OK, je peut attendre ![]()
Excuse moi « sylvio » mais je vois dans ta config :
P5B Delux Wi-Fi AP / E6600@3.3Ghz / 4*1Go GSkill 6400 PK / X1950XT / Casque HD650
Tu fonctionne donc avec 4 go de mémoire… car moi il se trouve que c’est impossible
Je précise que même le Bios ne detecte que 3 go
Je possède actuellemnt la Asus P5N32-SLI SE Deluxe mais je n’en suis pas satisfait … je ne peut pas mettre 4 go (4 barrettes de 1 go ) elle ne detecte que 3 go .
Pourtant je peut vu ses caractéristiques
www.ldlc.com…
J’ai écrit à ASUS et il m’on répondu ça :
Voici l’explication de votre problème :
If you installed total 4GB memory, the system will detect less than 4GB of total memory because of address space allocation for other critical functions, such as:
- System BIOS (including motherboard, add-on cards, etc…)
- Motherboards resources
- Memory mapped I/O
- configuration for AGP/PCI-Ex/PCI
- Other memory allocations for PCI devices
Different onboard devices and different add-on cards (devices) will result of different total memory size.
e.g. more PCI cards installed will require more memory resources, resulting of less memory free for other uses.
On a SLI system, since PCI-Ex graphic cards will occupy around 256MB, another 256MB will be occupied after you install a 2nd PCI-Ex graphic card. Hence, ! 2.75GB memory left only if two SLI cards installed on A8N-SLI Premium while 3.0GB memory left with one graphic card without other add-on devices.
This limitation applies to most chipsets & Windows XP 32-bit version operating system.
If you install Windows XP 32-bit version operating system, we recommend that you install less than 3GB of total memory. If more than 3GB memory is required for your system, then below two conditions must be met:
- The memory controller which supports memory swap functionality is used. The latest chipsets like Intel 975X, 955X, Nvidia NF4 SLI Intel Edition, Nvidia NF4 SLI X16, and AMD K8 CPU architecture can support the memory swap function.
- Windows XP Pro X64 Ed. (64-bit) or other OS which can address more than 4GB memory.
TRADUIT PAR GOOGLE :
Si vous installiez la mémoire 4GB totale, le système détectera moins que 4GB de mémoire totale en raison de l’attribution d’espace adresse pour d’autres fonctions critiques, comme :
- BIOS de système (carte mère y compris, cartes ajoutées, etc?)
- Ressources de cartes mères
- Entrée-sortie tracée par mémoire
- configuration pour AGP/PCI-Ex/PCI
- D’autres attributions de mémoire pour des dispositifs de PCI
Différent à bord des dispositifs et de différentes cartes ajoutées (dispositifs) résultera de la capacité de la mémoire totale différente.
par exemple plus de cartes de PCI installées exigeront plus de ressources de mémoire, résulter de moins de mémoire librement pour d’autres usages.
Sur un système de SLI, puisque les cartes graphiques PCI-Ex occuperont autour de 256MB, un autre 256MB sera occupé après que vous installiez une 22eme carte graphique PCI-Ex. Par conséquent ! la mémoire 2.75GB est partie seulement si deux cartes de SLI installées sur la prime d’A8N-SLI tandis que la mémoire 3.0GB partait avec une carte graphique sans d’autres dispositifs ajoutés.
Cette limitation s’applique à la plupart de logiciel d’exploitation de chipsets et de version de 32 bits de Windows XP.
Si vous installez le logiciel d’exploitation de version de 32 bits de Windows XP, nous recommandons que vous installez moins que 3GB de mémoire totale. Si plus que la mémoire 3GB est exigé pour votre système, alors en-dessous de deux conditions doit être réuni :
- Le contrôleur de mémoire qui soutient la fonctionnalité d’échange de mémoire est employé. Les derniers chipsets aiment Intel 975X, 955X, édition de Nvidia NF4 SLI Intel, Nvidia NF4 SLI X16, et l’architecture d’unité centrale de traitement d’AMD K8 peut soutenir la fonction d’échange de mémoire.
- Windows XP pro X64 ED. (64-bit) ou l’autre OS qui peut adresser plus que la mémoire 4GB.
Enfin je me suis décidé a conserver ma carte mère car j’ai vu dans plusieurs test que pour l’instant le passage de 2 à 4 go n’apporte rien d’extraordinaire !
Edité le 17/09/2007 à 21:57
