902
Audio Capture Sources:
NEC VIA Audio,0x00200000,0,0,qcap.dll,6.05.0001.0900
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.05.0001.0902
Synthé. SW table de sons GS Mic,0x00200000,1,0,quartz.dll,6.05.0001.0902
Périphériques de capture de flux WDM:
NEC VIA Audio,0x00200000,3,2,5.03.0000.0900
Périphériques de répartition de rendu WDM:
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,msdvbnp.ax,6.05.0001.0900
Microsoft DVBC Network Provider,0x00200000,0,1,msdvbnp.ax,6.05.0001.0900
Microsoft DVBS Network Provider,0x00200000,0,1,msdvbnp.ax,6.05.0001.0900
Microsoft DVBT Network Provider,0x00200000,0,1,msdvbnp.ax,6.05.0001.0900
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,1,0,psisrndr.ax,6.05.0001.0900
MPEG-2 Sections and Tables,0x00600000,1,0,mpeg2data.ax,6.05.0001.0900
Périphériques de répartition de mélangeur WDM:
Mélangeur audio Wave de noyau Microsoft,0x00200000,2,2,5.03.0000.0900
Audio Renderers:
NEC VIA Audio,0x00200000,1,0,quartz.dll,6.05.0001.0902
CyberLink Audio Renderer,0x00200000,1,0,cladr.ax,3.05.0000.0803
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.05.0001.0902
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.05.0001.0902
DirectSound: NEC VIA Audio,0x00200000,1,0,quartz.dll,6.05.0001.0902
Périphériques système répartis WDM:
NEC VIA Audio,0x00200000,13,3,5.03.0000.0900
Tu connait une bonne carte vidéo que je pourrait installer sur mon pc ? et comment fait 'on ?
est ce que tu croit que cette carte video je peut la mettre sur mon pc ?
Carte Graphique GeForce 6200 TC - 128 Mo DDR (supporte jusqu’à 256 Mo) - 128 bits - PCI Express
Vitesse Processeur - GPU : 350 MHz
Interface mémoire : 128 bits
Ramdac : 400 MHz
Processeur graphique : GeForce FX 6200 TC
Mémoire : 128 Mo DDR (supporte jusqu’à 256 Mo)
Bus : PCI Express
Sortie TV : Oui
Sortie DVI : DVI
Autres sorties : DSUB15 - DVI-I
Résolution : NC
