CPU-Z 1.38 report file
Processor(s)
Number of processors 1
Number of cores 2 per processor
Number of threads 2 (max 2) per processor
Name AMD Athlon 64 X2 4200+
Code Name Toledo
Specification AMD Athlon� 64 X2 Dual Core Processor 4200+
Package Socket 939
Family/Model/Stepping F.3.2
Extended Family/Model F.23
Brand ID 5
Core Stepping JH-E6
Technology 90 nm
Core Speed 2830.6 MHz
Multiplier x Bus speed 11.0 x 257.3 MHz
HT Link speed 1029.3 MHz
Stock frequency 2200 MHz
Instruction sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, x86-64
L1 Data cache 2 x 64 KBytes, 2-way set associative, 64-byte line size
L1 Instruction cache 2 x 64 KBytes, 2-way set associative, 64-byte line size
L2 cache 2 x 512 KBytes, 16-way set associative, 64-byte line size
Chipset & Memory
Northbridge ATI Xpress 3200 (RD580) rev. 00
Southbridge ALI M1575 rev. 00
Graphic Interface PCI-Express
PCI-E Link Width x16
PCI-E Max Link Width x16
Memory Type DDR
Memory Size 2048 MBytes
Memory Frequency 202.2 MHz (CPU/14)
CAS# Latency (tCL) 2.5 clocks
RAS# to CAS# (tRDC) 3 clocks
RAS# Precharge (tRP) 3 clocks
Cycle Time (tRAS) 8 clocks
Bank Cycle Time (tRC) 11 clocks
DRAM Idle Timer 16 clocks
Command Rate 1T
System
System Manufacturer
System Name
System S/N
Mainboard Vendor http://www.abit.com.tw/
Mainboard Model AT8 32X(ATI RD580-ULI M1575)
BIOS Vendor Phoenix Technologies, LTD
BIOS Version 6.00 PG
BIOS Date 05/19/2006
Memory SPD
Module 1 DDR, PC3200 (200 MHz), 1024 MBytes, Kingston
Module 2 DDR, PC3200 (200 MHz), 1024 MBytes, Kingston
Software
Windows Version Microsoft Windows XP Home Edition Service Pack 2 (Build 2600)
DirectX Version 9.0c
Que d’information sur ton matos
. Commence par bloquer tes ports Pci-e et Pci à respectivement 100 et 33Mhz
. On verra la suite plus tard
:hello: BONJOUR, :hello:
Et ? :??:
Va voir la: http://www.clubic.com/forum/-topic-referen…pi-t310753.html
Puis: http://www.clubic.com/forum/-topic-referen…64-t315612.html
C’est toujours utile de lire :o En plus un bon tuto bien fait, tu as besoin de rien de plus si ce n’est le lire, l’appliquer et overclocker comme il faut
Amuse toi bien.
Et de rien .
