Bonjour a tous
Je viens d’overcloker mon E6750 => 2.66 GHz a 3.01 Ghz avec SetFSB
J’ai teste le tout avec OCCT et le système était stable => température CPU 51/52 degrés
Ma configuration est la suivante:
Proc: E6750
ram: 4* 1GO PC 6400
CM: GA-P35-DS3R
Ventilo CPU : Freezer Pro 7 => www.rue-montgallet.com…
Configure advanced CPU Settings:
CPU Ratio Setting--------------------------------8.0
C1E Support-----------------------------------Disabled
CPU TM Function------------------------------Enabled
Vanderpool Technology---------------------Disabled
Execute Disable Bit---------------------------Enabled
Max CPUID Value Limit-----------------------Disabled
Intel (R) SpeedStep ™ Tech.-------------Disabled
Configure System Performance Settings:
Ai Overclock Tuner-----------------------------Manual
FSB Strap to North Bridge--------------------333Mhz
FSB Frequency----------------------------------400Mhz
PCIE Frequency--------------------------------101Mhz
DRAM Frequency----------------------------DDR2 800Mhz
DRAM Timing Control---------------------------Manuel
CAS# Latency--------------------------------5
RAS# To CAS Delay-------------------------5
RAS# PRE Time------------------------------5
RAS# ACT Time------------------------------15
Le reste des timings sur Auto
DRAM Static Read Control-------------------Disabled
Transaction Booster-----------------------------Auto
CPU Voltage------------------------------------1.3750v
CPU PLL Voltage---------------------------------1.50v
FSB Termination Voltage-----------------------1.40v
DRAM Voltage-------------------------------------2.1v
NB Voltage----------------------------------------1.40v
Clock Over-Charging Voltage------------------Auto
Load-Line Calibration--------------------------Enabled
CPU GTL Voltage Reference--------------------0.63x
NB GTL Voltage Reference----------------------0.67x
CPU Spread Spectrum-------------------------Disabled
PCIE Spread Spectrum------------------------Disabled
Merci d’avance
Edité le 02/05/2009 à 18:07
Alors quand tu reboot c’est normale car c’est pas avec le bios que tu fais donc au démarage le bios charge les configurations qui il ya dans le bios alors que SetFSb c’est sous windows.
O/C a partir du bios c’est mieux.
Oui c’est mieu par contre un peu plus complique :s j’aimerais pas tout faire cramer lol et le vcore c’est important ?
Salut
non le mieux c’est sous bios comme il a dit damien, le SetFSB c’est pour voir les limites de ton proc et ta ram, et sous bios suis ce lien , et ne touches pas au Vcore si tu dépasse pas les 3 GHZ et de préférence mets le FSB et la mémoire en synchro ratio 1:1
ok merci par contre cela pose un probleme si mes ram sont de marques differentes ? 2x1 Corsair et 2x1 en patriot ??
j’ai remarque qu’avec FSB mon pc freeze un peu en dessou de 3.1 :s
non normalement ça pose aucun problème si elles ont la même fréquence et les mêmes timings
pas compri
en faite lorsque je passe avec fsb mon proc au dessus de 3072 Mhz il bug, affichage bleu… ce un problème ?
il est a 375 au dessus ca bug ^^ avec setFSB
ce qui me parrait etre le maximum et me suffit tout a fait, c'est gentil pour ton article mais en anglais ce un peux riqué de bien tout comprendre lol
C normal regardes le FSB max supporté pour ta carte mère normalement 1333 Mhz et toi t’es 1500 Mhz si on multiplie 4*375=1500 Mhz, sinon augmente le Vcore parceque 1.26v c’est peu pour 3 Ghz ragarde l’image[/url] et suis [url=http://www.xbitlabs.com/articles/mainboards/display/ga-p35-ds3r.html]ce lien
Edité le 03/05/2009 à 09:15
a ok d’accord c’est donc le maximum que je puisse obtenir avec setFSB snn il faudrait que je change multiplier en 6x au lieu de 8x c’est ca ?
pense tu que cette configuration fonctionnerait ?
Bonsoir,
non je parle du FSB c’est la fréquence de BUS du processeur pas du logiciel SetBus, ta carte mère normalement supporte des processeur qu’ils ont la fréquence de BUS 1333 MHZ ( E6750 est cadencé à 2.66 GHZ et sa fréquence de bus est à 1333 MHZ, ) mais en overclocking elle peut supporter plus EX la mienne EP43-DS3L supporte jusqu’à 1333 MhZ mais en overclocking suporrte jusqu’à 1600 MHZ,
et il ne faut pas que tu diminue le multiplicateur de 8 à 6 parceque tu seras obligé d’augmenter le FSB et ça plantera pareil.
tu peux fais un screen de ton bios comme cette photo les parties là t’as fait les modifs .
Edité le 02/05/2009 à 23:27
Oublie SetFSB qui n’est pas destiné aux débutants.
Alors ton CPU est @ 3,2 GHz (8*400) logiquement. Est-il bien stable en charge ?
oui et tu feras jamais du stable avec setFSB
SetFSB, sert à trouver le « maxscreen », mais en aucun cas du stable
ok merci a tous je vous fait un screen et je vous montre
bon alors je veux bien etre debutant en o/c mais je comprend pas dans mon bios ya pas tt ca
comment je peux mettre tout ce qui est marque dans ca ? www.xbitlabs.com…
En plus c’est pas les memes nom, je suis perdu lol
J’ai bien fait CTRL F1 pourtant :s
Edité le 03/05/2009 à 12:04
Mets le PCI express sur 100
Met performance enhance sur standar
Baisse le FSB à 360 pour commencer et met ton coeff CPU le plus haut possible
Tu augmenteras le FSB dans le bios au fur et mesure des test de stabilité que tu fera avec OCCT
Tu connais le max stable de ta ram ? de ton FSB ?
Après avoir fait tout ça, si à un moment, ça bloque, augmente un peu le voltage du FSB :neutre:
Avec SetFSB je suis stable a 375 pnd 1 heur avec OCCT
oui met un FSB ça s’augmente progressivement, on ne met pas 500 de FSB en 1 coup
