[VDS] barrette 1 GO DDRAM PC 3200 DDR 400MHZ DIMM 184 broches AVEC DISSIPATEUR THERMIQUE.
LA BARRETTE FONCTIONNE AVEC LES CHIPSETS SUIVANTS :
VIA P4X266A,
*.VIA KT266/333 (except ASUS KT266/333)
*.VIA KT600 (except ASUS KT600)
*.VIA PT800
*.SIS 645
*.SIS 648
- 648FX
*.SIS 746FX - KM400
- K8T800
- KT 880
- KT 400 (except ASUS KT400)
- KT 400A
- SIS 661FX
- SIS 655
- SIS 650GX
- SIS 650
- NFORCE 250GB
- ULI CHIPSETS
- INTEL 915
- NFORCE 4 SLI
- VIA APPOLLO P4X400
- VIA K8M800
- VIA K8M890
- VIA K8N800
- VIA K8N890
- VIA K8T800
- VIA K8T890
- VIA K8T900
- VIA PT800
- VIA PT880
- VIA PT890
- VIA P4M800
- VIA P4M800 PRO
- VIA P4M890
- VIA P4M900
- VIA PN800
- SIS 648
- SIS 649
- SIS 650
- SIS 651
- SIS 656
- SIS 661
- SIS 748
- SIS 750
- SIS 755
- SIS 756
-SPECIFICATIONS GENERALES:
-184 PIN Memory
-3.2 GB/sec
-400Mhz
-2.5 Volt Module
-DIMM (DUAL IN-LINE MEMORY 128 X 64) HIGH DENSITY
-Non-ECC, Non-Parity
-Unbuffered
INFOS SUPPLEMENTAIRES
-Chip Configuration: 128x64
-Chip Density: 128x4 (High Density)
-Double face avec 8 chips par face
-Dimm (Dual in-line memory 128 X 64) HIGH DENSITY
-Non Ecc, Non Registered
-CAS Latency: 3
-184 Pins, SPD Support
Fdp in:40 euros
Edité le 08/06/2007 à 20:04
