Je recherche une carte mere socket 478 avec ou sans cpu, 100% fonctionnelle et surtout pas CHERE.
merci.
up
Salut, moi je vend ma carte mere, de préférence avec le processeur, voici les caractéristiques :
Pross:
Pentium 4 Prescott 3.2 Hyperthreading
fréquence : 3.2Ghz
cache L2 : 1 Mo
socket 478
Carte Mère :
Gigabyte 8KNXP (P4 titan, Dual Bios, Dual Channel DDR, Dual Power System, SATA, FIREWIRE, RAID, AGP 8x)
Processor
Socket 478 for Intel® Pentium® 4 processor.
Chipset
North Bridge : Intel® 875P MCH
South Bridge : Intel® ICH5R
Integrated Peripherals :
Intel® CSA interface Gigabit Ethernet Controller
Silicon Image Serial ATA chip
Texas Instrument IEEE 1394 chip
GigaRAID controller chip
Realtek ALC658 CODEC
Front Side Bus
1.800 / 533 / 400 MHz FSB
Memory
Type: Dual Channel DDR 400 / 333 / 266 ECC support
Max capacity: 4 GB (Please read FAQ for further information)
DIMM slots: 6 *
*Note: Through GIGABYTE innovation of supporting 6 DIMMS memory on Intel chipset motherboard. However, due to chipset limitations there will be a frequency downgrade of memory modules when 6 DIMMs are fully loaded.
Internal I/O Connectors
4 x Serial ATA connectors
2 x IEEE 1394 pin headers
2 x USB 2.0 (supports 4 ports by cable)
4.2 x UltraDMA 133/100/66 Bus Master IDE (For HDDs only)
2 x UltraDMA 100/66 Bus Master IDE
1 x FDD
1 x S/P-DIF input/output pin header
CD/AUX in
1 x Game port pin header
Expansion Slots
1 x AGP Pro slot
5 x PCI slots (PCI 2.3 compliant)
1 x DPS slot
Rear Panel I/O
4 x USB 2.0 ports
1 x RJ45 LAN port
1 x LPT port
2 x COM ports
3 x Audio ports (Line-in / Line-out / MIC)
2 x PS/2 ports (Keyboard/Mouse)
Form Factor
ATX
2.30.5cm x 24.4cm
H/W Monitoring
ITE 8712F
System health status auto-detect and report by BIOS
Hardware detecting and reporting for case open, power-in voltage, CPU voltage, and fan speed.
BIOS
2 x 4M bit flash ROM, Award BIOS
Other Features
Xpress Install
Xpress Recovery
Smart Fan
EasyTune 4
@BIOS
Q-Flash
Multi Language BIOS
Driver
Intel® chipset software installation utility
Silcon Image Serial ATA driver
GigaRAID IDE RAID driver
Intel® RAID Driver
Intel® PRO/1000 CT LAN driver
Realtek audio driver
USB2.0 driver
Supports 800MHz FSB Pentium® 4 Processor with HT Technology
Supports Dual Channel DDR400 architecture with ECC
AGP 8X with AGP Pro interface for work-station graphics
Gigabyte patented Dual Power System 2 (DPS 2 ) design
Integrated Serial-ATA interface with RAID 0 function
Integrated T.I. IEEE1394 interface
Integrated GigaRAID IDE RAID interface
Integrated Intel® PRO/1000 CT Network Connection
Features Performance Acceleration Technology (PAT)
C’est une très bonne carte mère stable, jamais overclokée elle était utilisée il y a 3 ans dans les config ALIENWARE, avec le meme pross. J’utilise cette machine avec 2Go de ram pour faire tourner des machines virtuelle (VMWARE), et le tout est trés stable, le pross est actuellement surmonté d’un ventirad tout cuivre avec caloduc, en pleine utilisation sans overcloking sa tourne autour de 35° en été.
Je vend la carte mère plus le pross pour 120, mais on peut peut être discuter…
Possibbilité de vendre la RAM avec ( CORSAIR PC3200 (400Mhz)).
Cordialement.
[COLOR=blue]
j’ai une carte
GiGABYTE GA 81DMNF
soket 478
1 agp
3 pci
1 amr
prix 25 port collissimo compris
personne a moins chere, je cherche juste une mobo pour en remplacer une grillé, le moins cher possible.
salut moi j’en ai…
mais est tu sur paris ?
ps:
(jen ai une sans port agp
une autre avec un port agp4x, et une autre agp8x … :ouch: ça pose probleme
de quoi aurait tu besoin exactement?)
[quote=klez,8/01/2007, 02:14:21]
oui je suis sur Paris
(enfin je passe par Paris gare du nord tous les jours), il faut qu elle est un port agp, mais entre du 4* et du 8*, aucune importance, tu les fais a combien tes mobo ? tu me contactes en MP stp.
juge je t’ai envoyé un mp :na:
je suis intéressé par votre carte + proc. Contactez-moi.
Cordialement
J’ai une mobo ECS a vendre sur mon topic.
